System abend. Don't use EMS & MUID macro as part of Profile_Rul URL (SPA50x, fw 7.5.3)
Dan Lukes
EMS and/or MUID macro is used within Profile_Rule URL:
<Profile_Rule ua="na">https://test.....cz/Provisioning.php?EMS=$EMS;MUID=$MUID</Profile_rule>
On first resync (either periodic or use SIP NOTIFY) the phone will reboot - then keep rebooting again and again. Reset to factory default will stop it.
The syslog shows:
18:08:37.471304 IP (tos 0x0, ttl 64, id 114, offset 0, flags [none], proto UDP (17), length 315)
    10....8.1024 > 10....1.514: SYSLOG, length: 16
        Facility local3 (19), Severity debug (7)
        Msg: pbs 230912\0x0a
18:08:37.472220 IP (tos 0x0, ttl 64, id 115, offset 0, flags [none], proto UDP (17), length 315)
    10....1024 > 10....1.514: SYSLOG, length: 287
        Facility local0 (16), Severity info (6)
        Msg: SPA508G e0:..:..:..:..:9d -- Requesting resync https://19....2:443/Provisioning.php?EMS=mobile;MUID=0101\0x0a
18:08:37.472602 IP (tos 0x0, ttl 64, id 116, offset 0, flags [none], proto UDP (17), length 61)
    10....8.1024 > 10.....1.514: SYSLOG, length: 33
        Msg: FMM >>>> Requesting profile\0x0a
18:08:37.473205 IP (tos 0x0, ttl 64, id 117, offset 0, flags [none], proto UDP (17), length 71)
    10....8.1024 > 10....1.514: SYSLOG, length: 43
        Facility kernel (0), Severity error (3)
        Msg: <<<signal:10 received from thread FLASH\0x0a
18:08:37.474043 IP (tos 0x0, ttl 64, id 119, offset 0, flags [none], proto UDP (17), length 77)
    10....8.1024 > 10....1.514: SYSLOG, length: 49
        Msg: request reboot type=4 reason=System 4(8000)\0x0a
The same configuration file with no EMS and MUID macro within Profile_Rule works as expected with no problem.
Also, both EMS and MUID macro can be used id Report_Rule with no problem.
It is another bug from pile of bugs in 7.5.3 firmware. Several hours of wasted time. Hope it help to someone else to save it's time.
nseto
Level 6
Level 6
I've entered this issue, with ID being CSCue57774 so dev will take care of this in the future release.  Thanks.
nseto
Level 6
Level 6
Dan, dev has resolved this and will be in the 7.5.5 release.  Thanks for the test account.
