cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
Respuestas
No se pueden completar las conferencias
rlopez
buen dia,
tengo un problema para configurar las conferencias en ccme, estoy trabajando con la version 12.4(24)T de IOS y la 7.1 de ccme, estuve revisando varios ejemplos de configuracion pero el problema es que no me acepta los comandos. esta es la salida del show inventory
NAME: "2811 chassis", DESCR: "2811 chassis"
PID: CISCO2811         , VID: V07 , SN: FTX1345A07C
NAME: "2nd generation four port FXO voice interface daughtercard on Slot 0 SubSlot 0", DESCR: "2nd generation four port FXO voice interface daughtercard"
PID: VIC2-4FXO         , VID: V01 , SN: FOC10351G13
NAME: "2nd generation four port FXO voice interface daughtercard on Slot 0 SubSlot 1", DESCR: "2nd generation four port FXO voice interface daughtercard"
PID: VIC2-4FXO         , VID: V03 , SN: FOC134830FY
NAME: "PVDMII DSP SIMM with one DSP on Slot 0 SubSlot 4", DESCR: "PVDMII DSP SIMM with one DSP"
PID: PVDM2-16          , VID: V01 , SN: FOC13381K3M
NAME: "PVDMII DSP SIMM with one DSP with half channel capcity on Slot 0 SubSlot 5", DESCR: "PVDMII DSP SIMM with one DSP with half channel capcity"
PID: PVDM2-8           , VID: V01 , SN: FOC11441JEA
NAME: "AIM Service Engine 1", DESCR: "AIM Service Engine"
PID: AIM-CUE           , VID: V03 , SN: FOC12166CK9
NAME: "High Density Voice on Slot 1", DESCR: "High Density Voice"
PID:                   , VID: 1.1, SN: JAD070702M0
NAME: "E1 (1 Port) Multi-Flex Trunk WAN Daughter Card on Slot 1 SubSlot 0", DESCR: "E1 (1 Port) Multi-Flex Trunk WAN Daughter Card"
PID: VWIC-1MFT-E1=     , VID: 1.0, SN: 30452099
NAME: "PVDM 3-C549 Simm on Slot 1 SubSlot 1", DESCR: "PVDM 3-C549 Simm"
PID: PVDM-12=          , VID:    , SN:
NAME: "PVDM 3-C549 Simm on Slot 1 SubSlot 2", DESCR: "PVDM 3-C549 Simm"
NAME: "PVDM 3-C549 Simm on Slot 1 SubSlot 3", DESCR: "PVDM 3-C549 Simm"
los comandos que quiero aplicar, de acuerdo a las guias de configuracion son los siguientes
sccp local GigabitEthernet0/0
sccp ccm 10.15.15.1 identifier 1 version 7.0 ------------------------> No lo acepta solo me deja colocar el comando sccp ccm 192.168.20.253 priority 1
sccp ccm group 1  --------------------------------------> NO lo acepta
associate ccm 1 priority 1
associate profile 101 register confer1
associate profile 103 register xcode1
dspfarm profile 103 transcode ---------------------------> NO lo acepta
codec g711ulaw
codec g711alaw
codec g729r8
maximum sessions 6
associate application SCCP
dspfarm profile 101 conference ---------------------------> NO lo acepta
codec g711ulaw
codec g711alaw
codec g729r8
maximum sessions 5
Alguien me puede indicar por que no me acepta los comandos y que debo hacer para poder configurar las conferencias.
de antemano gracias.
3 RESPUESTAS 3
Hola,
Podrias intentar deshabilitar sccp e intentarlo? Que error o mensaje te aparece cuando introduces esos comandos? Intenta habilitar tambien el dsp services dspfarm en la voice-card 0
Quedo en espera de tu respuesta.
Saludos
hola Pablo,
gracias por tu respuesta, he deshabilitado sccp e intente habilitar dsp services dspfarm en voice-card 0 y estos son los mensajes que me manda:
dspfarm is configured for NM-HDV card.
Only one dspfarm type is allowed.
y solo queda la configuracion asi
voice-card 1
dspfarm
para los otros comandos estos son los mensajes que manda
Router(config)#dspfarm pro?
% Unrecognized command
Router(config)#dsp ?
  codec       Configure codec related parameters for DSPFARM service
  confbridge  Specify the conferencing related parameters values
  connection  Specify the dspfarm connection related parameters values
  rtp         Specify the RTP related parameters values
  transcoder  Specify the transcoding related parameters values
espero me puedas ayudar a encontrar la solucion a este detalle.
gracias.
Hola Raul:
Checando tu configuración y el show inventory, las dsps que tratas de usar son las de la NMHDV con el ci c549, el cual se configura de la siguiente manera:
sccp local FastEthernet0/0
sccp
sccp ccm 10.1.1.30 priority 1
sccp ccm 10.1.1.0 priority 2
sccp switchback timeout guard 180
dspfarm transcoder maximum sessions 4
dspfarm confbridge maximum sessions 1
Para que configures con identifier y con profiles necesitas pvdm2, las cuales segun veo ya no tienes disponibles puesto que estan ya utilizadas por los puertos FXO.
Considero que debes agregar modulos de pvdm2 en el slot0 del router para configurar profiles y tener mas recursos para conferencia.
Saludos
Guillermo
