ericwill
Direct YouTube Link:  Demystifying Monitoring for Cisco UCS Manager and Standalone C-Series Servers - YouTube
Google Plus Link:  Google+
In case you were not able to attend, members of our UCS TME team hosted a deep dive discussion on how monitoring really works under the covers in both UCS Manager and Standalone C-Series Servers.  In this session we touched on best practices, recommendations, demonstrations, and pointers to relevant reference documentation for monitoring Cisco UCS Servers.
The Cisco UCS Monitoring Resource Handbookis a monitoring reference guide that was developed to supplement this session.
Participants:
Eric Williams, Moderator, Technical Marketing Engineer, Cisco
Jeff Foster, Technical Marketing Engineer, Cisco
Jason Shaw, Technical Marketing Engineer, Cisco
Links Relevant to this session:
UCS Manager MIB Reference Guide: http://www.cisco.com/en/US/docs/unified_computing/ucs/sw/mib/b-series/b_UCS_MIBRef.html
UCS Manager Fault Reference Guide: http://www.cisco.com/en/US/docs/unified_computing/ucs/ts/faults/reference/UCSFaultsRef.pdf
C-Series MIB Reference Guide: http://www.cisco.com/en/US/docs/unified_computing/ucs/sw/mib/c-series/b_UCS_Standalone_C-Series_MIBRef.pdf
C-Series Fault Reference Guide: http://www.cisco.com/en/US/docs/unified_computing/ucs/c/sw/fault/reference/guide/CIMC_Fault_codes.pdf
Monitoring UCS Manager with Syslog:
http://www.cisco.com/en/US/docs/unified_computing/ucs/sw/ucsm_syslog/b_Monitoring_Cisco_UCSM_Using_Syslog.pdf
To learn more about Cisco UCS Manager and Standalone C-Series:
Cisco UCS Communities:  http://communities.cisco.com/ucs
Cisco Developed Integrations Communities:  http://communities.cisco.com/ucsintegrations
Cisco UCS Manager: http://www.cisco.com/en/US/products/ps10281/index.html
Cisco UCS Central: http://www.cisco.com/en/US/products/ps12502/index.html
Cisco UCS Management (Blog): http://blogs.cisco.com/datacenter/cisco-ucs-management/
hetalsoni
Eric,Jeff,Jason
Very informative--looking forward for next sesssion...
Anuj Thapa
Is somebody able to download or open MIB reference Guide,
ericwill
It's a known issue with our documentation team, and they are working to fix it ASAP.  Keep watching the link, as it is correct, we are just working on fixing the backend issue.
ericwill
We have a workaround link that should get you the document while we continue to fix the backend document CMS issue.
Try this link, which worked for me -> MIB Reference for Cisco UCS Manager - Cisco
Anuj Thapa
Thanks Eric. That works like charm.
