Codecs problem
lnofal
Community Member
Hello:
My configuration is
OpenPhone-->WAN-->Gtw3660-->PSTN--------------->Phone
Prepaid E1 (America-alaw)
Tones : Openphone ========= Ok =========> Gateway
Prompts: OpenPhone <======== Ok ========== Gateway
Voice: OpenPhone ====== It's Ok ====> Phone
voice: OpenPhone <===== Don't hear ===== Phone
The application answer the call fine. The prompt's play is ok and the call is established.
The PSTN side hear the audio, but the openPhone side can't hear.
The same situation occurrs when I set codecs G711 ulaw/alaw.
Help me, please.
Thanks.
Leonardo
milay
Is this the OpenPhone you are refering to?:
http://www.linuxjournal.com/article/3512
Do you have a sniffer trace or GW traces to show the audio setup?
Mike
lnofal
Community Member
Yes
> the audio setup?
I'm using EtherReal on the OpenPhone side (client),
and on the gateway side I'm loging with Syslog.
When the comunication is established, and from openphone side we don't hear audio, the Syslog does not register any errors.
Below Is an RTP incoming packet in the openphone side, originating from the gateway, but not udible.
Frame 11819 (214 bytes on wire, 214 bytes captured)
Arrival Time: Feb 18, 2005 15:05:50.292909000
Time delta from previous packet: 0.004445000 seconds
Time since reference or first frame: 65.639335000 seconds
Frame Number: 11819
Packet Length: 214 bytes
Capture Length: 214 bytes
Ethernet II, Src: 00:01:42:5b:7b:20, Dst: 00:0d:61:3a:11:b8
Destination: 00:0d:61:3a:11:b8 (200.16.194.249)
Source: 00:01:42:5b:7b:20 (200.16.194.253)
Type: IP (0x0800)
Internet Protocol,
Src Addr: 200.16.194.1 (200.16.194.1),
Dst Addr: 200.16.194.249 (200.16.194.249)
Version: 4
Header length: 20 bytes
Differentiated Services Field: 0x00 (DSCP 0x00: Default; ECN: 0x00)
0000 00.. = Differentiated Services Codepoint: Default (0x00)
.... ..0. = ECN-Capable Transport (ECT): 0
.... ...0 = ECN-CE: 0
Total Length: 200
Identification: 0xc834 (51252)
Flags: 0x00
0... = Reserved bit: Not set
.0.. = Don't fragment: Not set
..0. = More fragments: Not set
Fragment offset: 0
Time to live: 253
Protocol: UDP (0x11)
Header checksum: 0xdfd3 (correct)
Source: 200.16.194.1 (200.16.194.1)
Destination: 200.16.194.249 (200.16.194.249)
User Datagram Protocol, Src Port: 17068 (17068), Dst Port: 4020 (4020)
Source port: 17068 (17068)
Destination port: 4020 (4020)
Length: 180
Checksum: 0x0000 (none)
Real-Time Transport Protocol
10.. .... = Version: RFC 1889 Version (2)
..0. .... = Padding: False
...0 .... = Extension: False
.... 0000 = Contributing source identifiers count: 0
0... .... = Marker: False
.000 0000 = Payload type: ITU-T G.711 PCMU (0)
Sequence number: 9333
Timestamp: 2239741042
Synchronization Source identifier: 528663041
Payload: F5F5EFE9EE7AFFF2F7F7FE746F76706D...
Thanks...
