05-17-2010 01:09 PM
I am having some issues with the Salesforce plugin:
My installation is:
05-21-2010 05:44 AM
Question #1:
Which documentation have you referenced that needs to be updated with the info?
Question #2:
CUPC passwords are based on the Unified CM passwords. If using LDAP
Synchronization/Authorization, CUPC will use the password stored in LDAP.
This is the recommended deployment as any password change in LDAP will
automatically be picked up by Unified CM. Without LDAP Synchronization/
Authorization, Unified CM maintains passwords locally and will need to be
changed every time there is a password change in LDAP.
Is the issue the management of backend passwords with Unified CM, or the
fact that the plugin is not picking up the automatic password changes?
Question #3:
Calls that are presented to CUPC, are handled through configuration and setup
on Unified CM. CUPC softphone is a registered SIP line side device (UPC device)
on Unified CM and calls are presented to the configured audio source on the client
(which in this case appears to be the headset in your example).
Can you clarify the issue, as the title states CUPC softphone is ignored.
