Allocating Static IP for anyconnect remote clients on Cisco Router 2911
I am using Cisco 2911 router, I configured the remote client in that. I need to provide the static IP to the remote users instead of providing from the DHCP pool. is it possible?
Are you using RADIUS for authentication?
Are you using FlexVPN configuration?
no, it's not a flexvpn or radius configured. its anyconnect remote user VPN configured and allow only RDP session to VPN user. (and its working fine but I want to configure a static IP for each VPN user) please have a look the configuration below.
ROUTER#sh running-config
version 15.6
hostname ROUTER
aaa new-model
aaa authentication login webvpn local
aaa session-id commonf
no ip domain lookup
ip name-server 192.168.1.100
ip name-server 192.168.1.200
ip cef
no ipv6 cef
crypto pki trustpoint TRUST
enrollment selfsigned
ip-address 172.21.21.98
revocation-check crl
rsakeypair my_key 1024 1024
crypto pki certificate chain TRUST
certificate self-signed 01
30820237 308201A0 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
37313530 1806092A 864886F7 0D010902 160B4D4F 42494C59 2D31304D 42301906
092A8648 86F70D01 0908130C 38352E31 39342E36 372E3938 301E170D 31383039
username REVPN secret 5 $1$FVdD$jNnQJCGo/ZEAmpkp2qLta.
crypto vpn anyconnect flash0:/webvpn/anyconnect-win-4.6.02074-webdeploy-k9.pkg sequence 1
interface Loopback1
ip address 192.168.200.254 255.255.255.0
interface GigabitEthernet0/0
description CONNECTED TO ISP
ip address 172.21.21.98 255.255.255.252
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/1
description Connected to Palo Alto Firewall ( Inside network )
ip address 55.195.26.1 255.255.255.248
duplex auto
speed auto
ip local pool REVPN 192.168.200.10 192.168.200.20
ip forward-protocol nd
ip http server
ip http secure-server
ip nat inside source list 10 interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 172.21.21.97
ip route 10.128.3.200 255.255.255.255 55.195.26.2
ip route 10.128.4.0 255.255.255.0 55.195.26.2
ip access-list extended REVPN-ACL
permit tcp 192.168.200.0 0.0.0.255 10.128.3.0 0.0.0.255 eq 3389
permit tcp 192.168.200.0 0.0.0.255 10.128.4.0 0.0.0.255 eq 3389
webvpn gateway ANYCONNECT
ip address 172.21.21.98 port 443
http-redirect port 80
ssl trustpoint TRUST
inservice
webvpn context company
title ""
login-message "*Authorised Access Only*"
aaa authentication list webvpn
gateway ANYCONNECT
ssl authenticate verify all
inservice
policy group policy1
functions svc-enabled
banner ""
filter tunnel REVPN-ACL
svc address-pool "REVPN" netmask 255.255.255.0
svc default-domain ""
svc keep-client-installed
svc homepage ""
svc rekey method new-tunnel
svc split include 10.128.4.0 255.255.255.0
svc split include 192.168.200.0 255.255.255.0
svc dns-server primary 192.168.1.100
svc dns-server secondary 192.168.1.200
default-group-policy policy1
end
