CUBE MAX Session Support by ISR G2 Model
clayostlund
Level 5
Level 5
I need to find a table some place that shows the total number of SIP Sessions supported by each of the ISR G2 models.
Specifically, I am looking for info such as:
a 2901 can support 30 sessions
a 2921 can support 75 sessions
etc.
Thanks in Advance!
Also, if your a CUBE expert, if you could stear me in the direction of some Cisco Configs for CUBE in use with CUCM Enterprise with SIP from a PSTN Provider that would be great.  I have deployed MANY CUCM servers, but we have not had anyone yet use SIP and CUBE, so it's new.
mfenne
Hi Clay:
Thanks for your inquiry. There's a Q&A on CUBE that has all the capacity information you're looking for at:
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6790/gatecont/ps5640/prod_qas09186a00801da69b.html
Have a great day.
Cheers,
Marlowe
adrien.hemard
Hi Clay:
On the ordering guide you got right information:Cisco Unified Border Element and Gatekeeper Ordering Guide - Cisco
Adrien
