Orf Gelbrich
Task NamePassword Check at Workflow Task Level
Description
  1. Change the user of a running workflow
Prerequisites
  1. Tested on 5.3.1
CategoryWorkflow
ComponentsvSphere 5.x
User Inputs
  1. userid to change to
Output
  8. Click "Submit".
Thank you Niraj Kumar
Note: This does not work at the enduser workflow execution level!
Checking for an empty password field:
Checking if the password matches:
Password matched:
Create 2 inputs of type password:
Controller after un marshall
The code
importPackage(com.cloupia.service.cIM.inframgr.forms.util);
importPackage(com.cloupia.service.cIM.inframgr.forms.wizard);
importPackage(java.lang);
importPackage(java.util);
if (page.isPageSubmitted()){
         var pwd = pojo.getPassword();
         var repwd = pojo.getConfirmPassword();
         if(pwd.isEmpty()){
                page.setError(id + ".password", "please enter password");
                page.setPageMessage("Please fix the errors to proceed.");
         else if(repwd.isEmpty() || !(pwd.equals(repwd))){
          page.setError(id + ".confirmPassword", "password not matching,please re-enter password");
There is also an out of the box task:
Regular expression example at custom task level:
This works at task input level, not at workflow execution!
