UC540 Error Message "network error detecting"
dwilson1031
Our customer has UC540 that has been in for several months.  All phones are 504s and the switch is a ESW 520 24 port PoE unit.  They have reported that the phones are displaying the following error message: network error detecting.  Then the message will change to connecting.
After 4 or 5 minutes everything is ok.  They aree getting this error message multiple times.  Has anyone run into this problem and found a fix?
18 Replies 18
ifradsham
We are having a similar problem on a UC560.  The phones show network error and then connecting.  But in our case the system doesn't come back up; it just freezes and we have to power cycle the box.  We just did an upgrade to the latest software but no fix.  There are no crash logs, nothing.  The system just seems to lock up.  We opened a TAC case but no resolution was found.  So we are RMA the box
The customer is running out of patience with the frequent outages.  And, as a Cisco partner, this doesn't inspire me to go pushing the UC5xx solution.
SMB tech support removed the "lock" from the ESW520-24P ports.  SInce doing this the customer has indicated that the "network error detecting" message has not reoccurred.
David Trad
Hi There,
I would like to ask a couple of questions, mainly to get an insight into the issue you guys are having.
  1. What is the DHCP Controller is it the UC-500 or is there an SBS server?
    If there is an SBS server there have you configured the UC-500 to operate correctly within that environment??
  2. What devices are plugged into the ESW-500 Series switch? Is it just phones and PC's plugged into the back of the phones??
    If the answer is the latter, when this network issue happens does the PC's lose their network connectivity as well?
  3. How often is this happening? Is it entirely random or can you re-produce the issue??
  4. Is this happening to every single phone or is it random phones, or particular phones are most common?
  5. When this happens have you checked to see if the switch port lights change from green to orange or if the switch is showing an error?
    If you can maybe check for this next time it happens, would be good to see if the switch is erroring out, maybe even check it via web gui
  6. Do the phones have the latest Firmware on them? Have you asked SBCS for a Beta Firmware for SPA phones?
    Consider the possibility they are aware of the issue and may have a Beta Firmware for the phones
  7. How many phones are plugged into the system?
    Would love to get a census on this and see if there is a pattern being formed here based on how many seats
The more information I can get as in as much detail per question, the better understanding I can try to get of the actual issue, this way I can try to avoid it and or I can at least attempt to try and replicate the problem.
Look forward to your reply guys, hope you can provide the detailed information.
Cheers,
David.
Cheers, David Trad. **When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
Hi I work with the original poster on this project and can help answer these qs for you.
As of tonight, the uc560 is still crashing every few hours- and today the business is not open, so little to no load on it.
Q- can uc500 support RSTP? ESW switches can do rapid/multi- I cant see how uc500 can do anything other than stp on/off. Its' three gig ports each set as trunk to poe switches. SBCS smart call conne op console standalone 1.6 in use as well. (if that is a factor)
Answers inline:
A: dhcp (192.168.100.0 data vlan 1) provided by windows server. In this case the entire range for the data vlan is excluded. The uc560 does lease out phone ips though. (10.1.1.x)
  1. What devices are plugged into the ESW-500 Series switch? Is it just phones and PC's plugged into the back of the phones??
A: there are 4 esw switches, 3 poe and one one non poe for servers etc. The switches are fine- it is the uc560 that goes offline- ie you can't even console to it- it is hung. Power reset is necessary.No other desktop switches obvious to be found.
  1. How often is this happening? Is it entirely random or can you re-produce the issue??
A: We thought could reproduce the issue as anytime a call was made to the acd pilot- it would crash. We since removed the acd setup and uprgaded. It no longer crashes (on acd), but still randomly crashes. It will crash ervery 3- 4 hrs reliably- night or day.
  1. Is this happening to every single phone or is it random phones, or particular phones are most common?
A: all phones as uc560 is offline.
  1. When  this happens have you checked to see if the switch port lights change  from green to orange or if the switch is showing an error?
A: Switches are fine. Uc560 is offline and non responsive- no crash log, no activity no console . Sometimes it reloads on its own, usually requres powere reset.
  1. Do the phones have the latest Firmware on them? Have you asked SBCS for a Beta Firmware for SPA phones?
A: yes, has been upgraded to 8.1 with 7.46 firmware (prevoius 8.02 and 7.42)
  1. How many phones are plugged into the system?
A:47 sets 46 508, 1 525
thanks
Jason
Hi Jason,
Thanks for your fast response
I have seen something like this before or at least close to it, but that was a long time ago and it happened with both an ISR 2810 and a UC-520 running same version IOS (24 T2) but we are well and truly past this now so cant see it being the same issue, although I am not saying it isn't.
It manifest itself in two ways:
  1. IOS had a memory leak and i think it was due to one particular area (Cant remember it), and as more phones were registered as being on a call the system would lock itself up and phones would then just reboot, occasionally you would see a quick flash of network error on the screen before they reboot themselves, but there was a crush dump on the IOS to see this and analyze the data
  2. System would run out of resources or had bad memory in it, it didn't matter as it produced the same result regardless of which one it was, there was a bad batch of UC-520 that hit the Australian market (As much as Cisco denied it it was present), they would be fine if you only had a couple of handsets registered to the system, when diagnosing it in the lab we couldn't get it to fault, until by fluke I plugged in almost the same amount of phones and the issue reared it's ugly head, I then had something to report back to TAC (Not SMB Support at the time), and this problem could be replicated on more than one machine.
Now before I go off on a tangent with this, I would suggest sticking to the path of SMB support working on this. The issue you could be having could be entirely different and its origins may be from something else, it's just the way you explain it that imediatly struck me as a ghost from the past, in all cases there was no way to SSH/Telnet or even Console into the system if it was a full lock-up, a complete reboot was required.
Couple more questions:
  1. What type of service are you using? PSTN/ISDN/PRI?
  2. When the box locks up are all these lights locking up as well? If there is activity on other ports/services but ones in particular are locking up can you indicate which ones they are??
It is a long shot but I thought I better ask this, it doesn't matter if they are add-on cards or in-built it would be good to get a glimpse of this, even the switch port lights if you have the standard inbuilt into it as well, check to see if they lock-up being in a constant lit mode.
Cheers,
David.
The PSTN connection is a PRI.
With respect to the lights, I will try to get the info, but the system is remote so it's hard to get an accurate reading on that.
I would also like you to try calling into STAC and telling them to disable the DHCP Pool for the data;"no ip dhcp pool data".  Secondly, make sure your DNS is set the the SBS server and third, put in two routes back to the UC540 for CUE to 10.1.10.1 and 10.1.10.2.  See if that helps.
Also, try the latest firmware on the phones either by downloading 7.4.7 for the SPA phones or using CCA 3.0.1 that has the 7.4.8 phone load included.
All the best,
Robcast
Rob,
Thank you for directing the partner to the SBSC since we dont support CLI in the CCA model, but the SBSC can escalate issues to the BU for next release inclusion and may also grant the CLI provided it doesnt impede CCA or OM.
Please double check the SWP 8.1.0, which I am sure contains 7-4-6 phone FW for SPAs.  You have to go to CCO to download the latest SPA phone FW which Friday was 7-4-7.  CCA 3.0.1 is the latest, but has no phone loads as you know.
7-4-8 is due end of this week I was told, but thats based on successful testing.
Steve
Hi Steve, I understand the directive to only use the CCA from one point of view.  However, certain things can only be done via the CLI.  For example, if a customer wants to maintain a data DHCP scope on their server rather than the UC500, the only way to eliminate the data dhcp from the UC560 is via the CLI.  So how can partners be expected to use only the CCA (and stay compliant with getting support) when such a common task can't be done via the CCA?
Thanks.
Understand that we have come to realize that we can not offer the CLI capability withUC500 for the small Select Certified / SMB specialized partner, but will for more advanced specializations.  Do you need a copy of that policy statement?  It's on the Partner Zone section of the community.
https://supportforums.cisco.com/docs/DOC-14855
The problem for you and us is the ability to offer complete wide open CLI coexistence with CCA.  There are too many permutations of possible CLI that could be used that would have to integrated, and that becomes unmanageable & unprofitable for this product, which as of March 1st has an additional 15% discount.
We do feel like this product it the most robust & flexible (comparing to UC320 & BE3000, which are locked down with no CLI) and we do accept input for future CCA releases (CCA 3.1 should have the disable DHCP feature for example) and we encourage you to review the FDG (feature description guide contains what the product supports) BEFORE you sell the product.
We also welcome your calls to SBSC to explain what you need and see if there are any potential safe oob CLI that may be implemented as a stop gap, if possible.
I hope you understand this product is a great offer with CCA and with advanced UC certification can also work with CLI only (no CCA and no OM) if that's what you really need.
Steve DiStefano
Technical Solutions Architect - Partner Sales, USA
Cisco Systems
7025 Kit Creek Road
Research Triangle Park
North Carolina, 27709
1.919.392.6219
sdistef@cisco. com
www.cisco.com/smb
Message was edited by: Steven DiStefano: Added link to Jan 21st CCA/ CLI policy statement from Cisco VPs.
Hi, we removed the data pool from dhcp as it is not used.
DNS is given out in the scope by the windows box. No dns used in phone lease.
There are no routes needed-the uc560 is the default gateway for the subnet. It routes between its vlans itself as connected routes.
This has been happening for three weeks now and is getting more frequent. Phone loads aren't relative as they have been changed and mulitple models are affected. The entire uc560 goes offline- dead. No console access until a power reset.
Originally we thought this was a b-acd bug as dialing an acd pilot crashed it, but after removing acd pilot, it still randomly crashes every 3-6 hrs. Seems to be more frequent during busy time of the day.
To compound matters, when it crashes, the attendant console gets out of whack, and needs a reboot, a manual clearing of the tapi registration and sometimes, the main # disappears from the attendant console setup.
This is beyond frustration.
This is a serious issue and you should open a case ASAP.
We did last wednesday. We requested RMA friday am and are waiting on the replacement box.
I am really hoping a hardware swap out will fix this.
Hi Jason,
Good luck with this, can you keep us posted on how this goes as I am interested to know if the new box resolve the issue
Cheers,
David.
