on 03-27-2015 07:45 PM
Cisco UCS Platform Emulator, Release 3.0(2cPE1)
CONFIGURATION IMPORT NOTE: Importing configuration backups (All, System, or Logical) taken from the UCS Platform Emulator (UCSPE) to physical UCS Manager domains is not recommended or supported by Cisco TAC. UCSPE backups should only be imported to UCSPE domains.
The UCS Platform Emulator version 3.0(2cPE1) is a platform release that ONLY supports the 6324 Fabric Interconnect based domains. No other Fabric Interconnect (6100 / 6200) will work with this UCSPE.
New Hardware Features
Cisco UCS Platform Emulator, Release 3.0(2cPE1), adds support for the following new hardware:
– Modifications to the VM Console login
– Modifications to the VM Console Options Menu
– Modifications to the Network Settings
– Modifications to the System Settings
– More details added to the Status Summary display
Known Limitations
Cisco UCS Platform Emulator, Release 3.0(2cPE1) has the following limitations:
NOTE: From UCS PE 2.2(1bPE1) onwards, UCS PE supports uploading the B-Series and C-Series server firmware bundles. Because of the large file sizes of the firmware bundles, UCS PE only supports uploading of only the stripped-down versions (attached to this document), which includes only the firmware metadata but not the actual firmware itself in the binaries. The stripped-down version of the firwmare bundles which contain metadata only of the B-series and C-series server firmware is reduced to approximately 50 kB in size.
even I have the same issue cannot continue downloading after ~ 90 - 100 MB.
the download issue happened to me last week too! I tried again and it went through okay...
Cannot download this file ,download stops after 100M, anyway to download ,can you share to me
PS, I'm China , i want to UCSPE_3.0.2cPE1.ova
Thank you very much.
Very slow download...
Is available HTML5 interface for standard Fabric? Or only for MINI?
link download stop 50 mb
Only for the UCS Manager 3.x
All the classic run on 2.x and do not support the HTML 5 web interface.
Download stops after few MBs!! So many feedback for the same issue!! Can't it be fixed ![]()
Close all other windows in your web browser and don't do any other thing, I have the same problem the download stop after 50 or less MBs but after that i let the download running alone and it works fine and i repeat the process in 2 others PCs.
reach out to me directly at ericwill at cisco dot com and I can help you out.
You should have a torrent file as they are huge in size
After the latest version of the emulator was downloaded and deployed on VMWare ESXi 5.5, I found that the Emulator doesn't provide ability to use external fabric interconnect 6248. The emulator offers only the embedded fabric interconnect 6324. Is this by design or this is a bug
The UCS Manager 3.0 release is a release only for UCS Mini, which ONLY supports the 6324 FI’s. The real UCS Manager software does not support 6100 / 6200 FI’s with 3.0(x) yet.
Eric
Thank You,
Does the UCS team have plans to release another version that will support both FI devices, traditional 6248 / 6296 and the 6324 mini?
Also, Is it possible to integrate the UCS emulator with the UCS Central management appliance? I did try to connect UCS Emulator 3.0.1 with the UCS Central 1.3.1b? It will be a great priceless experience and will have better acceptance by the IT folks who work for the CISCO existing UCS clients as well as new clients that plan to deploy UCS
Yes we have plans to release a future release of UCS Manager in the 3.x code train that will support traditional 6200 FI’s and 6300 based UCS Mini. Any UCSM version (real or UCSPE) post 2.1.2a can connect to UCS Central. I would recommend a minimum version of UCS Manager 2.1.3a though.
Eric
I created a VM set up where UCS Manager 3.0 version installed...now i am planning CIMC installation on this setup.
Is it possible on this ...because i follow the installation process of CIMC and stuck on the step 1 where go to the KVM console ....Is there any other way so that i can install CIMC
