Problem with the Unity express Script
kailash_sharma
Level 2
Level 2
I have created a script in Unity Express . one of the option is redirecting the call to one international number .but when user press the option it says number is incorrect .
Can some one pls suggest what could be the issue.
> when dialing the same nunber from the phone it works fine .
>Thanks
bnandan
Hi Kailash,
Did you try appending country code before the phone number in redirect step?
Do you have appropriate dial-peer on CME?
You have mentioned that, calling that international number from phone directly works. From which phone you are dialing that number? I mean is that phone also registered to same CME?
Bhavya
