Unity Failover Design in MAN Environment
calmichael
It seems that the design guides require that Unity
and Exchange be colocated in the same VLAN and
Layer 3 IP subnet.
The situation a client wants to have explored is to
relocate the Unity failover server to another campus
buildling to overcome disaster recovery topics that
are associated with single building designs.
The links between buildings are 10GE (redundant) with
peak bandwidth reaching 15% and latency below 10ms.
This is a Unity-VM 4.0(4) deployment, voicemail only
with off-box Exchange 2003.
If only the Unity failover server was to be relocated
or built new at a 10GigE connected site, would this
still be considered as a supported design? Note that
Exchange would still be in the original building and
would not be present at the failover building though
plans may change to include additional Exchange
servers throughout the campus. A CCM server that is
part of the same cluster as the original building
would be present at the failover building location.
--- Thanks ---
kechambe
Level 7
Level 7
The bandwidth levels you have are much more that what we require for support. The requirement is 45 mbps or more and for it to be considered the same LAN. The 'Cisco Unity Deployment and Solutions Guide' book is a pretty large section on this. It's worth reading.
Keep in mind that Exchange 2003 is not supported for voicemail only, even if it is off box. There are some technical issues when Unity is deployed as VM with Exchange 2003 that will affect system performance. Until they are all resolved only Exchange 2000 is supported.
Keith
