Orf Gelbrich
Task NamePassword Check at Workflow Execution Level
Description
  1. Change the user of a running workflow
Prerequisites
  1. Tested on 5.3.1
CategoryWorkflow
ComponentsvSphere 5.x
User Inputs
  1. userid to change to
Output
  8. Click "Submit".
This is a sample workflow to test 2 password variables at workflow execution levee if they match and then send out an e-mail if they match or not:
The Workflow:
The execution:
The execution if they do not match:
The execution if they match:
The Cloupia script:
// Load Packages
importPackage(java.lang);
importPackage(java.util);
// Get Variables from the workflow
var PW1 = ctxt.getInput("Password");
var PW2 = ctxt.getInput("Confirm Password");
var userId = ctxt.getUserId();
var userProfile = ctxt.getAPI().userAPIGetMyLoginProfile();
var email = userProfile.getEmail();
ctxt.updateInput("SUBMITTER_EMAIL", email);
logger.addInfo("Password = '"+PW1+"' / Confirm Password = '"+PW2+"'");
// Verify passwords match
if (PW1.equals(PW2))
  logger.addInfo("Passwords match.");
  ctxt.setSuccessful();
} else {
  logger.addInfo("Passwords unmatched.");
  ctxt.setFailed("Passwords did not match.");
