05-08-2013 07:50 AM
Hello!
I am having problems with my VPN clients getting access to the networks over a MPLS infrastruture. I can reach these resources form my Core network (172.17.1.0/24) and my Wifi (172.17.100.0/24) but not from my VPN network (172.17.200.0/24). From the VPN I can reach the Wifi network (which is behind a router) and the rule that allows that also allows access to the other networks but for some reason it is not working.
When I ping inside the core network from VPN I can connect and get responses. When I ping to the Wifi network, I can get responses and connect to resources there. A tracert to the wifi network shows it hitting the core switch (a 3750 stack) @ 172.17.1.1, then the Wifi router (172.17.1.3) and then the host. A tracert to a resource on the MPLS network from the VPN shows a single entry (the destination host) and then 29 time outs but will not ping that resource nor connect.
I've posted all the info I can think of below. Any help appreciated.
*** Here is a tracert from a core network machine to the resource we need on the MPLS:
C:\Windows\system32>tracert 10.2.0.125
Tracing route to **************** [10.2.0.125]
over a maximum of 30 hops:
1 1 ms <1 ms <1 ms 172.17.1.1
2 1 ms <1 ms <1 ms 172.17.1.10
3 5 ms 5 ms 5 ms 192.168.0.13
4 31 ms 30 ms 31 ms 192.168.0.5
5 29 ms 30 ms 29 ms 192.168.0.6
6 29 ms 29 ms 29 ms 192.168.20.4
7 29 ms 29 ms 29 ms RV-TPA-CRMPROD [10.2.0.125]
Trace complete.
172.17.1.10 is the mpls router.
**** Here is the routing table (sh ip route) from the 3750 @ 172.17.1.1
Gateway of last resort is 172.17.1.2 to network 0.0.0.0
S 192.168.30.0/24 [1/0] via 172.17.1.10
172.17.0.0/24 is subnetted, 3 subnets
S 172.17.200.0 [1/0] via 172.17.1.2
C 172.17.1.0 is directly connected, Vlan20
S 172.17.100.0 [1/0] via 172.17.1.3
172.18.0.0/24 is subnetted, 1 subnets
S 172.18.1.0 [1/0] via 172.17.1.10
S 192.168.11.0/24 [1/0] via 172.17.1.10
10.0.0.0/8 is variably subnetted, 4 subnets, 2 masks
S 10.2.0.0/24 [1/0] via 172.17.1.10
S 10.10.10.0/24 [1/0] via 172.17.1.10
S 10.20.0.0/24 [1/0] via 172.17.1.10
S 10.3.0.128/25 [1/0] via 172.17.1.10
S 192.168.1.0/24 [1/0] via 172.17.1.10
S* 0.0.0.0/0 [1/0] via 172.17.1.2
*** Here is the firewall config (5510):
ASA Version 8.4(1)
hostname RVGW
domain-name ************
enable password b5aqRk/6.KRmypWW encrypted
passwd 1ems91jznlfZHhfU encrypted
names
interface Ethernet0/0
nameif Outside
security-level 10
ip address 5.29.79.10 255.255.255.248
interface Ethernet0/1
nameif Inside
security-level 100
ip address 172.17.1.2 255.255.255.0
interface Ethernet0/2
shutdown
no nameif
no security-level
no ip address
interface Ethernet0/3
shutdown
no nameif
no security-level
no ip address
interface Management0/0
nameif management
security-level 100
ip address 172.19.1.1 255.255.255.0
management-only
banner login RedV GW
ftp mode passive
dns server-group DefaultDNS
domain-name RedVector.com
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object network WiFi
subnet 172.17.100.0 255.255.255.0
description WiFi
object network inside-net
subnet 172.17.1.0 255.255.255.0
object network NOSPAM
host 172.17.1.60
object network BH2
host 172.17.1.60
object network EX2
host 172.17.1.61
description Internal Exchange / Outbound SMTP
object network Mail2
host 5.29.79.11
description Ext EX2
object network NETWORK_OBJ_172.17.1.240_28
subnet 172.17.1.240 255.255.255.240
object network NETWORK_OBJ_172.17.200.0_24
subnet 172.17.200.0 255.255.255.0
object network VPN-CLIENT
object-group service DM_INLINE_TCP_1 tcp
port-object eq www
port-object eq https
object-group network DM_INLINE_NETWORK_1
network-object object BH2
network-object object NOSPAM
object-group network VPN-CLIENT-PAT-SOURCE
description VPN-CLIENT-PAT-SOURCE
network-object object VPN-CLIENT
object-group network LAN-NETWORKS
network-object 10.10.10.0 255.255.255.0
network-object 10.2.0.0 255.255.255.0
network-object 10.3.0.0 255.255.255.0
network-object 172.17.100.0 255.255.255.0
network-object 172.18.1.0 255.255.255.0
network-object 192.168.1.0 255.255.255.0
network-object 192.168.11.0 255.255.255.0
network-object 192.168.30.0 255.255.255.0
object-group network VPN-POOL
network-object 172.17.200.0 255.255.255.0
object-group protocol DM_INLINE_PROTOCOL_1
protocol-object ip
protocol-object icmp
access-list Outside_access_in extended permit tcp any object-group DM_INLINE_NETWORK_1 eq smtp
access-list Outside_access_in extended permit tcp any object BH2 object-group DM_INLINE_TCP_1
access-list global_mpc extended permit ip any any
access-list Inside_access_in extended permit object-group DM_INLINE_PROTOCOL_1 any any
pager lines 24
logging enable
logging asdm informational
no logging message 106015
no logging message 313001
no logging message 313008
no logging message 106023
no logging message 710003
no logging message 106100
no logging message 302015
no logging message 302014
no logging message 302013
no logging message 302018
no logging message 302017
no logging message 302016
no logging message 302021
no logging message 302020
flow-export destination Inside 172.17.1.52 9996
mtu Outside 1500
mtu Inside 1500
mtu management 1500
ip local pool VPN 172.17.1.240-172.17.1.250 mask 255.255.255.0
ip local pool VPN2 172.17.200.100-172.17.200.200 mask 255.255.255.0
no failover
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
nat (Inside,Outside) source static EX2 Mail2
nat (Inside,Outside) source static any any destination static NETWORK_OBJ_172.17.1.240_28 NETWORK_OBJ_172.17.1.240_28
nat (Inside,Outside) source static any any destination static NETWORK_OBJ_172.17.200.0_24 NETWORK_OBJ_172.17.200.0_24
nat (Inside,Outside) source static inside-net inside-net destination static NETWORK_OBJ_172.17.1.240_28 NETWORK_OBJ_172.17.1.240_28
nat (Inside,Outside) source static LAN-NETWORKS LAN-NETWORKS destination static VPN-POOL VPN-POOL
nat (Inside,Outside) dynamic interface
nat (Inside,Outside) static 5.29.79.12
nat (Outside,Outside) after-auto source dynamic VPN-CLIENT-PAT-SOURCE interface
access-group Outside_access_in in interface Outside
access-group Inside_access_in in interface Inside
route Outside 0.0.0.0 0.0.0.0 5.29.79.9 1
route Inside 10.2.0.0 255.255.255.0 172.17.1.1 1
route Inside 10.3.0.0 255.255.255.128 172.17.1.1 1
route Inside 10.10.10.0 255.255.255.0 172.17.1.1 1
route Inside 172.17.100.0 255.255.255.0 172.17.1.3 1
route Inside 172.18.1.0 255.255.255.0 172.17.1.1 1
route Inside 192.168.1.0 255.255.255.0 172.17.1.1 1
route Inside 192.168.11.0 255.255.255.0 172.17.1.1 1
route Inside 192.168.30.0 255.255.255.0 172.17.1.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
aaa-server RedVec protocol ldap
aaa-server RedVec (Inside) host 172.17.1.41
ldap-base-dn DC=adrs1,DC=net
ldap-group-base-dn DC=adrs,DC=net
ldap-scope subtree
ldap-naming-attribute sAMAccountName
ldap-login-password *****
ldap-login-dn CN=Hanna\, Roger,OU=Humans,OU=WPLAdministrator,DC=adrs1,DC=net
server-type microsoft
aaa authentication ssh console LOCAL
http server enable
http 192.168.1.0 255.255.255.0 management
http 172.17.1.0 255.255.255.0 Inside
http 24.32.208.223 255.255.255.255 Outside
snmp-server host Inside 172.17.1.52 community *****
snmp-server location Server Room 3010
snmp-server contact Roger Hanna
snmp-server community *****
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
crypto ipsec ikev1 transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set ikev1 transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map Outside_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map Outside_map interface Outside
crypto ikev1 enable Outside
crypto ikev1 policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 30
authentication crack
encryption 3des
hash sha
group 2
lifetime 86400
telnet 172.17.1.0 255.255.255.0 Inside
telnet timeout 5
ssh 172.17.1.0 255.255.255.0 Inside
ssh timeout 5
console timeout 0
dhcpd address 172.17.1.100-172.17.1.200 Inside
dhcpd dns 172.17.1.41 172.17.1.42 interface Inside
dhcpd lease 100000 interface Inside
dhcpd domain adrs1.net interface Inside
threat-detection basic-threat
threat-detection statistics
threat-detection statistics tcp-intercept rate-interval 30 burst-rate 400 average-rate 200
webvpn
group-policy RedV internal
group-policy RedV attributes
wins-server value 172.17.1.41
dns-server value 172.17.1.41 172.17.1.42
vpn-tunnel-protocol ikev1
default-domain value ADRS1.NET
group-policy RedV_1 internal
group-policy RedV_1 attributes
split-tunnel-policy tunnelspecified
default-domain value adrs1.net
username rparker password FnbvAdOZxk4r40E5 encrypted privilege 15
username rparker attributes
vpn-group-policy RedV
username mhale password 2reWKpsLC5em3o1P encrypted privilege 0
username mhale attributes
username dcoletto password g53yRiEqpcYkSyYS encrypted privilege 0
username dcoletto attributes
username rhanna password Pd3E3vqnGmV84Ds2 encrypted privilege 15
username rhanna attributes
tunnel-group RedV type remote-access
tunnel-group RedV general-attributes
address-pool VPN2
authentication-server-group RedVec
default-group-policy RedV
tunnel-group RedV ipsec-attributes
ikev1 pre-shared-key *****
class-map global-class
match access-list global_mpc
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum client auto
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect ip-options
inspect icmp
class global-class
flow-export event-type all destination 172.17.1.52
service-policy global_policy global
prompt hostname context
call-home
profile CiscoTAC-1
no active
destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
destination address email callhome@cisco.com
destination transport-method http
subscribe-to-alert-group diagnostic
subscribe-to-alert-group environment
subscribe-to-alert-group inventory periodic monthly
subscribe-to-alert-group configuration periodic monthly
subscribe-to-alert-group telemetry periodic daily
hpm topN enable
Cryptochecksum:202ad58ba009fb24cbd119ed6d7237a9
05-08-2013 05:23 PM
Hi Roger,
I bet you already checked it, but does the MPLS end router has route to VPN client subnet 172.17.200.x (or default) pointing to core rtr)?
Also, if the MPLS link has any /30 subnet assigned, you may need to include that as well in Object group LAN-NETWORKS.
Thx
MS
05-09-2013 12:18 PM
I have asked that the route be added and have been rold it is.
Do I need to add each network to LAN-NETWORKS that is between me and the resource?
Thx for responding!
