Help with VPN site-to-site under other VPN
Hello Guys,
I need a help with this scenario.
Branch --> HQ --> Site Remote, where:
Branch: Internal = 192.168.50.0/24
HQ: Internal = 192.168.40.0/24
Site Remote = 10.175.26.0/24
Branch + HQ = Both ASA with ESP-3DES-MD5. (Here, we are using the real LAN IP range for encryption domain)
HQ + Site Remote = My side ASA with ESP-AES-256-SHA. (Here, to reach the Site remote 10.175.26.0/24 we are NAT our LAN IP range to 172.18.0.10, so the encryption domain is 172.18.0.10 --> 10.175.26.0/24)
Now, we need that Branch reachs the Remote Site, under the VPN with Branch to HQ and HQ to Remote Site.
My actions:
Branch Firewall:
 - In the VPN Site to Site configuration I added the 10.175.26.0/24 for Tunnel between Branch and HQ in the Remote Network.
 - I added the EXEMPT for 10.175.26.0/24 in the inside.
HQ Firewall:
 - I created a Dynamic Policy in the outside from source = Branch IP range to = Site Remote IP range translated to 172.18.0.10.
I already have it working for another Site Remote, but that another has IPsec proposal ESP-3DES-MD5. (the same of Branch) I do not know if it is the problem, but I tried to use both proposal, together, 3DES-MD5 and AES-256-SHA.
Firewall rules are ok too.
Where are the mistake in that configuration?
Diego
good
put solved in this post
9 Replies 9
marziano77
hi
post your config
Follow attached!
The network that I need to reach from Branch is "name 10.175.26.0 REDE_Client"
The Tunnel group of the Client is 200.200.200.200
The NAT IP from my network to reach client is 172.19.0.5
hi seg
I looked very quick HQ config
and I saw that your peer(vpn_client) dont match any crypto map.
and this dont allow phase2.
I have not seen anything else
you double-check the config on both sides first.
My bad. I forgot to change it. The crypto map is number 4
diego, your config is wrong also in branch config.
you have only an tunnel group whit ip 177.7.7.7 but crypto map is blind to 177.135.122.70 FWL_Matriz.
In the HQ log I can see it...
3May 13 201417:23:08713061    Group = 189.7.7.7, IP = 189..7.7.7, Rejecting IPSec tunnel: no matching crypto map entry for remote proxy 192.168.90.0/255.255.255.0/0/0 local proxy 10.175.26.23/255.255.255.255/0/0 on interface outside
What do you want me to say
 you have posted a different conf,than your debug
yeah, probably because I changed it before send...
well... I recreated the tunnels and now it is working fine....
I think when we changed the outside IP and recreate the tunnels, maybe some dirty kept in the config... so I removed all and created it again..
thanks!!!
good
