CiscoUnity Miu Errors
alan-white
We are getting the specific error below on the same Unity port everytime and as a result users get blank voicemails left for them. It happens randomly. Anyone ever seen this?
Event Type: Error
Event Source: CiscoUnity_Miu
Event Category: Error
Event ID: 552
Date: 6/2/2004
Time: 11:38:39 AM
User: N/A
Computer: OKCVM1
Description:
Cisco Unity's telephony component has encountered a serious error.
EXPLANATION:
No reponse was received on port 2 while rejecting a transfer. This is a serious failure, and most likely parties involved in the call will be disconnected. In some cases, further calls on this port will not be handled correctly.
TECHNICAL DETAILS:
Thread 0x00000BD4 had a Failure on Port 2 in Method CAvMiuLine::TransferComplete(eMIU_XFERCOMPLETE_REJECTED)
DESCRIPTION: Timed-out waiting for LINECALLSTATE_IDLE after lineDrop.
DETAILS:
HCALL: 0x000101E5
CallState: LINECALLSTATE_ONHOLDPENDTRANSFER
Consulting HCALL: 0x000101BD
Consulting CallState: LINECALLSTATE_DISCONNECTED.
CALLINFO:
CallerID: 3163831431
CalledID: 101
RedirectingID: Unknown
Origin: Internal
Reason: Direct
Trunk: 0.
evonnorm
We need more information in order to diagnose this. Exactly what version of Cisco Unity are you using, and what is the integration, meaning are you using Cisco Call Manager (and if so, what version) or are you using a TDM PBX (and if so, which one)? It looks like Unity is trying to recall a supervised transfer from an outside caller (3163831431 in this case) to a subscriber (either the phone was busy or they didn't answer, I can't tell which from this). For whatever reason, we're having trouble dropping the consultation call, which is a required step before we can re-establish the original call. Does this happen for all subscribers and does it happen on every call? If you place a call from an external number and then request a supervised transfer to a subscriber, is Unity able to pull the call back (1) if the phone is busy and (2) if the phone is not busy but the subscriber does not answer. And in both cases, do messages get left for the subscriber and are the messages empty?
Thanks for the response. We are using Unity 4.0(2) with 7.04TSP and Callmanager 4.01sr2. It is a unified messaging integration with Exchange 5.5 sp4 and exchange is on a separate server. It is happening for random subscribers but only on calls from the outside and only on random calls. In all cases messages get left for subscribers and sometimes they are blank audio. Also, in all cases it only on port number 2 on Unity.
I think you've run into a known defect (CSCee56053), which concerns recalling supervised transfers with Cisco Call Manager 4.0(1)sr2. That defect is fixed in 4.0(1)sr2a, which is available for download in our Technical Support Download Area. Please upgrade to that version and let us know if you're still having problems.
Thanks for the great help. Applying the patch did indeed resolve our problem.
