Buenas tenemos un problema que no repica la ext 5000 cuando llaman de la calle al numero que se tiene en el puerto FXO
dial-peer voice 1 pots
trunkgroup OTAMA
description LLAMADAS SALIENTES CANTV
preference 1
destination-pattern 9.T
dial-peer voice 2000 voip
destination-pattern 2...
session protocol sipv2
session target ipv4:172.20.20.21
dtmf-relay sip-notify rtp-nte
codec g711ulaw
no vad
dial-peer voice 7000 voip
description LLAMADAS INTERNAS Valencia
destination-pattern 70..
session target ipv4:10.20.20.8
dtmf-relay h245-signal rtp-nte cisco-rtp
codec g711ulaw
dial-peer voice 6000 voip
session target ipv4:10.10.10.1
dtmf-relay rtp-nte
codec g729br8
dial-peer voice 200 voip
description **Llamadas salientes por el SIP Trunk**
destination-pattern 60..
voice-class codec 1
dtmf-relay rtp-nte cisco-rtp h245-signal
no vad
dial-peer voice 8000 voip
description Llamadas internas Cisco Jabber
destination-pattern 80..
codec g711ulaw
dial-peer voice 3 pots
translation-profile incoming ENTRANTE-CPA
incoming called-number 64..
supplementary-service pass-through
no digit-strip
direct-inward-dial
port 0/2/0
forward-digits all
voice-port 0/2/0
trunk-group OTAMA
no battery-reversal
input gain 14
output attenuation -6
connection plar 5000
caller-id enable
cabe destacar que poseo un CUCM y esto que muestro anteriormente esta en el Router.
