Orf Gelbrich
Task Name
  1. Kubernetes
Description
  1. .
Prerequisites
  1. Tested on 6.5 and
CategoryWorkflow
ComponentsvSphere 6.5
User Inputs
  8. Click "Submit".
The question came up can you overlap VLAN pools in UCSD?
The short answer is yes, but it has to be set up correctly.
Creation of 2 Pools in 2 different PODs (this is done under network policies):
Pool1 A
Pool2 C
Workflow:
Workflow execution:
Result VLAN 100 was pulled from each pool.
The VLAN usage screen also indicates that VLAN 100 was pulled 2 times:
When the VLAN pools are in the same POD then it will not over lap:
It pulled 100 and 101 on workflow run SR=911
Then it pulled 102 and 103 on workflow run SR=912
On workflow run SR=913 I added a VLAN pool in a different POD and it pulled the next VLAN 104 and from Pool C VLAN 100
The next run it pulled VLAN 105 and VLAN 101
Result is when the Pools are in the same POD then it will not over lab, but if the pools are in a different POD then VLAN overlay can be done.
