Loading Unity Connection
bob.bartlett
I am trying to load a demo box with Unity connection and I didn't find the platform configuration software anywhere and the load fails saying i must run that software to prepar my Windows 2003 load. Where can I get the Platform configuration CD.
lindborg
For demo installs you can run the setup with the "/NOPCD" command line option - this skips the hardware check and logs some stuff in the registry and event log so TAC knows you did it (i.e. TAC wont support your system if you do this). But for a demo installation as you're trying to do, it's OK.
Yeah! it did work with "/NOPCD". thanks for that. after the installation, i came across another huddle. is there Unity Connection eval license i can get from? without license, i seem stuck with no further configuration for my home lab.
the demo license file is found under 'license' directory. bummer! :)
