Orf Gelbrich
Task NamePXE boot HP OA Blade Server
DescriptionPXE boot HP OA Blade Server
Prerequisites
  1. Tested on 5.2.0.2
CategoryWorkflow tasks
ComponentsPXE boot HP OA Blade Server
  1. Log in to UCS Director as a user that has "system-admin" privileges.
  2. Navigate to "Policies-->Orchestration" and click on "Import".
  3. Click "Browse" and navigate to the location on your computer where the .wfdx file resides. Choose the .wfdx file and click "Open".
  4. Click "Upload" and then "OK" once the file upload is completed. Then click "Next".
  5. Click the "Select" button next to "Import Workflows". Click the "Check All" button to check all checkboxes and then the "Select" button.
  6. Click "Submit".
  7. A new folder should appear in "Policies-->Orchestration" that contains the imported workflow.
The workflow name:
The workflow Input:
The workflow:
