Orf Gelbrich
Automating the UCSD internal DB Backup for a single node deployment:
The crontab entry
[root@localhost etc]# crontab -l
1 2 * * 0 /usr/local/etc/DB_BACKUP > /dev/null 2>&1
The Script on UCSD
[root@localhost etc]# cat /usr/local/etc/DB_BACKUP
#!/bin/sh
# server login password localfile remote-dir
upload_script(){
      echo "verbose"
      echo "open $1"
      sleep 2
      echo "user $2 $3"
      sleep 3
      shift 3
      echo "bin"
      echo $*
      sleep 10
      echo quit
doftpput(){
        upload_script $1 $2 $3 put $4 $5 | /usr/bin/ftp -i -n -p
/opt/infra/stopInfraAll.sh
/opt/infra/dbBackupRestore.sh backup
BKFILE=/tmp/database_backup.tar.gz
if [ ! -f $BKFILE ]
then
  echo "Backup failed. "
  return 1
fi
export NEWFILE="cuic_backup_`date '+%m-%d-%Y-%H-%M-%S'`.tar.gz"
export FTPSERVER=172.17.32.110
export FTPLOGIN=cisco
export FTPPASS=cisco
doftpput $FTPSERVER $FTPLOGIN $FTPPASS $BKFILE $NEWFILE
nohup /opt/infra/startInfraAll.sh &
exit 0
mkdir /usr/local/etc
vi /usr/local/etc/DB_BACKUP
  cut and paste above text
chmod +x /usr/local/etc/DB_BACKUP
Update crontab
     set -o vi
     crontab -e
Ideas for Multi Node Backup
(1) Enable SSH on all hosts with pub key from Inventory DB.
(2) Write a script in such a way that from Inventory, it shutdown all primary, service nodes (hardcoding the IPs)
(3) Invoke a local backup command on the  inventory node and copy the backup to NFS
(4)  Invoke a remote backup command on the monitoring node and copy the backup to NFS
(5)  Start Service nodes, Primary nodes
Put this in a cron on Inventory node.
Another contribution by:
     Alejandro Madurga Ainoza
Python scripts to stop the services on a multimode (single node work as well)
In this case customer wanted to store the backup on a server filesystem (that could be NFS mounted).
Scripts attached, they call the OOTB backup scripts but avoid the FTP steps.
yshtoots
Does UCSD DB backup and restore is enough for full UCSD restoration from scratch?
Orf Gelbrich
Yes it does. But the dB coming and going to has to match the ucsd version
