Unity Connection interdigit timeout
ncraven
Community Member
How can I increase the timer on Unity Connection so a user can pause while entering his user ID?
Saurabh Agnihotri
You can achieve it on a per user basis by the following steps:
1)Goto the "Edit User Basics" page of the desired User on "Unity Connection Administration" page.
2)From the "Edit" menu, goto "Phone Menu" option.
3)Select the desired values in the Following boxes:
When Responding to Menus
* milliseconds
* milliseconds
* milliseconds
Times to Repeat Menu When User Does Not Respond
Specify how many times Cisco Unity Connection repeats a menu when a user  has not responded to it. The range of valid entries is 0 to 10.
Note     : This setting is not available for the voice-recognition conversation.
Default setting: 1 time.
Wait for First Touchtone or Voice Command ____ Milliseconds
Specify how long Cisco Unity Connection waits for a user to press a  first key or say a voice command after playing a menu. This setting is  also known as the "First Digit Timeout." The range of valid entries is  500 to 10,000 milliseconds.
Default setting: 5,000 milliseconds.
Wait for Additional Key Presses When Entering Names, Extensions, and Passwords ____ Milliseconds
Specify how long Cisco Unity Connection waits for additional key presses  after the user has pressed a key when entering user names or extensions  to address a message, update passwords, change call transfer or message  notification numbers, and so on.
The range of valid entries is 1,000 to 10,000 milliseconds.
Default setting: 3,000 milliseconds.
