kesimmon
Task Pack
String Pack
Description
Perform manipulations and checks on strings in UCS Director workflows
Prerequisites
Validated on UCSD 5.3.1.1
Category
Workflow Tasks
Components
UCS Director
Tasks
  1. String Combine
  2. String Length
  3. String Trim
  4. String Substring Absolute
  5. String Substring Relative
  6. String Upper
  7. String Lower
  8. String Replace
  9. String Contains
Output
Result of operation
Installation
  2. Unzip the file on your computer. Should end up with a .WFDX file.
  8. Click "Submit".
Usage
See attached document “UCS Director – String Pack”
The workflow also includes a sample Unit Test script that can be used to validate the custom task against different releases of UCS Director.  The Unit Test workflows are marked as Compound Tasks so the Test Suite task can run all of the tasks to simplify testing.
Example
Prefix a string to a variable
Start as the third character and extract the next two characters from the hostname
