Orf Gelbrich
Task NamePrint UCSD Java Methods
Description
Prerequisites
  1. Tested on 5.4
CategoryWorkflow
ComponentsvSphere 5.x
User Inputs
  8. Click "Submit".
A big thank you for the inspiration goes out to Mohamed Arif Hajamohideen.
Java docs on the UCSD appliance:
For the  java docs , please SSH to the UCSD server and check the location
  • /opt/infra/web_cloudmgr/apache-tomcat/webapps/app/javadocs  à
  • /opt/infra/web_cloudmgr/apache-tomcat/webapps/cloupia/javadocs  à
How to print UCSD JAVA Methods:
The workflow:
The Code:
importPackage(java.lang.reflect);
importPackage(java.io);
importPackage(com.cloupia.service.cIM.inframgr);
var javamethodname = [ ctxt.getInput("JavaMethodName") ];
function main() {
if (javamethodname == '1') {
                var t = new VDCUtil();
  logger.addWarning("javamethodname (VDCUtil): " + javamethodname);
if (javamethodname == '2') {
                var t = new InfraPersistenceUtil();
  logger.addWarning("javamethodname (InfraPersistenceUtil): " + javamethodname);
                var tClass = t.getClass();
                var methods = tClass.getMethods();
                for (var i = 0; i < methods.length; i++) {
                                logger.addWarning("Public Method: " + methods[i]);
main();
The VDCUtil:
Service Request ID: 5737
Workflow Inputs:
- JavaMethodName
Nov 08, 2015 12:28:51 UTC Request submitted
Nov 08, 2015 12:28:55 UTC Executing workflow item number 1
Nov 08, 2015 12:28:55 UTC Completed workflow item number 0, with status Completed
Nov 08, 2015 12:28:59 UTC Executing workflow item number 2
Nov 08, 2015 12:28:59 UTC Trigger context executeWorkFlowStep called
Nov 08, 2015 12:28:59 UTC Executing custom action PrintJavaMethods (ExecuteCloupiaScript)
Nov 08, 2015 12:29:02 UTC Executing cloupia script: PrintJavaMethods
Nov 08, 2015 12:29:02 UTC javamethodname (VDCUtil): 1
Nov 08, 2015 12:29:02 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.PrivateCloudComputingPolicy com.cloupia.service.cIM.inframgr.VDCUtil.copy(com.cloupia.service.cIM.inframgr.profiles.PrivateCloudComputingPolicy)
Nov 08, 2015 12:29:02 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.HyperVCloudComputingPolicy com.cloupia.service.cIM.inframgr.VDCUtil.copy(com.cloupia.service.cIM.inframgr.profiles.HyperVCloudComputingPolicy)
Nov 08, 2015 12:29:02 UTC Public Method: public static com.cloupia.model.cIM.VDC com.cloupia.service.cIM.inframgr.VDCUtil.copy(com.cloupia.model.cIM.VDC)
Nov 08, 2015 12:29:02 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.PrivateCloudSystemProfile com.cloupia.service.cIM.inframgr.VDCUtil.copy(com.cloupia.service.cIM.inframgr.profiles.PrivateCloudSystemProfile)
Nov 08, 2015 12:29:02 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.HyperVDeploymentProfile com.cloupia.service.cIM.inframgr.VDCUtil.copy(com.cloupia.service.cIM.inframgr.profiles.HyperVDeploymentProfile)
Nov 08, 2015 12:29:02 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.PrivateCloudStoragePolicy com.cloupia.service.cIM.inframgr.VDCUtil.copy(com.cloupia.service.cIM.inframgr.profiles.PrivateCloudStoragePolicy)
Nov 08, 2015 12:29:02 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.PrivateCloudNetworkPolicy com.cloupia.service.cIM.inframgr.VDCUtil.copy(com.cloupia.service.cIM.inframgr.profiles.PrivateCloudNetworkPolicy) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.HyperVCloudStoragePolicy com.cloupia.service.cIM.inframgr.VDCUtil.copy(com.cloupia.service.cIM.inframgr.profiles.HyperVCloudStoragePolicy)
Nov 08, 2015 12:29:02 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.CostModel com.cloupia.service.cIM.inframgr.VDCUtil.copy(com.cloupia.service.cIM.inframgr.profiles.CostModel)
Nov 08, 2015 12:29:02 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.HyperVCloudNetworkPolicy com.cloupia.service.cIM.inframgr.VDCUtil.copy(com.cloupia.service.cIM.inframgr.profiles.HyperVCloudNetworkPolicy)
Nov 08, 2015 12:29:02 UTC Public Method: public static com.cloupia.model.cIM.VDC com.cloupia.service.cIM.inframgr.VDCUtil.getVDC(int) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static com.cloupia.model.cIM.VDC com.cloupia.service.cIM.inframgr.VDCUtil.getVDC(int,boolean) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static com.cloupia.model.cIM.VDCCatalogItem com.cloupia.service.cIM.inframgr.VDCUtil.getVDCCatalogItemByName(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static com.cloupia.model.cIM.VDC com.cloupia.service.cIM.inframgr.VDCUtil.getVDCByName(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static com.cloupia.model.cIM.VDCCatalogItem com.cloupia.service.cIM.inframgr.VDCUtil.getVDCCatalogItem(int) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.VDCUtil.isDeletable(com.cloupia.model.cIM.VDC,java.lang.StringBuffer)
Nov 08, 2015 12:29:02 UTC Public Method: public static java.lang.String com.cloupia.service.cIM.inframgr.VDCUtil.getFolderName(int)
Nov 08, 2015 12:29:02 UTC Public Method: public static java.lang.String com.cloupia.service.cIM.inframgr.VDCUtil.getDeleteAction(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static java.lang.String[] com.cloupia.service.cIM.inframgr.VDCUtil.getCatalogAppNames(int[]) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static com.cloupia.model.cIM.CatalogOSEntry com.cloupia.service.cIM.inframgr.VDCUtil.getCatalogOS(int) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.VDCUtil.getVDCCatalogItemList(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.VDCUtil.getVDCCatalogItemList() throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.VDCUtil.getVMAccessScheme(int) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static java.util.Map com.cloupia.service.cIM.inframgr.VDCUtil.getVDCIdToNameMap() throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static java.util.Map com.cloupia.service.cIM.inframgr.VDCUtil.getVDCIdToCloudNameMap() throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static java.util.Map com.cloupia.service.cIM.inframgr.VDCUtil.getVDCCatalogItemIdToNameMap() throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.VDCUtil.addVDCCatalogItem(com.cloupia.model.cIM.VDCCatalogItem) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.VDCUtil.addVirtualSANVDCCatalogItem(com.cloupia.feature.vmwareController.virtualSAN.model.VirtualSANVDCCatalogItemInfo) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.VDCUtil.modifyVDCCatalogItem(com.cloupia.model.cIM.VDCCatalogItem) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.VDCUtil.deleteVDCCatalogItem(int) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.VDCUtil.getVDIVDCList() throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static int com.cloupia.service.cIM.inframgr.VDCUtil.getVDCCountByGrpId(int) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static java.util.Map com.cloupia.service.cIM.inframgr.VDCUtil.getVDCMapByGrpId(int) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.VDCUtil.getVDCByStoragePolicy(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.VDCUtil.getVDCByNetworkPolicy(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.VDCUtil.getVDCBySystemPolicy(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.VDCUtil.getVDCByCostModel(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.VDCUtil.getVDCByComputingPolicy(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.VDCUtil.getCloudListForGroup(int) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.VDCUtil.deleteVDC(int) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static java.util.Map com.cloupia.service.cIM.inframgr.VDCUtil.getVDCMap() throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.VDCUtil.modifyVDC(com.cloupia.model.cIM.VDC) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.VDCUtil.modifyVDC(com.cloupia.model.cIM.VDC,boolean) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.VDCUtil.addVDC(com.cloupia.model.cIM.VDC) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.VDCUtil.addVDCAppCategory(java.util.List)
Nov 08, 2015 12:29:02 UTC Public Method: public static com.cloupia.model.cIM.VDCXenDesktopParams com.cloupia.service.cIM.inframgr.VDCUtil.getVDCXenDesktopPrams(int) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static java.util.Map com.cloupia.service.cIM.inframgr.VDCUtil.validateDataStores(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static java.util.Map com.cloupia.service.cIM.inframgr.VDCUtil.validateHyperVDataStores(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static java.util.Map com.cloupia.service.cIM.inframgr.VDCUtil.validatePortGroup(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.VDCUtil.validateNetworkPolicyIPPoolPolicies(java.util.Map,com.cloupia.service.cIM.inframgr.profiles.PrivateCloudNetworkPolicy) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.VDCUtil.getEnabledCatalogApps() throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static com.cloupia.model.cIM.CatalogAppEntry com.cloupia.service.cIM.inframgr.VDCUtil.getCatalogApp(int) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.VDCUtil.isVMPartOfContainerVDC(java.lang.String)
Nov 08, 2015 12:29:02 UTC Public Method: public static int com.cloupia.service.cIM.inframgr.VDCUtil.getVMContainerId(java.lang.String)
Nov 08, 2015 12:29:02 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.VDCUtil.getEnabledCatalogOSes() throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.VDCUtil.isComputingPolicyInUse(int)
Nov 08, 2015 12:29:02 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.VDCUtil.isSystemsPolicyInUse(int)
Nov 08, 2015 12:29:02 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.VDCUtil.isStoragePolicyInUse(int)
Nov 08, 2015 12:29:02 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.VDCUtil.isNetworkPolicyInUse(int)
Nov 08, 2015 12:29:02 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.VDCUtil.isNetworkPolicyInUse(java.lang.String)
Nov 08, 2015 12:29:02 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.VDCUtil.isAmazonPolicyInUse(int)
Nov 08, 2015 12:29:02 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.VDCUtil.isRackspacePolicyInUse(int)
Nov 08, 2015 12:29:02 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.VDCUtil.getAllCatalogApps() throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.VDCUtil.getAllCatalogOSes() throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static int com.cloupia.service.cIM.inframgr.VDCUtil.getVMCountInVDC(com.cloupia.model.cIM.VDC) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static com.cloupia.service.cIM.inframgr.VDCUtil$VDCVMCount com.cloupia.service.cIM.inframgr.VDCUtil.getVMCountsForVDC(int) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static com.cloupia.service.cIM.inframgr.VDCUtil$VDCVMCount com.cloupia.service.cIM.inframgr.VDCUtil.getVMCountsForVDC(com.cloupia.model.cIM.VDC) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.VDCUtil.getVMsAssociatedWithVDC(int) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.VDCUtil.getVMsAssociatedWithSRID(int) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.VDCUtil.getVDCAppCategoryByCatID(int)
Nov 08, 2015 12:29:02 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.VDCUtil.modifyVDCAppCategory(int,com.cloupia.model.cIM.VDCAppCategory) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.VDCUtil.validateNetworkPolicyPortGroup(java.lang.String,java.util.Map,com.cloupia.service.cIM.inframgr.profiles.PrivateCloudNetworkPolicy,boolean) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static java.util.Map com.cloupia.service.cIM.inframgr.VDCUtil.validateHyperVPortGroup(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.VDCUtil.validateHypervNetworkPolicyPortGroup(java.lang.String,java.util.Map,com.cloupia.service.cIM.inframgr.profiles.HyperVCloudNetworkPolicy,boolean) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static java.util.Map com.cloupia.service.cIM.inframgr.VDCUtil.validateVMWithVDC(com.cloupia.model.cIM.VDC,int,int,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static java.util.Map com.cloupia.service.cIM.inframgr.VDCUtil.validateImageWithVDC(com.cloupia.model.cIM.VDC,com.cloupia.model.cIM.VDCCatalogItem) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static java.util.Map com.cloupia.service.cIM.inframgr.VDCUtil.validateKvmImageWithVDC(com.cloupia.model.cIM.VDC,com.cloupia.model.cIM.VDCCatalogItem) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.VDCUtil.getVDCCatalogItemListByGrpId(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.VDCUtil.getGenericVMsForVDC(int) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.VDCUtil.getActiveGenericVMsForVDC(int) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.VDCUtil.queryMeteringRecords(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.VDCUtil.getVMMeteringEntryList(int,java.util.Calendar,java.util.Calendar) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static double com.cloupia.service.cIM.inframgr.VDCUtil.getAggreatedValue(java.util.List,java.lang.String,java.util.Calendar)
Nov 08, 2015 12:29:02 UTC Public Method: public static com.cloupia.service.cIM.inframgr.HistoricalDataEntry com.cloupia.service.cIM.inframgr.VDCUtil.getHistoricalDataEntry(java.util.List,java.lang.String,java.util.Calendar)
Nov 08, 2015 12:29:02 UTC Public Method: public static int com.cloupia.service.cIM.inframgr.VDCUtil.deleteInactiveVMs(com.cloupia.model.cIM.VDC) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.VDCUtil.isVMPoweredOn(com.cloupia.model.cIM.GenericVM) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.VDCUtil.isVMFailed(com.cloupia.model.cIM.GenericVM) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.VDCUtil.addNetworkDeploymentPolicy(com.cloupia.service.cIM.inframgr.profiles.NetworkDeploymentPolicy) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.VDCUtil.modifyNetworkDeploymentPolicy(com.cloupia.service.cIM.inframgr.profiles.NetworkDeploymentPolicy) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.VDCUtil.deleteNetworkDeploymentPolicy(int) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.VDCUtil.getNetworkDeploymentPolicies() throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.NetworkDeploymentPolicy com.cloupia.service.cIM.inframgr.VDCUtil.getNetworkDeploymentPolicy(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.NetworkDeploymentPolicy com.cloupia.service.cIM.inframgr.VDCUtil.getNetworkDeploymentPolicy(int) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.VDCUtil.addWindowsLicense(com.cloupia.service.cIM.inframgr.profiles.WindowsLicense) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.VDCUtil.getWindowsLicenseAll() throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.WindowsLicense com.cloupia.service.cIM.inframgr.VDCUtil.getWindowsLicense(int) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.VDCUtil.modifyWindowsLicense(com.cloupia.service.cIM.inframgr.profiles.WindowsLicense) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.VDCUtil.deleteWindowsLicense(int) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.VDCUtil.addVirtualStorageCatalog(com.cloupia.service.cIM.inframgr.profiles.VirtualStorageCatalog) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.VDCUtil.modifyVirtualStorageCatalog(com.cloupia.service.cIM.inframgr.profiles.VirtualStorageCatalog) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.VDCUtil.deleteVirtualStorageCatalog(int) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.VDCUtil.getVirtualStorageCatalogs() throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.VDCUtil.getVirtualStorageCatalogsByCloud(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.VirtualStorageCatalog com.cloupia.service.cIM.inframgr.VDCUtil.getVirtualStorageCatalog(int) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.VirtualStorageCatalog com.cloupia.service.cIM.inframgr.VDCUtil.getVirtualStorageCatalog(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static long com.cloupia.service.cIM.inframgr.VDCUtil.addVirtualStorageEntry(com.cloupia.service.cIM.inframgr.profiles.VirtualStorageEntry) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.VDCUtil.modifyVirtualStorageEntry(com.cloupia.service.cIM.inframgr.profiles.VirtualStorageEntry) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.VDCUtil.deleteVirtualStorageEntry(long) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.VDCUtil.deleteVirtualStorageEntryForCatalog(int) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.VDCUtil.getVirtualStorageEntries(int) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.VDCUtil.getAllVirtualStorageEntries() throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.VirtualStorageEntry com.cloupia.service.cIM.inframgr.VDCUtil.getVirtualStorageEntry(long) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.VDCUtil.addVLANPoolPolicy(com.cloupia.service.cIM.inframgr.profiles.VLANPoolPolicy) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.VDCUtil.modifyVLANPoolPolicy(com.cloupia.service.cIM.inframgr.profiles.VLANPoolPolicy) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.VDCUtil.deleteVLANPoolPolicy(int) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.VDCUtil.getVLANPoolPolicies() throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.VLANPoolPolicy com.cloupia.service.cIM.inframgr.VDCUtil.getVLANPoolPolicyById(int) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.VLANPoolPolicy com.cloupia.service.cIM.inframgr.VDCUtil.getVLANPoolPolicyByName(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.VDCUtil.getVXLANPoolPolicies() throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.VDCUtil.addVXLANPoolPolicy(com.cloupia.service.cIM.inframgr.profiles.VXLANPoolPolicy) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.VDCUtil.modifyVXLANPoolPolicy(com.cloupia.service.cIM.inframgr.profiles.VXLANPoolPolicy) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.VDCUtil.deleteVXLANPoolPolicy(int) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.VXLANPoolPolicy com.cloupia.service.cIM.inframgr.VDCUtil.getVXLANPoolPolicyById(int) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.VXLANPoolPolicy com.cloupia.service.cIM.inframgr.VDCUtil.getVXLANPoolPolicyByName(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.VDCUtil.getVDCCatalogItembyCloudName(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.VDCUtil.getVDCCatalogItembyCloudNameAndType(java.lang.String,int) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.VDCUtil.getVDCCatalogItemByType(int) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static long com.cloupia.service.cIM.inframgr.VDCUtil.getContainerVMCount(java.lang.String,int) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static java.util.Map com.cloupia.service.cIM.inframgr.VDCUtil.getContainerVMCountMap()
Nov 08, 2015 12:29:02 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.VDCUtil.isVSCEnabled(java.lang.String)
Nov 08, 2015 12:29:02 UTC Public Method: public static com.cloupia.lib.cIaaS.xendesktop.model.XenHostingUnit com.cloupia.service.cIM.inframgr.VDCUtil.getXenHostingUnitByAccountAndName(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static com.cloupia.lib.cIaaS.xendesktop.model.XenDesktopGroup com.cloupia.service.cIM.inframgr.VDCUtil.getXenDesktopGroupByAccountAndUID(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.VDCUtil.persistVDCStatus(java.util.List)
Nov 08, 2015 12:29:02 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.VDCUtil.persistVDCComplianceStatus(java.util.List,java.lang.String)
Nov 08, 2015 12:29:02 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.VDCUtil.updateVDCStatus(com.cloupia.model.cIM.VDCStatus)
Nov 08, 2015 12:29:02 UTC Public Method: public static com.cloupia.model.cIM.VDCStatus com.cloupia.service.cIM.inframgr.VDCUtil.getVDCStatus(int)
Nov 08, 2015 12:29:02 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.VDCUtil.getVDCCatalogItemByFolders() throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.VDCUtil.getVDCCatalogItemByFoldersAndCloudName(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.VDCUtil.getVirtualSANVDCCatalogItemByFoldersAndCloudNameAndPodName(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.VDCUtil.migrateCatalogFolderName() throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.VDCUtil.getVDCCatalogItemByFolderName(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.VDCUtil.isCatlogFolderNameUsed(java.lang.String)
Nov 08, 2015 12:29:02 UTC Public Method: public static com.cloupia.model.cIM.VDCCatalogItem com.cloupia.service.cIM.inframgr.VDCUtil.moveUpCatalogs(int,int) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static com.cloupia.model.cIM.VDCCatalogItem com.cloupia.service.cIM.inframgr.VDCUtil.moveDownCatalogs(int,int) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.VDCUtil.updateCatalogItem(int,int,int,int) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.VDCUtil.isEndUserPolAssociatedToVdc(int) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.VDCUtil.isVmMgmtPolAssociatedToVdc(int) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static com.cloupia.model.cIM.VDCCatalogItem com.cloupia.service.cIM.inframgr.VDCUtil.getVdcCatalogItem(int) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.VDCUtil.getVDCCatalogItemFolderListByGrpId(java.util.Map,boolean) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.VDCUtil.updateFolderList(java.util.List) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.VDCUtil.deleteFolderList(java.util.List) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static int com.cloupia.service.cIM.inframgr.VDCUtil.getFolderIndexbyCatalog(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static int com.cloupia.service.cIM.inframgr.VDCUtil.checkCatalogFolderChange(int,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static com.cloupia.model.cIM.FormLOVPair[] com.cloupia.service.cIM.inframgr.VDCUtil.getInactiveDaysLOV()
Nov 08, 2015 12:29:02 UTC Public Method: public static java.lang.String com.cloupia.service.cIM.inframgr.VDCUtil.validateApprovers(java.lang.String)
Nov 08, 2015 12:29:02 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.VDCUtil.isValidEmailAddress(java.lang.String)
Nov 08, 2015 12:29:02 UTC Public Method: public static java.lang.String com.cloupia.service.cIM.inframgr.VDCUtil.validateEmailAddress(java.lang.String)
Nov 08, 2015 12:29:02 UTC Public Method: public static java.lang.String[] com.cloupia.service.cIM.inframgr.VDCUtil.removeSpaceList(java.lang.String)
Nov 08, 2015 12:29:02 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.VDCUtil.createCatalogIcon(com.cloupia.model.cIM.CatalogImageIcon) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.VDCUtil.updateIconsCurrentlyUsedInformation(boolean,java.lang.String)
Nov 08, 2015 12:29:02 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.VDCUtil.deletefolderNameExisist(java.lang.String)
Nov 08, 2015 12:29:02 UTC Public Method: public static java.lang.String com.cloupia.service.cIM.inframgr.VDCUtil.getCatalogFolderIcon(java.lang.String)
Nov 08, 2015 12:29:02 UTC Public Method: public static java.lang.String com.cloupia.service.cIM.inframgr.VDCUtil.getDefaultFolderIcon()
Nov 08, 2015 12:29:02 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.VDCUtil.validateAllVDCsPerCloud(java.lang.String)
Nov 08, 2015 12:29:02 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.VDCUtil.modifyVDCStatus(java.util.List)
Nov 08, 2015 12:29:02 UTC Public Method: public static com.cloupia.model.cIM.VDCResourceLimit com.cloupia.service.cIM.inframgr.VDCUtil.getVDCResourceLimit(int) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.VDCUtil.addVDCResourceLimit(com.cloupia.model.cIM.VDCResourceLimit) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.VDCUtil.deleteVDCResourceLimit(int) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.VDCUtil.updateVDCResourceLimit(com.cloupia.model.cIM.VDCResourceLimit) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static java.util.Map com.cloupia.service.cIM.inframgr.VDCUtil.validateVDC(com.cloupia.model.cIM.VDC) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static java.lang.String com.cloupia.service.cIM.inframgr.VDCUtil.getAppListStr(int[]) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static java.util.Map com.cloupia.service.cIM.inframgr.VDCUtil.getVMCountsForAllVDCs() throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static java.util.Map com.cloupia.service.cIM.inframgr.VDCUtil.getVDCStatusMap()
Nov 08, 2015 12:29:02 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.VDCUtil.getVDCByCloudName(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.VDCUtil.getVDCAppCategory(int)
Nov 08, 2015 12:29:02 UTC Public Method: public static com.cloupia.model.cIM.VDCAppCategory com.cloupia.service.cIM.inframgr.VDCUtil.getVDCAppCategory(int,int) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.VDCUtil.getVDCByGrpId(int) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.VDCUtil.getVDCByGrpId(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.VDCUtil.getVDCList() throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.VDCUtil.getVDCByGrpIdAndCloudName(int,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.VDCUtil.getVDCComplianceStatus(int)
Nov 08, 2015 12:29:02 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.VDCUtil.getVDCBaicViewList() throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.VDCUtil.getAggregateHistoricalData(com.cloupia.model.cIM.VDC,java.lang.String,long,long) throws java.lang.Exception
Nov 08, 2015 12:29:02 UTC Public Method: public final void java.lang.Object.wait(long,int) throws java.lang.InterruptedException
Nov 08, 2015 12:29:02 UTC Public Method: public final native void java.lang.Object.wait(long) throws java.lang.InterruptedException
Nov 08, 2015 12:29:02 UTC Public Method: public final void java.lang.Object.wait() throws java.lang.InterruptedException
Nov 08, 2015 12:29:02 UTC Public Method: public boolean java.lang.Object.equals(java.lang.Object)
Nov 08, 2015 12:29:02 UTC Public Method: public java.lang.String java.lang.Object.toString()
Nov 08, 2015 12:29:02 UTC Public Method: public native int java.lang.Object.hashCode()
Nov 08, 2015 12:29:02 UTC Public Method: public final native java.lang.Class java.lang.Object.getClass()
Nov 08, 2015 12:29:02 UTC Public Method: public final native void java.lang.Object.notify()
Nov 08, 2015 12:29:02 UTC Public Method: public final native void java.lang.Object.notifyAll()
Nov 08, 2015 12:29:02 UTC Completed cloupia script PrintJavaMethods
Nov 08, 2015 12:29:02 UTC Task #1 (PrintJavaMethods (ExecuteCloupiaScript)) completed successfully in 3 seconds
Nov 08, 2015 12:29:02 UTC Input/Output values for Task #1 (PrintJavaMethods (ExecuteCloupiaScript)):
Nov 08, 2015 12:29:02 UTC [Local Input: Label = PrintJavaMethods]
Nov 08, 2015 12:29:02 UTC [Local Input: Script = importPackage(java.lang.reflect); importPackage(java.io); importPackage(com.cloupia.service.cIM.inframgr); var javamethodname = [ ctxt.getInput('JavaMethodName') ]; function main() { if (javamethodname == '1') { var t = new VDCUtil(); logger.addWarning('javamethodname (VDCUtil): ' + javamethodname); } if (javamethodname == '2') { var t = new InfraPersistenceUtil(); logger.addWarning('javamethodname (InfraPersistenceUtil): ' + javamethodname); } var tClass = t.getClass(); var methods = tClass.getMethods(); for (var i = 0; i < methods.length; i++) { logger.addWarning('Public Method: ' + methods[i]); } } main(); ]
The InfraPersistenceUtil:
Service Request ID: 5738
Workflow Inputs:
- JavaMethodName
Nov 08, 2015 12:29:19 UTC Request submitted
Nov 08, 2015 12:29:20 UTC Executing workflow item number 1
Nov 08, 2015 12:29:20 UTC Completed workflow item number 0, with status Completed
Nov 08, 2015 12:29:24 UTC Executing workflow item number 2
Nov 08, 2015 12:29:24 UTC Trigger context executeWorkFlowStep called
Nov 08, 2015 12:29:24 UTC Executing custom action PrintJavaMethods (ExecuteCloupiaScript)
Nov 08, 2015 12:29:26 UTC Executing cloupia script: PrintJavaMethods
Nov 08, 2015 12:29:27 UTC javamethodname (InfraPersistenceUtil): 2
Nov 08, 2015 12:29:27 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.deleteData(java.lang.String,java.lang.Class) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cID.cIdAccess.ProductAccess[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getProductAccess(java.lang.String,boolean) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cID.cIdAccess.ProductAccess[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getProductAccess(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.VMWareCluster com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getCluster(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static java.lang.String com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getPassword(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.Account[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllCloudAccounts() throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.AccountStatus[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllAccountsStatus() throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.addAccount(com.cloupia.model.cIM.Account,boolean) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.addAccount(com.cloupia.model.cIM.Account) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.addAccount(com.cloupia.model.cIM.HostAccountDetails) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.addAccount(com.cloupia.model.cIM.HostAccountDetails,boolean) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.updateAccount(com.cloupia.model.cIM.Account) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.updateAccount(com.cloupia.model.cIM.HostAccountDetails) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.deleteAccount(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAccounts(int,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.Account[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAccounts(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.Account com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAccount(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.Account[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllAccounts() throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.AccountStatus com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAccountStatus(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.registerController(java.lang.String)
Nov 08, 2015 12:29:27 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.resetAPIKey(java.lang.String,boolean) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static int com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.addServiceRequest(com.cloupia.model.cIM.ServiceRequest) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.deleteServiceRequest(int) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getCatalogItemListByGrpId(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getScheduledVMActionByStatus(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static int com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAccountType(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.GenericVM com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMById(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllVMActionStatusByVmId(int) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllVMActionStatus() throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllVMActionStatusByAccount(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.ContextActionStatus com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMActionStatusById(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.Image[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllImageByAccount(java.lang.String)
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.ServiceRequest com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getServiceRequest(int) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.VMWareVMSummary com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMWareVMSummary(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getDataCenterList() throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMWareVMSummaryByResourcePool(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.GenericVM com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getActiveGenericVMByAccountAndName(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.modifyGenericVM(com.cloupia.model.cIM.GenericVM) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.modifyVMWareVMSummary(com.cloupia.model.cIM.VMWareVMSummary) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.archiveVM(java.lang.String,java.lang.String)
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.VMWareDatacenter com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getDatacenter(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static java.lang.String com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getImageLocation(java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getApprovers() throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.CostModel com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getCostModel(int) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.CostModel com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getCostModel(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static java.util.Collection com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getDatastores(com.cloupia.model.cIM.VMWareHost[])
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.ResourcePoolInfo com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getResourcePool(com.cloupia.model.cIM.ResourcePoolIdentity) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.ResourcePoolInfo com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getResourcePool(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.ResourcePoolInfo com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getResourcePool(com.cloupia.model.cIM.ResourcePoolDetailedIdentity) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.VMwareFolder com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getFolder(com.cloupia.model.cIM.VMwareFolderIdentity) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cID.cIdAccess.LoginProfile com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getLoginProfile(java.lang.String,boolean) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cID.cIdAccess.LoginProfile com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getLoginProfile(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistObject(java.lang.Class,java.lang.Object) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMwareScsiLuns(com.cloupia.model.cIM.DataStoreInfo)
Nov 08, 2015 12:29:27 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMwareScsiLuns(java.lang.String)
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.lib.cIaaS.network.model.DeviceStatus com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getDeviceStatus(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getStorageAssignmentsByEntityType(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getStorageAssignmentsByEntityType(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static java.lang.String com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getPolicyName(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getResourcePools(java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getResourcePools(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cID.cIdAccess.LoginProfile com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getLoginUser(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.PortGroup com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getPortGroup(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.PortGroup com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getPortGroup(java.lang.String,java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.VMStorageProfile com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getStorageProfile(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.Image com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getImage(java.lang.String,java.lang.String)
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.Image com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getImage(java.lang.String)
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.TagBasedCostModel com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getTagBasedCostModel(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.TagBasedCostModel com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getTagBasedCostModel(int) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.GenericVM com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMByUniqueId(java.lang.String,java.lang.String)
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.HyperVVMSummary com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getHyperVVMSummary(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.RackSpaceVMSummary com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getRackSpaceVMSummary(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.Tier3VMSummary com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getTier3VMSummary(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.AmazonDeploymentProfile com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAmazonDeploymentProfile(int) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.AmazonDeploymentProfile com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAmazonDeploymentProfile(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.RackspaceDeploymentProfile com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getRackspaceDeploymentProfile(int) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.RackspaceDeploymentProfile com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getRackspaceDeploymentProfile(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.RhevCloudDeploymentProfile com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getKvmDeploymentProfile(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.RhevCloudDeploymentProfile com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getKvmDeploymentProfile(int) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.Tier3DeploymentProfile com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getTier3DeploymentProfile(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.Tier3DeploymentProfile com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getTier3DeploymentProfile(int) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.updateVMActionStatus(com.cloupia.model.cIM.ContextActionStatus) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.VMWareCluster[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllVMwareClusters() throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persisteVMWareClusters(java.lang.String,com.cloupia.model.cIM.VMWareCluster[]) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persisteVMWareDatacenters(java.lang.String,com.cloupia.model.cIM.VMWareDatacenter[]) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.VMWareHost[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllVMWareHosts() throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.VMWareHost[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllVMWareHosts(boolean) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistVMWareHosts(java.lang.String,com.cloupia.model.cIM.VMWareHost[]) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistVMWareHosts(java.lang.String,com.cloupia.model.cIM.VMWareHost[],java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistVMWareHostDatastores(com.cloupia.model.cIM.VMWareHost[]) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistVMWareScsiLuns(com.cloupia.model.cIM.VMWareHost[]) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistVMWareScsiLuns(com.cloupia.model.cIM.DataStoreInfo[]) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistVMwareStorageAdapterLunMap(com.cloupia.model.cIM.VMWareHost[]) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistVMwareStorageAdapterLunMap(com.cloupia.model.cIM.DataStoreInfo[]) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistVMWareHostStorageAdapter(com.cloupia.model.cIM.VMWareHost[]) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistResourcePools(java.lang.String,com.cloupia.model.cIM.ResourcePoolInfo[]) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistResourcePools(java.lang.String,java.lang.String,com.cloupia.model.cIM.ResourcePoolInfo[]) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistHostNetworkData(java.lang.String,com.cloupia.model.cIM.VMWareHostNetworkData[]) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistHostNetworkData(java.lang.String,com.cloupia.model.cIM.VMWareHostNetworkData[],java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistNetworkVSwitchs(java.lang.String,com.cloupia.model.cIM.VMWareHostNetworkData[],java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistNetworkVSwitchs(java.lang.String,com.cloupia.model.cIM.VMWareHostNetworkData[]) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistNetworkPortGroups(java.lang.String,com.cloupia.model.cIM.VMWareHostNetworkData[]) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistNetworkPortGroups(java.lang.String,com.cloupia.model.cIM.VMWareHostNetworkData[],java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistNetworkVmkNics(java.lang.String,com.cloupia.model.cIM.VMWareHostNetworkData[],java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistNetworkVmkNics(java.lang.String,com.cloupia.model.cIM.VMWareHostNetworkData[]) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllVMVNics() throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistVMwareVMVnicData(java.lang.String,java.lang.String,java.util.List) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistVMwareVMVnicData(java.lang.String,com.cloupia.model.cIM.VMVNic[]) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistVMwareVMVnicData(java.lang.String,java.lang.String,com.cloupia.model.cIM.VMVNic[]) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistVMwareVMDiskData(java.lang.String,com.cloupia.model.cIM.VMDisk[]) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistVMwareVMDiskData(java.lang.String,java.lang.String,com.cloupia.model.cIM.VMDisk[]) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllDVSwitchs() throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistDVSwitchs(java.lang.String,com.cloupia.model.cIM.DVSwitch[]) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistDVSwitchs(java.lang.String,com.cloupia.model.cIM.DVSwitch[],java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistDVPortgroups(java.lang.String,com.cloupia.model.cIM.DVPortgroup[]) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistDVPortgroups(java.lang.String,com.cloupia.model.cIM.DVPortgroup[],java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.VMWareSnapshotInfo[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllVMwareSnapshotsByAccount(java.lang.String)
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.VMWareSnapshotInfo[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllVMwareSnapshotsByAccount(java.lang.String,java.lang.String)
Nov 08, 2015 12:29:27 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistPhysicalNICs(java.lang.String,com.cloupia.model.cIM.HostNodePhysicalNIC[]) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistPhysicalNICs(java.lang.String,com.cloupia.model.cIM.HostNodePhysicalNIC[],java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistVCenterLicenses(java.lang.String,com.cloupia.model.cIM.VCenterLicenseInfo[]) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistESXLicenses(java.lang.String,com.cloupia.model.cIM.ESXLicenseInfo[]) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistVCenterPlugins(java.lang.String,com.cloupia.model.cIM.VCenterPluginInfo[]) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistESXFeatures(java.lang.String,com.cloupia.model.cIM.ESXFeatureInfo[]) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persisteAmazonVolumes(java.lang.String,com.cloupia.model.cIM.AmazonVolume[])
Nov 08, 2015 12:29:27 UTC Public Method: public static int com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.archiveAmazonVolumes(java.lang.String,long)
Nov 08, 2015 12:29:27 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistAmazonSnapshots(java.lang.String,com.cloupia.model.cIM.AmazonSnapshot[])
Nov 08, 2015 12:29:27 UTC Public Method: public static int com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.archiveAmazonSnapshots(java.lang.String,long)
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.Image[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllImages()
Nov 08, 2015 12:29:27 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persisteImages(java.lang.String,com.cloupia.model.cIM.Image[])
Nov 08, 2015 12:29:27 UTC Public Method: public static int com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.archiveImages(java.lang.String,long)
Nov 08, 2015 12:29:27 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.insertCandidatVM(com.cloupia.service.cIM.inframgr.CandidateVM) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.VDCCatalogItem com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getCatalogItemfromWorkflowObject(com.cloupia.model.cIM.ServiceRequest) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.service.cIM.inframgr.CandidateVM com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getCandidateVMWithSRIDandProvInstId(int,java.lang.String)
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.service.cIM.inframgr.CandidateVM com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getCandidateVM(java.lang.String,java.lang.String,java.lang.String)
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.service.cIM.inframgr.CandidateVM com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getCandidateVM(int,java.lang.String)
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.service.cIM.inframgr.CandidateVM com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getCandidateVM(int)
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.service.cIM.inframgr.CandidateVM com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getCandidateVM(java.lang.String)
Nov 08, 2015 12:29:27 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.deleteTemporarySrResources(int) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static int com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.archive(java.lang.String,long)
Nov 08, 2015 12:29:27 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getSpotHistoricalData(com.cloupia.model.cIM.ReportContext,java.lang.String,long,long) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAvgStorageUsageForGroup(java.lang.String,int,java.util.Calendar,java.util.Calendar) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.fw.remoting.common.RemoteTaskRunInfo com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getLatestTaskInfo(java.lang.String)
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.service.cIM.inframgr.ClusterSummary com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMWareClusterSummary(java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.service.cIM.inframgr.ClusterSummary com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMWareClusterSummary(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.service.cIM.inframgr.ClusterSummary com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getHyperVClusterSummary(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static int com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getActiveVMCountForAccountAndHostNode(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static int com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMCountForAccountAndHostNode(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.service.cIM.inframgr.ClusterSummary com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getRhKvmClusterSummary(java.lang.String,com.cloupia.lib.cIaaS.rhev.model.RhevCluster) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.CloudSummary com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getCloudSummaryForOneCloud(com.cloupia.model.cIM.Account) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVDCSummaryListForGroup(int) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.AmazonStorageSummary com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAmazonStorageSummaryByAccount(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.HostNodeStatusSummary[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getHostNodeStatusSummaryByAccount(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static java.util.Map com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getGenericFieldToFieldMap(java.lang.Class,java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static java.util.Map com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getGenericIdToNameMap(java.lang.Class,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static java.util.Map com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getGenericIdToNameMap(java.lang.Class,java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.doesAmazonDeploymentPolicyExist(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.doesRackspaceDeploymentPolicyExist(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.doesTier3DeploymentPolicyExist(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.doesKvmCloudDeploymentPolicyExist(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.doesKvmCloudComputingPolicyExist(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.doesPrivateSystemPolicyExist(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.doesPrivateCloudComputingPolicyExist(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.doesPrivateCloudComputingPolicyExist(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.doesPrivateCloudStoragePolicyExist(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.doesPrivateCloudStoragePolicyExist(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.HyperVCloudNetworkPolicy com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getHyperVNetworkPolicy(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.HyperVCloudNetworkPolicy com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getHyperVNetworkPolicy(int) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.doesHyperVCloudComputingPolicyExist(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.doesHyperVCloudNetworkPolicyExist(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.doesHyperVDeploymentPolicyExist(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.doesHyperVCloudStoragePolicyExist(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.isValidApprover(java.lang.String)
Nov 08, 2015 12:29:27 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.doesSLAPolicyExist(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllPrivateCloudStaticIPPoolPolicy() throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.PrivateCloudStoragePolicy com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getPrivateCloudStoragePolicy(int) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.PrivateCloudStoragePolicy com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getPrivateCloudStoragePolicy(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getDataStoreNamesByCloud(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.HyperVCloudStoragePolicy com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getHyperVStoragePolicy(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.HyperVCloudStoragePolicy com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getHyperVStoragePolicy(int) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getPortGroupsByAccount(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getDVPortGroupsByAccount(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.PrivateCloudSystemProfile com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getPrivateCloudSystemProfile(int) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.PrivateCloudSystemProfile com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getPrivateCloudSystemProfile(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.HyperVDeploymentProfile com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getHyperVDeploymentProfile(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.RhevCloudComputingPolicy com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getKvmComputingPolicy(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.RhevCloudComputingPolicy com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getKvmComputingPolicy(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.RhevCloudComputingPolicy com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getKvmComputingPolicy(int) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.RhevCloudStoragePolicy com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getRhevStoragePolicyByName(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.RhevCloudNetworkPolicy com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getRhevNetworkPolicyByName(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static java.util.Map com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMsByAccountMap(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static int com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.addVMActionRequest(com.cloupia.model.cIM.VMActionRequest) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVCenterPluginByCloudNameAndProdKey(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static java.lang.String com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getErrMsgs(java.util.Map)
Nov 08, 2015 12:29:27 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getTaskRunInfoByTime(java.lang.String,long,long)
Nov 08, 2015 12:29:27 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAgentTaskInfo(java.lang.String)
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.service.cIM.inframgr.SystemStateEntry com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getSystemStateProperty(java.lang.String)
Nov 08, 2015 12:29:27 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getUsers() throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.updateUserPassword(java.lang.String,boolean) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.deleteSystemStateProperty(java.lang.String)
Nov 08, 2015 12:29:27 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllSystemStateEntries() throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllSystemStateEntriesByAccName(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllSystemStateEntriesByAccName(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.updateSystemStateProperty(java.lang.String,java.lang.String,long,long,long,boolean)
Nov 08, 2015 12:29:27 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.updateSystemStateProperty(java.lang.String,java.lang.String,long)
Nov 08, 2015 12:29:27 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.updateSystemStateProperty(com.cloupia.service.cIM.inframgr.SystemStateEntry)
Nov 08, 2015 12:29:27 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.updateSystemStateProperty(java.lang.String,java.lang.String)
Nov 08, 2015 12:29:27 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistHistoricalData(java.util.List) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.HostNodeStatusSummary[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getHyperVHostNodeStatusSummaryByAccount(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.HostNodeStatusSummary com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getHostNodeStatusSummaryByAccountAndHostNode(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getCapacityMgmtHistoricalDataJDBC(com.cloupia.model.cIM.ReportContext,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static int com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.purgeEvents(long) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static int com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.purgeBackendReports(long) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.fw.remoting.common.RemoteTaskRunInfo com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getTaskRunInfo(long,java.lang.String)
Nov 08, 2015 12:29:27 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getTaskRunInfo(java.lang.String)
Nov 08, 2015 12:29:27 UTC Public Method: public static java.lang.Object com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getDataByName(java.lang.String,java.lang.Class) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.addData(java.lang.Object,java.lang.Class) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static java.lang.Object com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getDataByQuery(java.lang.String,java.lang.Class) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.addDataCenter(com.cloupia.model.cIM.DataCenter) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.ServiceNodePool com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getServiceNodePool(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.addServiceNodePool(com.cloupia.model.cIM.ServiceNodePool) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.addSystemTaskPolicy(com.cloupia.model.cIM.SystemTaskPolicy) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistCostModel(com.cloupia.service.cIM.inframgr.profiles.CostModel) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static java.lang.Object com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getObjectByPolicyName(java.lang.Class,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.PrivateCloudComputingPolicy com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getPrivateCloudComputingPolicy(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.PrivateCloudComputingPolicy com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getPrivateCloudComputingPolicy(int) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistPrivateCloudComputingPolicy(com.cloupia.service.cIM.inframgr.profiles.PrivateCloudComputingPolicy) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistPrivateCloudStoragePolicy(com.cloupia.service.cIM.inframgr.profiles.PrivateCloudStoragePolicy) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistPrivateCloudNetworkPolicy(com.cloupia.service.cIM.inframgr.profiles.PrivateCloudNetworkPolicy) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.VMwareStorageSummary com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMwareStorageSummaryByAccount(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.VMwareStorageSummary com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMwareStorageSummaryForAllVMwareAccounts() throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static java.lang.String com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.listToString(java.util.List,java.lang.String)
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.VMUserData com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMDataById(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.GenericVM com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMByAccountAndId(java.lang.String,long) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static java.util.Collection com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllDatastoresByDataStoreName(java.lang.String,java.lang.String)
Nov 08, 2015 12:29:27 UTC Public Method: public static java.util.Collection com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllDatastoresForAccount(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllVMWareHostNames() throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMwareDiskGroupNames(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.DataStoreInfo[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getRhevDatastoresByAccount(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.DataStoreInfo[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMWareVSANDatastoresByAccount(java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMWareDatastoreISOImagesInfoByAccount(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getDataStoreListByCloudDatastoreURLAndVmDc(java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllHypervDatastoresByAccountAndHost(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.DataStoreInfo[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getHypervDatastoresByAccountAndHost(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.DataStoreInfo[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMWareDatastoresForAllAccounts(boolean,boolean) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.DataStoreInfo[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMWareDataStoresByAccountAndVMwaredatacenter(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.VMWareHost[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVSANHosts(java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.VSANDiskGroup[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVSANDiskGroup(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.VSANDiskGroup[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVSANDiskGroupByDatacenterName(java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.VSANDiskGroup[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVSANDiskGroupByHost(java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.VSANDiskGroup[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVSANDisksToDiskGroupByClusterAccountandHost(java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.VSANDiskGroup[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVSANDisksByClusterAccountHostandDiskGroup(java.lang.String,java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.VSANDiskGroup[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVSANEligibleDisks() throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.VSANDiskGroup com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVSANDiskGroupByClusterAccountandDiskGroupName(java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.VSANLicenseInfo[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVSANLicenseInfo(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.VMWareHost[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMWareHostsWithDatastoresByAccount(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.VMWareHost[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMWareNonClusterHostsByAccount(java.lang.String,boolean) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.populateVMwareScsiLuns(java.util.List)
Nov 08, 2015 12:29:27 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.populateVMwareStorageAdapterLunMap(java.util.List)
Nov 08, 2015 12:29:27 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMWareHosts() throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.VMWareHost[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMWareHosts(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMWareHostStorageAdapters() throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMWareHostsByCloud(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.VMWareHost[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMWareHostsByCluster(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.VMWareHost[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMWareHostsByClusterandDatacenter(java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.VMWareHost[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMWareHostsByDatacenter(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.validateHostName(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.validateHyperVHostName(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.validateHyperVCluster(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.validateClusterScope(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.validateCloudName(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.validateHyperVCloudName(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.validateRhevCloudName(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.HyperVHost[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getHyperVHostsByCluster(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.VMWareHost[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMWareHostsByAccountAndHostNodeWithoutDS(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.VMWareHost[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getSimpleVMWareHostsByAccountAndHostNode(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static java.util.Map com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMWareHostMap() throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static java.util.Map com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMWareHostMap(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static java.util.Map com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMWareHostMap(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static java.util.Map com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMWareHostMapByCluster(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.GenericVM[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllActiveVMs() throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllActiveVMsByAccount(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.GenericVM[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllVMs()
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.GenericVM[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllVMwareVMs()
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.GenericVM[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllUnArchivedHyperVVMs()
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.GenericVM[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMsByVMType(java.lang.String)
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.GenericVM[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllArchivedVMs()
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.Account[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllHostAccounts() throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getHostAccountDetails(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.deleteVirtualSANManagedClusters(java.lang.String)
Nov 08, 2015 12:29:27 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.deleteVirtualSANManagedCluster(java.lang.String,java.lang.String,java.lang.String)
Nov 08, 2015 12:29:27 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.deleteDataCollectionPolicy(java.lang.String)
Nov 08, 2015 12:29:27 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.deleteHostDetailAccount(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.deleteHostDetailAccount(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.archiveHyperVHosts(java.lang.String)
Nov 08, 2015 12:29:27 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.archiveHyperVHost(java.lang.String,java.lang.String)
Nov 08, 2015 12:29:27 UTC Public Method: public static java.lang.String com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAccountNameByDataStore(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.DataStoreInfo com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getDataStoreInfoByDataStoreName(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.Account com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAccountByIP(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.Account com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAccountByIP(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.Account com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMwareAccountByIPAndDC(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.HostAccountDetails com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.gethostAccountDetails(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.CloudKeyEntry com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAmazonKey(java.lang.String,int) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static java.lang.String[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAccountAndId(java.lang.String)
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.Account[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllNonHostAccounts() throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllVCenterPlugins() throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.isVSCPlugin(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.isKvmCloud(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.FormLOVPair[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.createCloudTypesLOV()
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.FormLOVPair[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAccountsByTypeLov(java.lang.String)
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.VMStorageProfile[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllVMWareStorageProfile() throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.VMStorageProfile[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMStorageProfilesByCloud(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.Account[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllVMWareAccountsByDC(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.Account[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllVMWareAndHypervAccounts() throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.Account[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllHypervAccounts() throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.FormLOVPair[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVmwareAccountsLov() throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.Account[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllHyperVAccounts() throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.Account[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllHyperVAccountsByPSAgentIP(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.lib.connector.account.PhysicalInfraAccount[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllRhevAccounts() throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.Account[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllVCloudAccounts() throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.Account[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllXenDesktopAccounts() throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.Account[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllNonXenDesktopAccounts() throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persisteHyperVCluster(com.cloupia.model.cIM.HyperVCluster[]) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.VMWareCluster[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getClustersByAccount(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMwareClustersByAccount(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMwareDatacentersByAccount(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.VMWareDatacenter[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllVMwareDatacenters() throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.VMWareCluster com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getClusterByAccountDCandName(java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.VMWareHostProfile[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getHostProfilesByAccount(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getDatastoreClusterByAccount(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllDatastoreClusters() throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.VMWareDatastoreCluster com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getDatastoreClusterByAccountAndName(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.VMWareHostProfile com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getHostProfileByAccountAndName(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.VMWareHostProfile com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getHostProfileByAccountAndHost(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getHostProfileUserInputsByProfielAndHostName(java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.VMWareHostProfileUserInputs com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getHostProfileUserInputsByProfielAndHostNameAndInputID(java.lang.String,java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.modifyHostProfileUserInput(com.cloupia.model.cIM.VMWareHostProfileUserInputs) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.VMWareDatacenter[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getDatacentersByAccount(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.HyperVCluster[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getHyperVClustersByAccount(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static java.util.HashSet com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllAccountNameSet() throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static java.util.Map com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllAccountNameMap() throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.filteClustersForValidAccounts(java.util.List) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.VMWareCluster[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllClusters() throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.VMWareCluster[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllClustersByAccountName(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.HyperVCluster[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllHyperVClusters() throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.VMWareHostProfile[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllHostProfiles() throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistHyperVHostDatastores(com.cloupia.model.cIM.HyperVHost[]) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.VMWareHost com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMWareHost(int) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.VMWareHost com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMWareHostByName(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.HyperVHost com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getHyperVHost(int) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.HyperVHost com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getHyperVHost(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllVMPaths() throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.GenericVM com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getGenericVMByAccountAndName(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.GenericVM com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getGenericVMByVMId(int) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getActiveVCloudVMsByAccount(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.GenericVM[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMByIds(java.lang.String[]) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMByAccount(java.lang.String,boolean) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static java.lang.String[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMIds(java.lang.String,boolean,boolean) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static java.lang.String[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getArchivedVMIds(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.archiveHypervVM(java.lang.String,java.lang.String)
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.GenericVM[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMsByAccount(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.GenericVM[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getArchivedVMsByAccount(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.isArchivedVM(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getArchivedVMsByVDC(int) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.GenericVM[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMsByCluster(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.GenericVM[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMsByDatacenter(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.GenericVM[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMsByAccountAndHostNode(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.VMWareVMSummary[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMWareVMsByAccountAndHostNode(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.HyperVVMSummary[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getHyperVVMsByAccountAndHostNode(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.GenericVM[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getArchivedVMsByAccountAndHostNode(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static int com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMsCountByAccountAndHostNode(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static int com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getActiveVMsCountByAccountAndHostNode(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.GenericVM[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getActiveVMsByAccountAndHostNode(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.Image com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVdiImage(java.lang.String,java.lang.String)
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.AmazonVolume com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAmazonVolume(java.lang.String,java.lang.String)
Nov 08, 2015 12:29:27 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getActiveAmazonVolumes(java.lang.String)
Nov 08, 2015 12:29:27 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getArchivedAmazonVolumes(java.lang.String)
Nov 08, 2015 12:29:27 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllAmazonVolumes(java.lang.String)
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.AmazonSnapshot com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAmazonSnapshot(java.lang.String,java.lang.String)
Nov 08, 2015 12:29:27 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getActiveAmazonSnapshots(java.lang.String)
Nov 08, 2015 12:29:27 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAmazonSecurityGroups(java.lang.String)
Nov 08, 2015 12:29:27 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAmazonVpcs(java.lang.String)
Nov 08, 2015 12:29:27 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAmazonSubnets(java.lang.String)
Nov 08, 2015 12:29:27 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAmazonVpnConnections(java.lang.String)
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.Image com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllDedicatedXenDesktopImages(java.lang.String,java.lang.String)
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.Image[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllDedicatedXenDesktopImages(java.lang.String)
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.Image[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllImagesByAccount(java.lang.String,boolean)
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.Image[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllVMwareImages()
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.Image com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getPerImages(java.lang.String)
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.VMWareSnapshotInfo com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMwareSnapshotsById(int)
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.VMWareSnapshotInfo com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMwareSnapshotsByName(java.lang.String,java.lang.String,java.lang.String,java.lang.String)
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.GenericVM com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMUniqueIdByVMId(int)
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.VMWareSnapshotInfo[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllVMwareSnapshotsByVMId(java.lang.String,java.lang.String)
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.VMWareSnapshotInfo[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllVMwareSnapshotsByVM(java.lang.String,java.lang.String)
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.VMWareSnapshotInfo[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllVMwareSnapshotsByAccounandDatacenter(java.lang.String,java.lang.String)
Nov 08, 2015 12:29:27 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.deleteAllVMwareSnapshotsByAccount(java.lang.String)
Nov 08, 2015 12:29:27 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.deleteAllVMwareSnapshotsByAccountandDatacenter(java.lang.String,java.lang.String)
Nov 08, 2015 12:29:27 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.deleteAllVMwareSnapshotsByVM(java.lang.String,java.lang.String)
Nov 08, 2015 12:29:27 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.deleteAllVMwareSnapshotsByVMDatacenterName(java.lang.String,java.lang.String,java.lang.String)
Nov 08, 2015 12:29:27 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.updateVMwareSnapshot(com.cloupia.model.cIM.VMWareSnapshotInfo) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistAmazonEC2Volume(java.lang.String,com.cloupia.model.cIM.AmazonVolume)
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.ContextActionStatus com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistContextActionStatus(java.lang.String,java.lang.String,java.lang.String,java.lang.String,int,int,java.lang.String,java.lang.String,int) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getRackSpaceFlavorList() throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getRackSpaceVMSummaryForCloud(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getTier3VMSummaryForCloud(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static java.util.Map com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getCatalogItemsAsMap() throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getCatalogItemList() throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.CatalogItem com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getCatalogItem(int) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.CatalogItem com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getCatalogItemByName(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.CatalogItem com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getCatalogItemByDeployPolicy(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.CatalogItem com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getCatalogItemByDRAP(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistCatalogItem(com.cloupia.model.cIM.CatalogItem) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.modifyCatalogItem(com.cloupia.model.cIM.CatalogItem) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.deleteCatalogItem(int) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.ServiceRequest[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllServiceRequests() throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.ServiceRequest[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllUnArchivedServiceRequests() throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.ServiceRequest[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllArchivedServiceRequests() throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static java.util.Map com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllServiceRequestsAsMap() throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.ServiceRequest[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllServiceRequestsByGroup(int) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.ServiceRequest[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllUnArchivedServiceRequestsByGroup(int) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.ServiceRequest[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllArchivedServiceRequestsByGroup(int) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.ServiceRequest[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllServiceRequestsByDuration(long,long) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static com.cloupia.model.cIM.ServiceRequest[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getServiceRequestsByGroupAndDuration(int,long,long) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static int com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.modifyServiceRequest(com.cloupia.model.cIM.ServiceRequest) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static int com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.modifyServiceRequestSRID(com.cloupia.model.cIM.ServiceRequest,int) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.modifyCostModel(com.cloupia.service.cIM.inframgr.profiles.CostModel) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.deleteCostModel(int) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllCostModel() throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllTagBasedCostModel() throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistTagBasedCostModel(com.cloupia.service.cIM.inframgr.profiles.TagBasedCostModel) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.modifyTagBasedCostModel(com.cloupia.service.cIM.inframgr.profiles.TagBasedCostModel) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.deleteTagBasedCostModel(int) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistRackspaceDeploymentProfile(com.cloupia.service.cIM.inframgr.profiles.RackspaceDeploymentProfile) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.modifyRackspaceDeploymentProfile(com.cloupia.service.cIM.inframgr.profiles.RackspaceDeploymentProfile) throws java.lang.Exception
Nov 08, 2015 12:29:27 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.deleteRackspaceDeploymentPolicy(int) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllRackspaceDeploymentProfile() throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getRackspaceDeployPolicies() throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistAmazonDeploymentProfile(com.cloupia.service.cIM.inframgr.profiles.AmazonDeploymentProfile) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.modifyAmazonDeploymentProfile(com.cloupia.service.cIM.inframgr.profiles.AmazonDeploymentProfile) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.deleteAmazonDeploymentPolicy(int) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllAmazonDeploymentProfile() throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAmazonDeployPolicies() throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistKvmDeploymentProfile(com.cloupia.service.cIM.inframgr.profiles.RhevCloudDeploymentProfile) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.modifyKvmDeploymentProfile(com.cloupia.service.cIM.inframgr.profiles.RhevCloudDeploymentProfile) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.deleteKvmDeploymentPolicy(int) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllKvmDeploymentProfile() throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllHypervStorageDisks() throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllHostVolumes()
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllHypervStorageFileShares() throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getKvmCloudDeploymentProfileByCloud(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getKvmDeployPolicies() throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistKvmComputingPolicy(com.cloupia.service.cIM.inframgr.profiles.RhevCloudComputingPolicy) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.modifyKvmComputingPolicy(com.cloupia.service.cIM.inframgr.profiles.RhevCloudComputingPolicy) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.deleteKvmComputingPolicy(int) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllKvmComputingPolicies() throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getKvmCloudComputingPolicyByCloud(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getKvmComputingPolicies() throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistXenDesktopComputingPolicy(com.cloupia.service.cIM.inframgr.profiles.XenDesktopComputingPolicy) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.modifyXenDesktopComputingPolicy(com.cloupia.service.cIM.inframgr.profiles.XenDesktopComputingPolicy) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.deleteXenDesktopComputingPolicy(int) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.XenDesktopComputingPolicy com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getXenDesktopComputingPolicy(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.XenDesktopComputingPolicy com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getXenDesktopComputingPolicy(int) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllXenDesktopComputingPolicies() throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getXenDesktopCloudComputingPolicyByCloud(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getXenDesktopComputingPolicies() throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.model.cIM.CatalogItem com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getCatlogItemByPolicyId(int,int,boolean) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMWareDeployPolicies() throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getHyperVDeployPolicies() throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistVMWareDeploymentProfile(com.cloupia.service.cIM.inframgr.profiles.VMWareDeploymentProfile) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistHyperVDeploymentProfile(com.cloupia.service.cIM.inframgr.profiles.HyperVDeploymentProfile) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistVCloudDeploymentProfile(com.cloupia.service.cIM.inframgr.profiles.VCloudExpDeploymentProfile) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.deleteVMWareDeploymentProfile(int) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.deleteHyperVDeploymentProfile(int) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.VMWareDeploymentProfile com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMWareDeploymentProfile(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.VMWareDeploymentProfile com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMWareDeploymentProfile(int) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.HyperVDeploymentProfile com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getHyperDeploymentProfile(int) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllVMWareDeploymentProfile() throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllHyperVDeploymentProfile() throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistDRAPProfile(com.cloupia.service.cIM.inframgr.profiles.DynamicResourceAllocationPolicy) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.deleteDRAPProfile(int) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.DynamicResourceAllocationPolicy com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getDRAPProfile(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.DynamicResourceAllocationPolicy com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getDRAPProfile(int) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getDRAPProfileByCloud(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllDRAPProfile() throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.modifyPrivateCloudComputingPolicy(com.cloupia.service.cIM.inframgr.profiles.PrivateCloudComputingPolicy) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.deletePrivateCloudComputingPolicy(int) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getPrivateCloudComputingPolicyByCloud(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllPrivateCloudComputingPolicy() throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.modifyPrivateCloudStoragePolicy(com.cloupia.service.cIM.inframgr.profiles.PrivateCloudStoragePolicy) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.deletePrivateCloudStoragePolicy(int) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getPrivateCloudStoragePolicyByCloud(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllPrivateCloudStoragePolicy() throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistPrivateCloudPortGroupToDVPortGroupMappingPolicy(com.cloupia.service.cIM.inframgr.profiles.PrivateCloudPortGroupToDVPortGroupMappingPolicy) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.modifyPrivateCloudPortGroupToDVPortGroupMappingPolicy(com.cloupia.service.cIM.inframgr.profiles.PrivateCloudPortGroupToDVPortGroupMappingPolicy) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.deletePrivateCloudPortGroupToDVPortGroupMappingPolicy(com.cloupia.service.cIM.inframgr.profiles.PrivateCloudPortGroupToDVPortGroupMappingPolicy) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.modifyPrivateCloudNetworkPolicy(com.cloupia.service.cIM.inframgr.profiles.PrivateCloudNetworkPolicy) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.deletePrivateCloudNetworkPolicy(int) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.deletePortGroupToDVPortGroupMappingPolicyEntry(int) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.PrivateCloudPortGroupToDVPortGroupMappingPolicy com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getPrivateCloudPortGroupToDVPortGroupMappingPolicy(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.PrivateCloudPortGroupToDVPortGroupMappingPolicy com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getPrivateCloudPortGroupToDVPortGroupMappingPolicy(int) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getPrivateCloudPortGroupToDVPortGroupMappingPolicyByAccount(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getPrivateCloudNetworkPolicyByCloud(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllPrivateCloudNetworkPolicy() throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllPrivateCloudPortGroupToDVPortGroupMappingPolicy() throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistPrivateCloudStaticIPPoolPolicy(com.cloupia.service.cIM.inframgr.profiles.PrivateCloudStaticIPPoolPolicy) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.modifyPrivateCloudStaticIPPoolPolicy(com.cloupia.service.cIM.inframgr.profiles.PrivateCloudStaticIPPoolPolicy) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.deletePrivateCloudStaticIPPoolPolicy(int) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getPrivateCloudStaticIPPoolPolicyByCloud(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllDataStoresMappedForISOInventoryCollection() throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllVMWareGuestOSToISOMappingPolicy() throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllIPSubnetPoolPolicy() throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllIPSubnetsInIpSubnetPoolPolicy(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllIPSubnetsReservedForGroup(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllIPSubnetsInfo() throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllParentIPSubnets() throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.checkForChild(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.IPSubnetInfo com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getIPSubnetsInIpSubnetPoolPolicy(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.IPSubnetInfo com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getIPSubnetInfoBySubnetLabel(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllIPSubnetsWithID(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistIPSubnetPoolSubnets(java.util.List) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistIPSubnetPoolSubnets(int,java.util.List) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.deleteIPSubnet(com.cloupia.service.cIM.inframgr.profiles.IPSubnetInfo) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.insertIPSubnet(com.cloupia.service.cIM.inframgr.profiles.IPSubnetInfo) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.IPSubnetInfo com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getIPSubnetInfoBySubnetLabelAndGroupId(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.IPSubnetPoolPolicy com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getIPSubnetPoolPolicy(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.IPSubnetPoolPolicy com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getIPSubnetPoolPolicy(int) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistIPSubnetPoolPolicy(com.cloupia.service.cIM.inframgr.profiles.IPSubnetPoolPolicy) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.modifyIPSubnetPoolPolicy(com.cloupia.service.cIM.inframgr.profiles.IPSubnetPoolPolicy) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.deleteIPSubnetPoolPolicy(int) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.deleteIPSubnetPoolPolicy(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.modifyIPSubnetInfo(com.cloupia.service.cIM.inframgr.profiles.IPSubnetInfo) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.deleteIPSubnetPoolPolicySubnets(int) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.deleteIPSubnetInfo(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.deleteIPSubnetInfoBySubnetId(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getSubnetsForIPSubnetPoolPolicy(int) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllChildSubnetsUnderParentId(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.isIPPSunetPoolinUse(int) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.IPSubnetInfo com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getIPSubnetInfo(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistPrivateCloudSystemProfile(com.cloupia.service.cIM.inframgr.profiles.PrivateCloudSystemProfile) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.modifyPrivateCloudSystemProfile(com.cloupia.service.cIM.inframgr.profiles.PrivateCloudSystemProfile) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.deletePrivateCloudSystemProfile(int) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllPrivateCloudSystemProfile() throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getLoginUserByAccessLevel(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.model.cID.cIdAccess.LoginProfile[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllMSPLoginUsers() throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.model.cID.cIdAccess.LoginProfilePaginated[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllFilteredInactiveUsers(boolean) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.model.cID.cIdAccess.LoginProfile[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllFilteredActiveUsers(boolean) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.model.cID.cIdAccess.LoginProfile[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllUsers() throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.model.cID.cIdAccess.LoginProfile[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllLoginProfileUsers() throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllExternalUsers() throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.model.cID.cIdAccess.LoginProfile[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllExternalUsers(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllUsersInGroup(int) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.model.cID.cIdAccess.ProductAccess[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getLDAPProductAccess(java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.model.cID.cIdAccess.Product[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllProducts() throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.model.cID.cIdAccess.LoginProfile com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getLoginProfileUser(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.lang.String com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAccessLevelByUserId(java.lang.String)
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.addUser(com.cloupia.model.cID.cIdAccess.User) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.model.cIM.Group com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.createSelfUserGroup(java.lang.String,com.cloupia.model.cID.cIdAccess.User)
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.model.cIM.Group com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.createSelfUserGroup(java.lang.String,com.cloupia.model.cID.cIdAccess.User,com.cloupia.model.cIM.Group)
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.addLDAPUser(com.cloupia.model.cID.cIdAccess.User) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.modifyUser(com.cloupia.model.cID.cIdAccess.User,boolean) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.deleteUser(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.disableUser(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistAccount(java.lang.String,com.cloupia.model.cIM.HostAccountDetails,boolean) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistAccount(java.lang.String,com.cloupia.model.cIM.Account,boolean) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.modifyPassword(com.cloupia.model.cID.cIdAccess.Password) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.modifyVMActionRequest(com.cloupia.model.cIM.VMActionRequest) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.updateDoWhileConfig(com.cloupia.feature.customactions.configs.DoWhileConfig) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.deleteVMActionRequest(int) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.model.cIM.VMActionRequest com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getScheduledVMAction(int) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getScheduledVMActions() throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getScheduledVMActionsByVDC(int) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistSLAHistoricalData(java.util.List) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistSLAHistoricalData(com.cloupia.service.cIM.inframgr.SLAHistoricalDataEntry) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistSLAProfile(com.cloupia.service.cIM.inframgr.profiles.SLAPolicy) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.modifySLAProfile(com.cloupia.service.cIM.inframgr.profiles.SLAPolicy) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.SLAPolicy com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getSLAPolicy(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.SLAPolicy com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getSLAPolicy(int) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.doesPrivateCloudNetworkPolicyExist(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.doesPrivateCloudNetworkPolicyExist(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.doesXenDesktopCloudComputingPolicyExist(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllSLAPProfile() throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.deleteSLAProfile(int) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getSLAProfileByCloud(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static int com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.purgeSLAHistoricalDataSpotSamples(long) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static int com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.purgeSLAHistoricalDataSamples(long) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.model.cIM.SystemParameters com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getSystemParemeters() throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getBudgetEntryList() throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getBudgetEntryListByGroup(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.model.cIM.BudgetEntry com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getBudgetEntry(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.model.cIM.BudgetEntry com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getBudgetEntryById(int) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getBudgetSpendingList() throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getBudgetSpendingListByGroup(int) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.model.cIM.BudgetEntry com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getBudgetEntryByDate(java.lang.String,long) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getBudgetEntrisByDate(long) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.addBudgetEntry(com.cloupia.model.cIM.BudgetEntry) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.modifyBudgetEntry(com.cloupia.model.cIM.BudgetEntry) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.deleteBudgetEntry(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.deleteBudgetEntryById(int) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getNetworkDetailData(java.util.List) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMWareHostNetworkDataByHost(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.model.cIM.VMWareHostNetworkData com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMWareHostNetworkDataByHostAndAccount(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMWareHostNetworkDataByAccount(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMwareVSwitchList() throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMwareVSwitchListbyAccountAndDatacenter(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMwareDVSwitchListForAccount(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMwareDVSwitchList() throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMwareDVPortgroupList() throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVsanPodDVPortgroupListForAccount(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVSwitchByAccount(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.validateVswitch(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.lang.String com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getMspSelfGroupList(com.cloupia.model.cIM.Group[]) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.lang.String com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getGroupList(com.cloupia.model.cIM.Group[])
Nov 08, 2015 12:29:28 UTC Public Method: public static java.lang.String com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getGroupListWithoutSelfGroup(com.cloupia.model.cIM.Group[])
Nov 08, 2015 12:29:28 UTC Public Method: public static int com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVLANIDByAccountAndHostAndPGNameAndPGType(java.lang.String,java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getPortGroupsByAccountandType(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVmkNicByAccount(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllVmkNics() throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.model.cIM.VmkNic com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVmkNicByHostAndSubnetAndVlan(java.lang.String,java.lang.String,int) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getPhysicalNIcByAccount(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getPhysicalNIcByAccountAndHostAndvSwitch(java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMVNicByAccount(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getPortGroupsByHost(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.model.cIM.PortGroup com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getPortGroupsByHostandPortGroup(java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMPortGroupsByHost(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.model.cIM.PortGroup com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMPortGroupByAccountHostAndPortGroupName(java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getDVPortGroupsByHost(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.model.cIM.DVPortgroup com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMDVPortgroupByAccountHostAndPortGroupName(java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVSwitchByAccountAndHost(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.model.cIM.VSwitch com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVSwitchByAccountAndHostandvSwitch(java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.addVSwitch(com.cloupia.model.cIM.VSwitch) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getPortGroupsByAccountAndHost(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getPortGroupsAssignedToGroup(java.lang.String)
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getDVPortgroupsAssignedToGroup(java.lang.String)
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getPortGroupsByAccountAndHostAndVSwitch(java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllPortGroupsForVMware() throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllPortGroupsForVMwareByType(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getPortGroupsByAccountAndHostAndVSwitchAndType(java.lang.String,java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getPortGroupsByAccountAndVSwitchAndType(java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getPortGroupsByAccountAndType(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getPortGroupsByAccountAndType(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getPortGroupsByVSwitchAndType(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getPortGroupsByAccountAndHostAndType(java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getDVPortGroupsByAccountAndType(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getDVPortGroupsByAccountHostAndType(java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.validateDVPortgrp(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.validatePortgrp(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllPortGroups() throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMwarePortGroupsByType() throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVmkNicByAccountAndHost(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVmkNicIPAddressesByAccountAndHost(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.model.cIM.VmkNic com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVmkNicByAccountAndHostAndPortGroupName(java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.model.cIM.VmkNic com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVmkNicByAccountAndHostAndVMKnic(java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMVNicByAccountAndVMId(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMVNicByAccountAndVMIdOrderByPortIdx(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.model.cIM.ResourcePoolInfo com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getResourcePoolByRPIdentity(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.model.cIM.ResourcePoolInfo com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getResourcePoolByAccountNameAndVMName(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistBudgetMeteringEntries(int,com.cloupia.model.cIM.BudgetMeteringEntry[]) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistBudgetSpendingEntries(com.cloupia.model.cIM.BudgetSpending[]) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistVMwareTemplateVnicData(java.lang.String,java.lang.String,com.cloupia.model.cIM.TemplateVNic[]) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistVMwareTemplateVnicData(java.lang.String,com.cloupia.model.cIM.TemplateVNic[]) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistVMwareTemplateDiskData(java.lang.String,java.lang.String,com.cloupia.model.cIM.TemplateDisk[]) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistVMwareTemplateDiskData(java.lang.String,com.cloupia.model.cIM.TemplateDisk[]) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.isAccountValid(com.cloupia.model.cIM.Account)
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.Map com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.validateCatalogItem(com.cloupia.model.cIM.VDCCatalogItem) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.HashSet com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getIpAddressesInUse(java.lang.String,boolean) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.model.cIM.GenericVM com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMByVMName(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllVMMeteringEntryList(int,int) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllActiveVMMeteringEntryByVMId(int) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllInactiveVMMeteringEntryByVMId(int) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.model.cIM.VMWareVMSummary com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMwareVMSummary(int) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.model.cIM.VMWareVMSummary com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMwareVMSummaryByUuid(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.modifyDataCenter(com.cloupia.model.cIM.DataCenter) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.deleteDataCenter(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAssignedPodList() throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAssignedPodListByAccount(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getDataCenterListBySiteId(int) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllServiceNodePools() throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllSystemTaskPolicies() throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistSystemTaskPolicy(com.cloupia.model.cIM.SystemTaskPolicy) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllClusterLeafs() throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllData(java.lang.Class) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistData(com.cloupia.model.cIM.SystemTaskPolicy) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persisteVMWareDatastores(java.lang.String,com.cloupia.model.cIM.DataStoreInfo[]) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.model.cIM.VCenterLicenseInfo[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVCenterLicenseInfoByAccount(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistVMWareHostProfiles(java.lang.String,com.cloupia.model.cIM.VMWareHostProfile[]) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.deleteVMwareHostProfile(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.deleteVMWareHostProfileUserInputs(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.model.cIM.ESXLicenseInfo[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getESXLicenseInfoByAccount(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.model.cIM.ESXLicenseInfo[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getESXLicenseInfoByAccountAndHostnode(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.model.cIM.ESXFeatureInfo[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getESXFeatureInfoByAccountAndHostnode(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.lang.String com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVmwareHostNameForHostId(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getDVSwitchByAccountAndHost(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getDVPortGroupsByAccountAndHost(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.model.cIM.DVPortgroup com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getDVPortGroupsByAccountHostAndKey(java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getDVSwitchByAccount(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getDVSwitchByAccountAndDC(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getDVSwitchsByAccountDCAndSwitchName(java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.model.cIM.DVSwitch com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getDVSwitchByAccountAndSwitchName(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getDVPortGroupsByAccountAndDVSwitch(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getDVPortGroupByDVSwitchAndType(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getDVPortGroupsByDVSwitch(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getDVPortGroupByName(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getDVPortGroupByNameAndHostName(java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVPortGroupByAccountAndName(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.addPortGroup(com.cloupia.model.cIM.PortGroup) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.updateVMPendingAction(long,boolean,java.lang.String)
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.model.cIM.VMWareSnapshotInfo[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllVMwareSnapshots()
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.model.cIM.VMWareVMSummary com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMWareVMSummaryByUniqueIdAndAccountName(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getDataStoreListByCloud(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getDataStoreListByNFSRemoteHost(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getDataStoreListByCloudAndHost(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllDataStores() throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllDataStoresForVmwareAccounts() throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.model.cIM.Account com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAccountsByNameAndType(java.lang.String,int)
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.model.cIM.Account com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAccountsByNameTypeAndDC(java.lang.String,int,java.lang.String)
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getDVPortGroupsByAccountDCAndDVSwitch(java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getDVPortGroupsByAccountHostAndDVSwitch(java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.model.cIM.DVPortgroup com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getDVPortGroupsByAccountAndName(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.model.cIM.DVPortgroup com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getDVPortGroupByIdentity(java.lang.String,java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.model.cIM.DVPortgroup com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getDVPortGroupByIdentityValue(java.lang.String,java.lang.String,java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getFabricInterconnectPortsByAcctAndPortDn(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.model.cIM.GroupBudget com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getGroupBudget(int) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllVMWareVMSummary()
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.Map com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllVMWareVMSummaryMap()
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getNexus1000vSwitches()
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getPortProfilesForNexusSwitch(java.lang.String,java.lang.String)
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getDVPortGroupsByAccountDVSwitchAndType(java.lang.String,java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getDVPortGroupsByAccountDVSwitchAndType(java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getDVPortGroupsByDVSwitchAndType(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.model.cIM.DVPortgroup com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getDVPortGroupsByAccountDVSwitchHostPortGroupNameAndType(java.lang.String,java.lang.String,java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getDVPortGroupsByAccountDVSwitchHostAndType(java.lang.String,java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.addVLANtoVLANTable(com.cloupia.service.cIM.inframgr.profiles.VLANPoolTable) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.lang.String com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVlanResourceType(java.lang.String)
Nov 08, 2015 12:29:28 UTC Public Method: public static java.lang.String com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVxlanResourceType(java.lang.String)
Nov 08, 2015 12:29:28 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.addVXLANtoVXLANTable(com.cloupia.service.cIM.inframgr.profiles.VXLANPoolTable) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.modifyVLANtoVLANTable(com.cloupia.service.cIM.inframgr.profiles.VLANPoolTable) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.modifyVXLANtoVXLANTable(com.cloupia.service.cIM.inframgr.profiles.VXLANPoolTable) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.deleteVLANfromVLANTable(int) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.deleteVXLANfromVLANTable(int) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.VLANPoolTable com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVLANPoolTableById(int) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.VLANPoolTable com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVLANPoolTableByIdandDCName(int,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.Map com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVLANPoolTableIdsByDCName(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.Map com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVXLANPoolTableIdsByDCName(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.VXLANPoolTable com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVXLANPoolTableByIdandDCName(int,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVLANsByDatacenter(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.HashMap com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMWareIpAddressesInUse(boolean) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMWareHostStorageAdapterByHostAndCloud(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMWareHostStorageAdapterByHost(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMWareHostStorageAdapterByHostAndCloudAndType(java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMwareStorageAdapterLunMapByHostAndCloud(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.model.cIM.VMwareStorageAdapterLunMap com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMwareStorageAdapterLunMapByHostAndCloud(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMwareStorageAdapterLunMapByHostNameAndCloud(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.model.cIM.VMWareDatastoreCluster com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMwareDatastoreClusterByAccountAndName(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.model.cIM.DataStoreInfo com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getDataStoreByCloudAndName(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getDataStoreListByCloudAndName(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.model.cIM.DataStoreInfo com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getDataStoreByCloudAndNFSServerAndPath(java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getDataStoresByCloudAndNFSServerAndPath(java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.model.cIM.DataStoreInfo com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getDataStoreHypervByCloudAndNFSServerAndPath(java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getDataStoreListByCloudAndDatastoreURL(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.model.cIM.DataStoreInfo com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getDataStoreInfoByIdentity(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.validateDataStore(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getNetAppNfsRuleByExportPath(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getLunDatastoreAssociationByCloudHostDatastore(java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getLunDatastoreAssociationByDatastore(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static long com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.deleteImageByAccoutnAndHost(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static long com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.deleteImageByAccountAndId(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.Map com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getNFSDatastoreVolumeAndFilerName(java.lang.String)
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.StorageIPAddressProtocolMapping com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getStorageIPAddressProtocolMapping(long) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.addStorageIPAddressProtocolMapping(com.cloupia.service.cIM.inframgr.profiles.StorageIPAddressProtocolMapping) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.modifyStorageIPAddressProtocolMapping(com.cloupia.service.cIM.inframgr.profiles.StorageIPAddressProtocolMapping) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static long com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.deleteStorageIPAddressProtocolMapping(long) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getStorageIPAddressProtocolMappingsByDCName(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getStorageIPAddressProtocolMappings() throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.updatevFilerProtocolInfoByScheme()
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getNetAppVFilerProtocolInfos(java.lang.String,boolean) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getNetAppVFilerProtocolInfos() throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.updateNetAppVfilerProtocolInfo(com.cloupia.lib.cIaaS.netapp.model.NetAppVfilerProtocolInfo,java.lang.String)
Nov 08, 2015 12:29:28 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.updateNetAppVfilerProtocolInfo(com.cloupia.lib.cIaaS.netapp.model.NetAppVfilerProtocolInfo,java.util.List)
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.isVfilerNFSProtocolEnabled(com.cloupia.lib.cIaaS.netapp.model.NetAppVfilerProtocolInfo)
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.isVfilerISCSIProtocolEnabled(com.cloupia.lib.cIaaS.netapp.model.NetAppVfilerProtocolInfo)
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getNetAppVfilerByName(java.lang.String,java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getDVPortGroupsByType(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getDVPortGroups() throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getDVPortGroupsBySwitch(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistDVSwitch(com.cloupia.model.cIM.DVSwitch) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static long com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.deleteDVSwitch(com.cloupia.model.cIM.VMWaredvSwitchIdentity) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistDVPortgroup(com.cloupia.model.cIM.DVPortgroup) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static long com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.deleteDVPortgroup(com.cloupia.model.cIM.VMWaredvPortGroupIdentity) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getResourcePoolInfoByCloudName(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getResourcePoolInfoByCloudNameAndHost(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.model.cIM.ResourcePoolInfo com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getResourcePoolInfoByCloudDcNameAndRPIdentity(java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.model.cIM.ResourcePoolInfo com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getResourcePoolInfoByCloudDcNameAndParent(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.model.cIM.ResourcePoolInfo com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getHostOrClusterResourcePoolInfo(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllDCDeviceCredentials() throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static long com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getServiceRequestList() throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static long com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllVMCount() throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getXenVMSummary() throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static long com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllActiveVMCount() throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllWindowsRemoteAgents() throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.model.cIM.WinRemoteAgent com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getWinRemoteAgent(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllWindowsControllers() throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMVNicByAccountAndVMName(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.model.cIM.VMVNic com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMNicByAccountVMnameAndvNICName(java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMNicByAccountVMnameAndPortGroupName(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVPortGroupByAccountHostAndName(java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.model.cIM.VMWareCluster[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getDRSEnabledClustersByAccountandDC(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMwareHostsByAccountandDatacenter(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMwareHostByAccountandName(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMwareClusterByAccountandName(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMwareClusterByAccountandDCName(java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVSANVMwareClusterByAccountandNameAndDatacenter(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getResourcePoolInfoByCloudNameDCAndHost(java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getResourcePoolInfoByCloudNameAndrpIdentity(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getPortGroupsByType(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.model.cIM.VMWareVMSummary com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMWareVMSummaryByAccountAndName(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.model.cIM.VMWareVMSummary com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMWareVMSummaryByAccountDatacenterAndName(java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistTier3DeploymentProfile(com.cloupia.service.cIM.inframgr.profiles.Tier3DeploymentProfile) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.modifyTier3DeploymentProfile(com.cloupia.service.cIM.inframgr.profiles.Tier3DeploymentProfile) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.deleteTier3DeploymentPolicy(int) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllTier3DeploymentProfile() throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMWareHostsByAccountAndDC(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllVMDisksConfig() throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.model.cIM.VMDisk com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMDiskConfigByDiskLabelCloudDCAndVMID(java.lang.String,java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMDiskConfigByCloudAndVMName(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMDiskConfigByCloudDCAndDatastore(java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.service.cIM.inframgr.CandidateVM com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getCandidateVMforTier3(java.lang.String,java.lang.String,java.lang.String)
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.model.cIM.HostNetworkView com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getHostNetworkViewByPnic(java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistVMwareVMVMDiskData(java.lang.String,java.lang.String,java.util.List) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.lib.cIaaS.xendesktop.model.XenADAccount com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getFirstAvailableADAccountByAccountAndIdentityPool(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.purgeDeletedVMData(com.cloupia.model.cIM.GenericVM) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.deleteEntrtiesByClass(java.lang.Class,java.lang.String,java.lang.String)
Nov 08, 2015 12:29:28 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.deleteEntrtiesByClass(java.lang.Class,java.lang.String)
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.deleteVMwareSummary(int) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistHypervComputingPolicy(com.cloupia.service.cIM.inframgr.profiles.HyperVCloudComputingPolicy) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.modifyHyperVComputingPolicy(com.cloupia.service.cIM.inframgr.profiles.HyperVCloudComputingPolicy) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.deleteHyperVComputingPolicy(int) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.HyperVCloudComputingPolicy com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getHyperVComputingPolicy(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.HyperVCloudComputingPolicy com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getHyperVComputingPolicy(int) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.lib.cIaaS.hyperv.model.HypervTemplate com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getHyperVTemplate(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getHyperVTemplateForAccount(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllHyperVComputingPolicies() throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getHyperVCloudComputingPolicyByCloud(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.HyperVCloudComputingPolicy com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getHyperVCloudComputingPolicyByName(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.HyperVCloudNetworkPolicy com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getHyperVNetworkPolicyByName(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllHyperVNetworkPolicies() throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getHyperVCloudNetworkingPolicyByCloud(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getKvmNetworkPoliciesByCloud(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistHypervNetworkingPolicy(com.cloupia.service.cIM.inframgr.profiles.HyperVCloudNetworkPolicy) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.modifyHyperVNetworkingPolicy(com.cloupia.service.cIM.inframgr.profiles.HyperVCloudNetworkPolicy) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.deleteHyperVNetworkPolicy(int) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.HyperVCloudStoragePolicy com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getHyperVStoragePolicyByName(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.RhevCloudStoragePolicy com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getRhevStoragePolicy(int) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.RhevCloudStoragePolicy com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getRhevStoragePolicy(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.RhevCloudNetworkPolicy com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getRhevNetworkPolicy(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getCatalogByCloudName(java.lang.String)
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllHyperVStoragePolicies() throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllRhevStoragePolicies() throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllRhevStoragePoliciesByCloudName(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getHyperVCloudStoragePolicyByCloud(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistHypervStoragePolicy(com.cloupia.service.cIM.inframgr.profiles.HyperVCloudStoragePolicy) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistRhevStoragePolicy(com.cloupia.service.cIM.inframgr.profiles.RhevCloudStoragePolicy) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.modifyHyperVStoragePolicy(com.cloupia.service.cIM.inframgr.profiles.HyperVCloudStoragePolicy) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.modifyRhevStoragePolicy(com.cloupia.service.cIM.inframgr.profiles.RhevCloudStoragePolicy) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.deleteHyperVStoragePolicy(int) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.deleteRhevStoragePolicy(int) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getHyperVVirtualNetworks(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getHyperVVirtualNetworksByAcctandHost(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.lib.cIaaS.hyperv.model.HypervHostVirtualNetwork com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getHyperVVirtualNetwork(java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.modifyHyperVDeploymentProfile(com.cloupia.service.cIM.inframgr.profiles.HyperVDeploymentProfile) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.model.cIM.DataStoreInfo com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getDatastoreInfoByAccountAndImageNameAndImageType(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getEMCVNXClariionSPPortsByPortType(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getNetAppFcAdapters() throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getNetAppFcAdapters(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getNetAppClusterFCPAdapters(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getNetAppClusterFCPAdapters() throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getEMCVNXClariionSPFCPorts(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.lib.cIaaS.ucs.model.UcsServer com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getServerByServiceProfileName(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.model.cIM.VMWareHost com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMWareHostByUuid(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.lang.String com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getUCSServerIPAddress(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllPhysicalNICs() throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.model.cIM.VMWareVMSummary com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMWareVMSummaryByHostandDataCenterName(java.lang.String,java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMDiskConfigByCloudDCDatastoreandVMName(java.lang.String,java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.model.cIM.VMDisk com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMDiskConfigByCloudDCDatastoreVMNameandDiskLabel(java.lang.String,java.lang.String,java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getTemplateDisksByCloudDCImageName(java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getTemplateDisksByImageName(java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.model.cIM.ImageDiskData com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getImageDiskDataByCloudDCDatastoreVMNameandDiskLabel(java.lang.String,java.lang.String,java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:28 UTC Public Method: public static com.cloupia.model.cIM.ImageDiskData com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getImageDiskDataByImageDisk(com.cloupia.model.cIM.TemplateDisk) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getImageDiskDataByImage(com.cloupia.model.cIM.Image) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.assignDiskTypetoDisk(com.cloupia.model.cIM.ImageDiskData) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMWareTemplateByAccountAndName(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getTemplateVNicByAccountAndTemplate(java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.deletePrivateCloudStorageAdditionalDisk(int) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.PrivateCloudStoragePolicyDisk com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getPrivateCloudStorageAdditionalDisk(int) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.VMDisk com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMDiskConfigByCloudDCVMNameAndVMDisk(java.lang.String,java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.GenericVM[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMwareGenericVMs(java.lang.String,java.lang.String)
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.DVSwitch com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getDVSwitchByAccountDCAndSwitchName(java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getDVSwitchByAccountName(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getTemplateVNicByAccountAndTemplateID(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.lib.cIaaS.emc.vnx.model.VNXMoverInterface com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getEMCVNXMoverInterfaceByDatastoreRemoteIP(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.lib.cIaaS.netapp.model.NetAppFiler com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getNetAppFilerByDatastoreRemoteIP(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.lib.cIaaS.netapp.model.NetAppVfiler com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getNetAppVFilerByDatastoreRemoteIP(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getNetAppVFilers() throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.lib.cIaaS.netapp.model.NetAppVfiler com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getNetAppVfilerInfoPerAccount(java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static int com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVFilerVLANID(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllSRGroupResources() throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static synchronized void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistSRGroupResources(java.util.List) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static double com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getResourceValuePerGroupandParam(int,java.lang.String)
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.PortGroup com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getPortGroupByAccountandPortGrpName(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.DVPortgroup com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getDVPortGroupByAccountandDVPortGrpName(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getUniqueDVPortGroupsByAccountAndType(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getUniqueDVPortGroupsByType(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getResourceValuePerGroup(int) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.PortGroup com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getPortGroupByIdentity(java.lang.String,java.lang.String,java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.modifyDVPortgroup(com.cloupia.model.cIM.DVPortgroup) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.modifyPortgroup(com.cloupia.model.cIM.PortGroup) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVFilerVLANIDList(java.lang.String,java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAccountConnectionStatus(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getCustomFeatureList() throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistFeatureUploadEntry(com.cloupia.model.cIM.FeatureFileUploadEntry) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getDeactivatedCustomFeatureList() throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.modifyFeatureUploadEntry(com.cloupia.model.cIM.FeatureFileUploadEntry) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.deleteFeatureUploadEntry(com.cloupia.model.cIM.FeatureFileUploadEntry) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.FeatureFileUploadEntry com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getCustomFeatureByFeatureID(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.isCustomFeatureExist(java.lang.String)
Nov 08, 2015 12:29:29 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.isSysAdminAllowedToChangeRole(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.updateCustomActionConfigbyWFInputFieldIdentity(java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.updateServiceRequestAssetId(java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistUcsSPRenameEntry(com.cloupia.lib.cIaaS.ucs.model.UcsSPRename) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.lang.String com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getUcsSPRenameAffectedWorflows(com.cloupia.lib.cIaaS.ucs.model.UcsSPRename) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.lang.String com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getUcsSPRenameAffectedSRs(com.cloupia.lib.cIaaS.ucs.model.UcsSPRename) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getUcsSPRenameEntries(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.lib.cIaaS.ucs.model.UcsSPRename com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getUcsSPRenameEntry(com.cloupia.lib.cIaaS.ucs.model.UcsSPRename) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.updateUcsSPRenameTableforWF(java.lang.String,java.lang.String,java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.updateUcsSPRenameTableforSR(java.lang.String,java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistSysResUtilSnapshot(com.cloupia.service.cIM.inframgr.syslimits.SysResourceUtilization) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getSysResUtilSnapshotEntries() throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.lib.cIaaS.netapp.model.NetAppClusterInterface com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getNetAppClusterInterfaceByLifIp(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.lib.cIaaS.netapp.model.NetAppClusterVolume com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getNFSNetAppClusterVolume(java.lang.String,java.lang.String,java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getHostVolumesByHost(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getHostVolumesByAccount(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.HypervHostCluster com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getHypervHostCluster(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.lang.String com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getHypervAccountFromN1kSwitchId(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.HyperVVMSummary com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getHyperVVMSummaryByAccountandUniqueId(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getPortGroupsByTypeAssignedToGroup(java.lang.String,java.lang.String)
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getDatastoreListByGroupID(int) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.modifyAddNetworkToNetworkPolicyConfig(com.cloupia.service.cIM.inframgr.profiles.PrivateCloudNetworkPolicy) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getDVPortGroupsByAccountAndDVswitchUUIDAndPGName(java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.deleteVMMeteryByVMID(int) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getHpIloAssignedToGroup(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.lib.cIaaS.hp.ilo.model.HPServerHostData com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getHPServerByAcctAndSerialNum(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static int com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getIloCpuCores(java.lang.String)
Nov 08, 2015 12:29:29 UTC Public Method: public static int com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getIloMemory(java.lang.String)
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getHPServerProcessorInfo(java.lang.String)
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getHPServerMemoryDevices(java.lang.String)
Nov 08, 2015 12:29:29 UTC Public Method: public static java.lang.String com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getHPIloServerMatchResource(java.lang.String,java.lang.String)
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.listHpServers()
Nov 08, 2015 12:29:29 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.checkforVMCloneAction(com.cloupia.model.cIM.ServiceRequest)
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.VDCCatalogItem com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.constructCatalogItemforCloneAction(com.cloupia.model.cIM.ServiceRequest,com.cloupia.model.cIM.VDC)
Nov 08, 2015 12:29:29 UTC Public Method: public static double com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getProvisionedStoragePercentForDataStore(com.cloupia.model.cIM.DataStoreInfo)
Nov 08, 2015 12:29:29 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistDatastoreListForISOInventory(com.cloupia.service.cIM.inframgr.profiles.VMWareMarkDataStoresForISOInventoryCollection) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.modifyDatastoreListForISOInventory(com.cloupia.service.cIM.inframgr.profiles.VMWareMarkDataStoresForISOInventoryCollection) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.VMWareMarkDataStoresForISOInventoryCollection com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getMarkDataStoresForISOInventoryCollection(int) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getDataStoresMappedForISOInventoryCollection(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.geAllDataStoresMappedForISOInventoryCollection() throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.deleteDatastoreListForISOInventory(int) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.deleteVMWareGuestOSToISOMappingPolicy(int) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistVMWareGuestOSToISOMappingPolicy(com.cloupia.service.cIM.inframgr.profiles.VMWareGuestOSToISOMappingPolicy) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.modifyVMWareGuestOSToISOMappingPolicy(com.cloupia.service.cIM.inframgr.profiles.VMWareGuestOSToISOMappingPolicy) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.VMWareGuestOSToISOMappingPolicy com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMWareGuestOSToISOImagesMappingPolicyById(int) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.VMWareGuestOSToISOMappingPolicy com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMWareGuestOSToISOImagesMappingPolicy(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllVMWareGuestOSToISOImagesMappingPolicy() throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMWareGuestOSToISOImagesMappingPolicyByCloud(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.DataStoreISOImagesInfo com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMWareDatastoreISOImagesInfoByIsoImagePath(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMWareDatastoreISOImagesInfoByISOImagePathAndAccount(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.DataStoreISOImagesInfo com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMWareDatastoreISOImageByImagePathHostDCAndCloud(java.lang.String,java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMWareDatastoreISOImagesListInfoByIsoImagePath(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getPrivateCloudPortGroupToDVPortGroupMappingPolicies() throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMsByDataStoresList(java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMDetailsByDVSwitch(java.lang.String,java.lang.String,java.lang.String)
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMDetailsByVSwitch(java.lang.String,java.lang.String,java.lang.String)
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMsByCIMCServer(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMDetailsByPortGroup(java.lang.String,java.lang.String,java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMDetailsByDVPortGroup(java.lang.String,java.lang.String,java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMDetailsByPhysicalNic(java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMDetailsByVMKNic(java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.uniqueVMList(java.util.List)
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.objectToModel(java.sql.ResultSet) throws java.sql.SQLException
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMsByUCSServer(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMsByUCSServer1(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getHostByUuid(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getServerByMACAddress(com.cloupia.lib.cIaaS.ucs.model.UcsServer) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getServerAdaptersByServerDn(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getPhysicalNIcByAccountAndMac(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getPhysicalInfraAccountsByType(java.lang.String)
Nov 08, 2015 12:29:29 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistCloudSenseEntry(com.cloupia.feature.cloudsense.CloudSenseCustomEntry) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.deleteCloudSenseEntry(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.modifyCloudSenseEntry(com.cloupia.feature.cloudsense.CloudSenseCustomEntry) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.feature.cloudsense.CloudSenseCustomEntry com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getCloudSenseCustomEntry(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getCustomCloudSenseEntries() throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getReportBuilderTemplates() throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getSRMProtectionGroupByAccount(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getSRMProtectionGroupDatastoreMappingByAccount(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getSRMProtectionGroupDatastoreMappingByAccount(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getSRMProtectionGroupResourcepoolMappingByAccount(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getSRMFolderInventoryMappingByAccount(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getSRMVMPortGroupsByAccount(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getSRMDistributedPortGroupsByAccount(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.isAccountSRMEnbaled(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllInfraAccounts() throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllMultiDomainMgrs() throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllPhysicalInfraAccounts() throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.feature.accounts.MultiDomainMgrAccount com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getMultiDomainMgrByName(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.feature.rhevcontroller.RhevAccount com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getRhevAccountCredentials(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.lib.connector.account.PhysicalInfraAccount com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getCredentialsClass(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cID.cIdAccess.AuthPreferences com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAuthPreferences()
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.lib.cIaaS.network.model.DeviceCredential com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getDeviceCredential(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getDataByDCandDevice(java.lang.String,java.lang.String,java.lang.Class) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static int com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getActiveVMsCountByAccountNameAndClusterId(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.isVMwareImageIdentity(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.lang.String com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getParamFromFormId(java.lang.String)
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.ArrayList com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllReportingContextforDataCenter()
Nov 08, 2015 12:29:29 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistNameValidationPolicy(com.cloupia.service.cIM.inframgr.profiles.NameValidationPolicy) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.modifyNameValidationPolicy(com.cloupia.service.cIM.inframgr.profiles.NameValidationPolicy) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.NameValidationPolicy com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getNameValidationPolicyById(int) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.NameValidationPolicy com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getNameValidationPolicyByName(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.deleteNameValidationPolicy(int) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllNameValidationPolicies() throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.deleteVMwareStorageAdapterLunMapByHostAndDSName(java.lang.String,java.lang.String,java.lang.String,java.lang.String)
Nov 08, 2015 12:29:29 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.deleteLDAPAccount(java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cID.cIdAccess.LoginProfile[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAlluserByGroups(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cID.cIdAccess.LoginProfile[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllGroupUsersList(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cID.cIdAccess.LoginProfile[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllGroupUsers() throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cID.cIdAccess.LoginProfile[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllUsersByGroup(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.HyperVCloudNetworkPolicy com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getHyperVCloudNetworkPolicy(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.Map com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getExternalUsersAsMap()
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.Map com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getLocalUsersAsMap()
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getNetworkAccounts(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getStorageAccounts(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getComputeAccounts(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllFlexPodAccounts(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.FormLOVPair[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getUCSServiceProfilesVHBAs(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.FormLOVPair[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getInfraStorageTypesLOV()
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.FormLOVPair[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllStorageAccountsLOVByType(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.FormLOVPair[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getNexusDevicesLOV() throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.isSupportedNexusSwitch(java.lang.String)
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getUCSvHBAForAccount(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllDeviceStatus() throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getNetiSCSIPortalInfo(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllCIMCRackGroups() throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.lib.cIaaS.ucs.model.cimc1_5.CIMCAssignRackGroupToPod com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getCIMCAssignRackGroupToPod(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getCIMCAssignRackGroupToPodByPodName(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.lang.String com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getNewElementAdded(com.cloupia.model.cIM.FormLOVPair[],com.cloupia.model.cIM.FormLOVPair[])
Nov 08, 2015 12:29:29 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistASAvVMDeploymentPolicy(com.cloupia.feature.resourceGroups.forms.ASAvVMDeploymentPolicyConfig) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.modifyASAvVMDeploymentPolicy(com.cloupia.feature.resourceGroups.forms.ASAvVMDeploymentPolicyConfig) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.feature.resourceGroups.forms.ASAvVMDeploymentPolicyConfig com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getASAVVMDeploymentPolicyById(int) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.feature.resourceGroups.forms.ASAvVMDeploymentPolicyConfig com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getASAvVMDeploymentPolicyByName(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.deleteASAvVMDeploymentPolicy(int) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllASAvVMDeploymentPolicies() throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.lang.String com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMTypeByVMID(long) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.VMStorageProfile[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllVMStorageProfilesByAccName(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMStorageProfilesByAccName(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllVMStorageProfilesByAccNameAndProfileName(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.VMStorageProfile[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllVMStorageProfiles() throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.purgeDeletedDatacenterInventoryEntries(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.VMStorageProfile[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getStorageProfilesByAccount(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.VMStorageProfile com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getStorageProfileByAccountAndPolicyName(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.VMStorageProfile com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getStorageProfileByAccountAndProfileName(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.DataStoreInfo[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMWareDatastoresByAccountAndDatastoreName(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.DataStoreInfo[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMWareDataStoresByAccountAndDatastoreIdentity(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getStorageProfileRuleset(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getStorageProfileRulesetByAccountAndProfile(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getStorageProfileDatastoreByAccountAndName(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.updateDVSwitchForNIOC(com.cloupia.feature.vmwareController.wftasks.configs.ModifyDVSwitchForNIOCSettingConfig) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.updateDVSwitchForNetworkResourcePoolsTrafficShare(com.cloupia.feature.vmwareController.wftasks.configs.ModifyDVSwitchForNetworkResourcePoolsTrafficSettingConfig) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.AllocatedIPfromIPPoolPolicy com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getallocatedIPfromIPPoolPolicy(java.lang.String,com.cloupia.service.cIM.inframgr.customactions.CustomActionTriggerContext,com.cloupia.service.cIM.inframgr.customactions.CustomActionLogger,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.VSANQualificationPolicy[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllVsanQualificationPolicyByAccName(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.VSANQualificationPolicy[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllVsanQualificationPolicy() throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistQualificationPolicy(com.cloupia.model.cIM.VSANQualificationPolicy) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.updateVSANQualificationPolicy(com.cloupia.model.cIM.VSANQualificationPolicy)
Nov 08, 2015 12:29:29 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistStdVSANQualificationPolicy(com.cloupia.model.cIM.StandardVSANQualificationPolicy) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.Image[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getFilterImageList(com.cloupia.model.cIM.Image[],int) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.lang.String com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getSelfGroupByGroup(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getStdVSANQualificationPolicies() throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVSANQualificationPolicies() throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getStdVSANQualificationPolicyByName(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMWareDataStoresAssignedToGroup(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cID.cIdAccess.LoginProfilePaginated com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getLoginInfoDetails(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getDatacentersByPodType(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVSANClustersByAcc(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVSANClustersByAccAndDC(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getManagedVSANClustersByAccAndDC(java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getManagedVSANClustersByAccAndDC(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.VMwareStorageSummary com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMwareStorageSummaryForAllVSANPodVMwareAccounts() throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.VMWareHost[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMWareHostsWithVSANDatastores(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.Account[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllVSANPodVMwareAccounts() throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.AccountStatus com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVmwareAccVMsCount(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.Account[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMwareAccountsByPodName(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistVsanPodSettings(com.cloupia.model.cIM.VSANPodSettings) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.VSANPodSettings com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVSANPodSettings(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.VMWareCluster[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllVSANPodVSANClusters() throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.InfraAccount com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getUCSMAccountInVirtualSANPod(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.VSANPodSettings com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVsanPodSettings(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getPhysicalNICsByAcntNameAndHost(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.VMWareVMSummary[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVSANDatastoreVMs() throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.addVMwareVMProvisionOverrideParameters(com.cloupia.model.cIM.VMwareVMProvisionOverrideParameters) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.modifyVMwareVMProvisionOverrideParameters(com.cloupia.model.cIM.VMwareVMProvisionOverrideParameters) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.deleteVMwareVMProvisionOverrideParameters(int) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.VMwareVMProvisionOverrideParameters com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMwareVMProvisionOverrideParametersBySRId(int) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.VDCCatalogItem com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMwareVMProvisionOverrideParametersCatalogItemBySRId(int) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.updateVMwareVMProvisionOverrideParametersCatalogItemBySRId(int,com.cloupia.model.cIM.VDCCatalogItem) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.updateVMwareVMProvisionOverrideParametersNICsIPBySRId(int,java.util.List) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.VSANDiskGroup com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVSANDiskGroupByDiskName(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.VSANDiskGroup com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVSANDisksByDiskName(java.lang.String,java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.VSANDiskGroup com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVSANDisksByCanonicalName(java.lang.String,java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.lang.String com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVSANDiskNameByCanonicalName(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.VSANDiskGroup com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVSANDiskByCanonicalName(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.VMWareHost[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVSANHostsByCluster(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.VMWareHost[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVSANHostsByClusterAndDataCenterName(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.VMWareHost[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllVSANHosts() throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.CreateVirtualSANClusterInputs com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getCreateVirtualSANClusterInputs(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistCreateVirtualSANClusterInputs(com.cloupia.model.cIM.CreateVirtualSANClusterInputs) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.deleteCreateVirtualSANClusterInputs(com.cloupia.model.cIM.CreateVirtualSANClusterInputs) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistVirtualSANClusterDetails(com.cloupia.feature.vmwareController.virtualSAN.model.VirtualSANClusterDetails) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVirtualSANClusterDetailsByPodName(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.feature.vmwareController.virtualSAN.model.VirtualSANClusterDetails com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVirtualSANClusterDetailsBySRID(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.AccountStatus[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMDistributionByCloud() throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.AccountStatus com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMsCount(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.updateGroupMembershipView(com.cloupia.model.cID.cIdAccess.LoginProfile,java.lang.String)
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.lib.cIaaS.ucs.model.UcsServer com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getUCSServerByAccountNameAndServerdn(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.PrivateCloudComputingPolicy com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getDefaultPrivateCloudComputingPolicyByCloud(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.PrivateCloudNetworkPolicy com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getDefaultPrivateCloudNetworkPolicyByCloud(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.PrivateCloudStoragePolicy com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getDefaultPrivateCloudStoragePolicyByCloud(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.CostModel com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getDefaultCostModel() throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.service.cIM.inframgr.customactions.CustomVMActionPolicy com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getDefaultUserActionPolicy(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getFolders(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.DVSwitch com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getDVSwitchByAccountAndHosts(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getDVPGsBySwitchName(java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.insertDatastoreLabelMapping(com.cloupia.model.cIM.DatastoreLabelMapping) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.DatastoreLabelMapping com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getDatastoreLabelMappingByDatacenterCloudAndDatastoreURL(java.lang.String,java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.deleteDatastoreLabelMappingByDSIdentity(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.VMStorageProfile com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getStorageProfileByCloudAndProfileID(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVsanClustersByCloudAndDatastores(java.lang.String,java.lang.String,java.lang.String[]) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.updateReferencePhysicalDC(java.lang.String,java.lang.String,int) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllDatastoresList()
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.feature.vmwareController.virtualSAN.model.VirtualSANManagedCluster com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getManagedVirtualSANClusterInputs(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistVirtualSANManagedClusterDetails(com.cloupia.feature.vmwareController.virtualSAN.model.VirtualSANManagedCluster) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.deleteVirtualSANManagedClusterDetails(com.cloupia.feature.vmwareController.virtualSAN.model.VirtualSANManagedCluster) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getManagedVSANClusterByAccountandPodAndDatacenter(java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getManagedVSANClusterByAccountAndDatacenter(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllVSANManagedClustersByPodName(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllVSANManagedClusterByClusterType() throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.feature.vmwareController.virtualSAN.model.VirtualSANManagedCluster com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getManagedVSANClusterByAccountandPodAndDatacenterAndCluster(java.lang.String,java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.deleteFailedVSANCluster(com.cloupia.feature.vmwareController.virtualSAN.model.VirtualSANManagedCluster) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.lang.String com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getPrivateCloudNetworkPolicyBySRId(int) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.canOverrideNetworkPolicyNICIPAddress(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.SrmFolderInventoryMappingInfo com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getSrmFolderMappingInfo(com.cloupia.model.cIM.VMwareFolderIdentity) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.SrmResourcePoolInventoryMappingInfo com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getSrmResourcePoolMappingInfo(com.cloupia.model.cIM.ResourcePoolInfo) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.SrmRecoveryPlanDetails com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getSrmRecoveryPlanDetails(com.cloupia.model.cIM.SrmRecoveryPlanDetailsIdentity) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.UCSDSrmProtectionGroupInfo com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getSrmProtectionGroupInfo(com.cloupia.model.cIM.VMwareSRMProtectionGroupIdentity) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllIPSubnetsInfoContainsID(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.VMwareFolder com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getServiceContainerFolder(java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getTagsMappedtoObject(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getPossTagValuesOfTag(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.lang.String com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getParentGatewaySubnetID(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.isAlreadySubnetted(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getStorageAssignmentsByUser(int) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.VMWareHostStorageAdapter com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMwareStorageAdapterByNameAndHostName(java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.Account[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMwareAccountsByPodNameForIaasCatalog(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.persistVirtualSANvDCDetails(com.cloupia.feature.vmwareController.virtualSAN.model.VirtualSANvDCInfo) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.feature.vmwareController.virtualSAN.model.VirtualSANvDCInfo com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVSANvDCByAccountVDCNameAndPodName(java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.deleteVSANvDCPodMapping(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.deleteVSANvDCPodMappingByAccountAndVDCName(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.deleteVSANCatalogPodMapping(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static void com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.deleteVSANCatalogPodMappingByAccountAndVDCName(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVsanPodDVPortgroupListForAccountAndDvSwitch(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.VMWareCluster com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVsanClusterByAccountDCandName(java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.deleteManagedClusterFromPod(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getSystemTaskPolicy()
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.SystemTaskPolicy com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getSystemTaskPolicy(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static boolean com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.isInMaintenanceMode(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.Account com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getConstructedGenericAccount(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.VMWareHost[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMWareHostsByAccountAndHostNode(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.HostNodeStatusSummary com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMWareHostNodeStatusSummary(com.cloupia.model.cIM.VMWareHost) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.HostNodeStatusSummary com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getRhKvmHostNodeStatusSummary(com.cloupia.lib.cIaaS.rhev.model.RhevHost) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.HyperVHost[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getHyperVHostsByAccountAndHostNode(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.CloudSummary com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getCloudSummary() throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.AmazonVMSummary com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAmazonVMSummary(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMDiskConfigByCloudDCAndVMID(java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getDatastoreClusterByAccountAndDatacenter(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.lang.String com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getImageIdFromIdentity(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getActiveAmazonVMsByAccount(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getActiveTier3VMsByAccount(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.service.cIM.inframgr.VDCSummary com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVDCSummary(com.cloupia.model.cIM.VDC) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.service.cIM.inframgr.VDCSummary com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVDCSummary(int) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.HostNodeStatusSummary com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getHyperVHostNodeStatusSummary(com.cloupia.model.cIM.HyperVHost) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getPhysicalNIcByAccountAndHost(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.lib.connector.account.PhysicalInfraAccount com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getPhysicalAccountByName(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getObjectsByCloudName(java.lang.Class,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllInActiveVMsByAccount(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllInActiveRhevVMsByAccount(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getInActiveHyperVVMsByAccount(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.GenericVM[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getActiveVMsByAccount(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.VMWareHost[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMWareHostsByAccountForResourceAllocation(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.VMWareHost[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMWareHostsByAccount(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.VMWareHost[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMWareHostsByAccount(java.lang.String,boolean) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getActiveVMWareVMsByAccount(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.HyperVHost[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getHyperVHostsByAccount(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getActiveHyperVVMsByAccount(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getStorageDomainsByAccount(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllHypervVMDisksConfig() throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.DataStoreInfo[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getHypervDatastoresByAccount(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.Map com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getHypervHostMap(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.Account[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllVDICloudAccounts() throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAccountsByType(int)
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAccountsByType(java.lang.String)
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllLunDatastoreAssociation() throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.lib.cIaaS.netapp.model.NetAppNfsRule com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getNetAppNfsRuleByExportPathAndRemoteIP(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.lib.cIaaS.netapp.model.NetAppVolume com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getNetAppByVolume(java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.lib.cIaaS.netapp.model.NetAppVolume com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getNetAppByVolume(java.lang.String,java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.DataStoreInfo com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getDataStoreByAccountAndVMwaredatacenter(java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.HostNodeStatusSummary[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllHostNodeStatusSummary() throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.HyperVHost[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllHyperVHosts() throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.HostNodeStatusSummary[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllHyperVHostNodeStatusSummary() throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllObjects(java.lang.Class) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.HostNodeStatusSummary[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllRhKvmHostNodeStatusSummary(java.util.List) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getResourcePoolsAssignedToGroup(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllResourcePools() throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getResourcePoolsForAccount(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getMSPStorageAssignmentsByEntityType(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static double com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getProvisionedStorageForDataStore(com.cloupia.model.cIM.DataStoreInfo)
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.Account com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMWareAccountInVirtualSANPod(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVCloudExpVMSummaryByAccount(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.HyperVHost com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getHostsByAccountAndHostNode(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getScheduledVMActionsByVM(long) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getScheduledVMActionsByCloud(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.ResourcePoolInfo com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getResourcePoolInfoByRPIdentity(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMWareVMsByAccount(java.lang.String,boolean) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.Image[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllImagesByVDC(int)
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.PrivateCloudNetworkPolicy com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getPrivateCloudNetworkPolicy(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.PrivateCloudNetworkPolicy com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getPrivateCloudNetworkPolicy(int) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.PrivateCloudStaticIPPoolPolicy com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getPrivateCloudStaticIPPoolPolicy(int) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.service.cIM.inframgr.profiles.PrivateCloudStaticIPPoolPolicy com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getPrivateCloudStaticIPPoolPolicy(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.Map com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllDatastoreLabelMappings() throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getStorageAssignmentsByEntityTypeAndGroupId(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.DataStoreInfo com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getDataStoreByCloudAndDatastoreURL(java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.DataStoreInfo com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getDataStoreByCloudUrlAndVmDataCenter(java.lang.String,java.lang.String,java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getNetAppAllNfsRules() throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.Account[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAllVMWareAccounts() throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static int com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getNoOfEventsByAccountAndSeverity(java.lang.String,int) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static int com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getNoOfEventsByVDCAndSeverity(int,int) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAggregateHistoricalData(com.cloupia.model.cIM.ReportContext,java.lang.String,long,long) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.Set com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMIdSet(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMWareVMSummaryByAccount(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getAmazonVMSummaryByAccount(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getHyperVVMSummaryByAccount(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.DataStoreInfo[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMWareDatastoresByAccount(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.DataStoreInfo[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMWareDatastoresByAccount(java.lang.String,boolean,boolean) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.HypervStorageSummary com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getHypervStorageSummaryByAccount(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.lib.cIaaS.hyperv.model.HypervHostVolume com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getHypervHostVolume(com.cloupia.model.cIM.DataStoreInfo) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.lang.String com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getHypervLUNDetails(com.cloupia.model.cIM.DataStoreInfo) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.VMWareHost[] com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getVMWareHostsAndMountedDatastoresByAccount(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getHistoricalData(com.cloupia.model.cIM.ReportContext,java.lang.String,long,long) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getHistoricalDataNonNegativeValues(com.cloupia.model.cIM.ReportContext,java.lang.String,long,long) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getDatastoreAggregateHistoricalData(com.cloupia.model.cIM.ReportContext,java.lang.String,long,long) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static java.util.List com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getDatastoreSpotHistoricalData(com.cloupia.model.cIM.ReportContext,java.lang.String,long,long) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static int com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.purgeHistoricalDataSpotSamples(long) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static int com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.purgeHistoricalDataSamples(long) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static int com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.purgeCollectionEntriesOlderThan(long) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public static com.cloupia.model.cIM.DataCenter com.cloupia.service.cIM.inframgr.InfraPersistenceUtil.getDataCenter(java.lang.String) throws java.lang.Exception
Nov 08, 2015 12:29:29 UTC Public Method: public final void java.lang.Object.wait(long,int) throws java.lang.InterruptedException
Nov 08, 2015 12:29:29 UTC Public Method: public final native void java.lang.Object.wait(long) throws java.lang.InterruptedException
Nov 08, 2015 12:29:30 UTC Public Method: public final void java.lang.Object.wait() throws java.lang.InterruptedException
Nov 08, 2015 12:29:30 UTC Public Method: public boolean java.lang.Object.equals(java.lang.Object)
Nov 08, 2015 12:29:30 UTC Public Method: public java.lang.String java.lang.Object.toString()
Nov 08, 2015 12:29:30 UTC Public Method: public native int java.lang.Object.hashCode()
Nov 08, 2015 12:29:30 UTC Public Method: public final native java.lang.Class java.lang.Object.getClass()
Nov 08, 2015 12:29:30 UTC Public Method: public final native void java.lang.Object.notify()
Nov 08, 2015 12:29:30 UTC Public Method: public final native void java.lang.Object.notifyAll()
Nov 08, 2015 12:29:30 UTC Completed cloupia script PrintJavaMethods
Nov 08, 2015 12:29:30 UTC Task #1 (PrintJavaMethods (ExecuteCloupiaScript)) completed successfully in 5 seconds
Nov 08, 2015 12:29:30 UTC Input/Output values for Task #1 (PrintJavaMethods (ExecuteCloupiaScript)):
Nov 08, 2015 12:29:30 UTC [Local Input: Label = PrintJavaMethods]
Nov 08, 2015 12:29:30 UTC [Local Input: Script = importPackage(java.lang.reflect); importPackage(java.io); importPackage(com.cloupia.service.cIM.inframgr); var javamethodname = [ ctxt.getInput('JavaMethodName') ]; function main() { if (javamethodname == '1') { var t = new VDCUtil(); logger.addWarning('javamethodname (VDCUtil): ' + javamethodname); } if (javamethodname == '2') { var t = new InfraPersistenceUtil(); logger.addWarning('javamethodname (InfraPersistenceUtil): ' + javamethodname); } var tClass = t.getClass(); var methods = tClass.getMethods(); for (var i = 0; i < methods.length; i++) { logger.addWarning('Public Method: ' + methods[i]); } } main(); ]
Nov 08, 2015 12:29:30 UTC [Local Input: Undo Script = ]
Nov 08, 2015 12:29:30 UTC Completed workflow item number 1, with status Completed
Nov 08, 2015 12:29:31 UTC Executing workflow item number 3
Nov 08, 2015 12:29:31 UTC Completed workflow item number 2, with status Completed
Nov 08, 2015 12:29:02 UTC [Local Input: Undo Script = ]
Nov 08, 2015 12:29:02 UTC Completed workflow item number 1, with status Completed
Nov 08, 2015 12:29:06 UTC Executing workflow item number 3
Nov 08, 2015 12:29:06 UTC Completed workflow item number 2, with status Completed
Packages and Classes (by Mohamed Arif Hajamohideen)
The statement ‘importPackage’ will give the details of packages.
The statement ‘importClass’ will give the details of class.
I have verified this in UCSD 5.4
Sample script to test:
importClass(com.cloupia.service.cIM.inframgr.GroupManagerImpl);
File Path
Custom task to search a file with the given String. The task will print the file path in the log. Tested in 5.4
cristel1221
Community Member
Very long! but it's great!
