Unified Computing System Discussions
Engage with peers and experts on UCS and HyperFlex topics.
Cisco UCS 240 M8 Server - CIMC configured but not working facing the same issue in five servers. Connected peer to peer still same issue so did factory reset ping came for few seconds then again, it was not working. Does anyone face this kind of issu...
Hi all,I have two standalone C-series servers (UCS220 M7) with a VIC 15237 MLOM (100G, QSFP-100G-LR-S) connected directly to IOS-XR routers.The vNIC is in Trunk mode with no default VLAN, VNTAG mode is disabled, and Physical NIC Mode is on so that Li...
Hello,I need to change management networks and IP addresses that I'm using to access UCS-M and my blades.For UCS-M is it as simple as changing Management Interfaces on the Admin tab or do I need change IP addresses on each FI via CLI?Also, I'm using ...
Hi.I am working on an upcoming UCS FI 6200 to 64108 migration running infrastructure firmware 4.1(3m).Regarding the existing ports, this UCS domain is using direct-attached iSCSI storage using appliance ports. Are there any additional steps that need...
jmmorrell by • Frequent Visitor
  • 307 Views
  • 2 replies
Hello All,I have a C220 M6N that will not power on. It appears the Intel ME Node Manager is "unhealthy or unresponsive" per the log and it's causing the server to not power on. I also have a corrupted BIOS, see logs below.Critical F1707 sys/rack-unit...
krussell by • Frequent Visitor
  • 200 Views
  • 0 replies
