Any Connect Problem
dogancubuklu
Community Member
Dear All,
I am Dogan from Istanbul, Turkey.
I am a Macbook user. At the same time, I use Cisco Any Connect for VPN. The problem is when the Cisco Any Connect is connected, I can not make calls on Macbook, it somehow blocks outgoing / incoming calls. When I turn the Cisco Any Connect off, then I can make both incoming and outgoing calls.
Is there anybody who can help me ?
Thanks in advance
It's likely that only your IT department can help here. I assume that they have the VPN configured in a way that breaks your soft phone. If that is a wanted use case, they will likely adjust to make it work.
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
