cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
Respuestas
Test/Update Audio Paths in CME
A3XN
There is a command in CLI to test stored audios (flash:) in CME?
If this is not possible, CLI command to update routes (while getting IP addresses) so that physical IP phones have the correct information and don't fail.
Thanks for the info
1 SOLUCIÓN ACEPTADA
Soluciones aceptadas
A3XN
After solving the problem, I came to the conclusion that the limitation is the free memory of CME.
Example:
Usage Degradation Error... Audios need to be updated for IP phones to recover from errors  (no sounds).
The audios were still intact (they have been stored in CME for more than 2 years), I only updated audios from the IP phones.
+ Summarizing... No commands needed to test stored files
Ver la solución en mensaje original publicado
1 RESPUESTA 1
A3XN
Example:
