Greg Wilkinson
UPDATE 10/25/22: The IMC Emulator will be decommissioned at the end of this week. There has not been any active development with the utility in several years, and as such we will be removing this page.
The Cisco IMC Emulator allows users to familiarize themselves with Cisco’s UCS Standalone Management platform, also known as the Cisco Integrated Management Controller (Cisco IMC). It provides access to all three management interfaces Cisco offers today – WebUI, CLI, and the XMLAPI. The Cisco IMC Emulator is supported on the following servers: C220M4, C240M4, C460M4.
The emulator enables users to do the following:
  • View and explore the available Cisco IMC features without the need for physical HW. For example, experiencing the new HTML5 based WebUI that launched with Cisco IMC 3.0(1c) firmware.
  • Become familiar with select Cisco UCS hardware and standalone management solutions before purchasing equipment.
  • Set up automation scripts / programmatic deployments using the XML API. This can save time for our customers.
Current Release 3.0(3f):
The latest release of the Cisco IMC Platform Emulator brings the following changes:
- Emulator is now bundled as an OVA for seamless deployment, eliminating the requirements for pre-configured Linux hosts
- Emulator now has multi-threaded QEMU support, allowing for faster interaction via the API, and overall performance increase
- ZIP file includes individual platform versions if deploying a VM is not possible. These can be run inside RHRL 7.0/CentOS 6.5 and have the same prerequisites as the initial release.
**User Guide for current release is posted in the Attachments section below. The OVA/ZIP files can be found on Box:
Cisco IMC Emulator Downloads - Box
________________________________________________________________________
Previous Releases
Release 3.0(3a)
Cisco IMC Platform Emulator – version 3.0(3a). This release adds many new features, including the following:
- VIC Configuration
- BIOS Configuration
- WebUI based Emulator configuration (previously, this was CLI only)
- Configurable IMC Emulator MAC Address and Serial Number
- Various bug fixes
The Cisco IMC Platform Emulator is now bundled into a single .zip file. The package needs to be unpacked as before, and uses a “launch.sh” script in the root directory (cimc_emulator-3.0.3a) to launch the emulator. Individual platforms can still be accessed using the CLI by navigating to cimc_emulator-3.0.3a\prod\<desired platform>. Please reference the latest user guide for additional details.
You can access the Cisco IMC Emulator platform images from the link below:
Cisco IMC Emulator - Box
The user guide can be found as part of the .zip file and is also posted below.
Initial Release 3.0(1c):
The emulator runs from a 64bit linux host, and was tested with RHEL 7.0 and CentOS 6.5.  When using Windows, you must ensure Virtual Box software is installed, and an appropriate 64 bit linux OS is provided. The host machine must have the tunctl and brctl commands to create the tap network and the bridge network, respectively (these are used for accessing/communicating with the emulated IMC). There is also a configuration file that can be modified in real time, and allows users to adjust various IMC sensor values, mimic faults, and perform device state changes.
The video below provides an overview of the Cisco IMC Emulator and also explains how to install the utility.
Video Link : 16038
This next video outlines general use cases for the IMC Emulator, while also stepping through some examples.
Video Link : 16039
RamblingPSTech
The Box link is currently broken. Can this be re-activated?
Chauhan Rahul
Hi Greg,
Hope you are doing well.
Is this emulator still available for download?
Greg Wilkinson
Please try to download now.
Chauhan Rahul
Thanks Greg
It's available for download.
nbuya0617
Hello @Greg Wilkinson ,
The box download seem to be broken again. Are you able to assist?
Greg Wilkinson
Links should be enabled.
SamUrai
Any chance to get a 4.2x version?
tomoki.hatano
let me download the emulator
Thank you
JANG71478
Hi Greg,
the links are broken again. Any chance you can repost them?
Much appreciated!
BR, Jack
nbuya0617
Hi @Greg Wilkinson,
Would it be possible to provide an updated/patched version of the emulators? The instance today has many vulnerabilities as detected by our scanners. Also, could the IMC versions be updated to the latest releases for proper integration testing?
As you can see, these are great resources for the community, but the security risks are far too high to keep a running instance on most networks today.
Thanks for your continued support!
Greg Wilkinson
Hello everyone, please be aware that this page will be removed at the end of this week. The IMC Emulator has not received any updates in several years, and as such will be decommissioned. Thank you for all the support and we hope you found the tool useful.
SamUrai
Does this emulator provide server OS bootup support for the supported UCS servers ?  If it does, can someone please share it?
andreluizsh
Hi Greg! I hope you're okay.
I'm currently studying for the CCIE DC and was wondering if it would be possible to share an updated link to the IMC Emulator.
I understand that the product has been discontinued, but it would still help me in my studies and simulations.
Thanks a lot!
