Orf Gelbrich
Task NameNetapp cli execution with variable chopping
Description
Prerequisites
Minimum UCSD version: 5.4.0.1
CategoryCustom task
Components
User Inputs
User OutputNetapp filer and cli command
  8. Click "Submit".
A thank you goes out to: Abhilash Pujari
The workflow:
Previous output is input:
Previous output is input in task:
Example of variable disassembly:
The workflow execution:
The variable name:
Other chopping options for the code (sort):
var vss1 = selection.split("online");
var vss = vss1.sort();
Custom task to extract the SR information:
importPackage(com.cloupia.service.cIM.inframgr);
importPackage(java.util);
importPackage(java.lang);
// Auto generated to code invoke following task
// Task Label:  Execute NetApp CLI
// Task Name:  Execute NetApp CLI
function Execute_NetApp_CLI_()
    var task = ctxt.createInnerTaskContext("Execute NetApp CLI ");
    // Input 'Filer Identity Name', mandatory=true, mappableTo=filerIdentity
    task.setInput("Filer Identity Name", input.filerName);
    // Input 'CLI Command', mandatory=false, mappableTo=gen_text_input
    task.setInput("CLI Command", input.inputCommand);
    // Input 'Expected Output', mandatory=false, mappableTo=gen_text_input
    task.setInput("Expected Output", input.expectedOutput);
    // Input 'Undo CLI Command', mandatory=false, mappableTo=gen_text_input
    task.setInput("Undo CLI Command", input.undoCLICommand);
    // Now execute the task. If the task fails, then it will throw an exception
    task.execute();
function getOutput(){
var srId = ctxt.getSrId();
  //var srId = Integer.parseInt(input.SR_ID);
  //var severityLevels = input.SeverityLevels;
    logger.addInfo("SrId is:"+srId);
    var severityLevel = 1;
  var SRLogsList = getSRLogs(srId,severityLevel);
  if(SRLogsList == null || SRLogsList.isEmpty()){
  logger.addWarn("There is no SR LOGS.....");
  for(var i=0;i<SRLogsList.size();i++){
  var logEntry = SRLogsList.get(i);
  var sr_Id = logEntry.getSrId();
  var severity = logEntry.getSeverity();
  var message = logEntry.getMessage();
    if(message.contains("Output:")){
  var taskOutput = getRequiredOutputFromLoggerMessage(message);
  logger.addInfo("=========="+taskOutput);
  output.taskOutput = taskOutput;
  //logger.addInfo("SrId:"+sr_Id+"  severity:"+ severity+"   Message:"+message);
function getSRLogs(srId,severityLevel){
  var entryList = SRLogUtil.getSRLogs(srId,severityLevel);
  return entryList;
function getRequiredOutputFromLoggerMessage(outputFormat){
//Here we can fetch the exact info from the output.
return outputFormat;
function main(){
// Invoke the task
Execute_NetApp_CLI_();
Thread.sleep(3000);
getOutput();
logger.addInfo("Output of task is:"+output.taskOutput)
// Invoke the main function
main();
