AnyConnect and Smart Card through RDP
pavoljaco
I have virtual machine (Win 7 64bit), I am connecting to it through RDP protocol and I have sharing Smar Cards enabled. I have all necessary software and drivers for smart cards installed on virtual machine.
When I use Smart Card as usb token connected on my laptop (Gemalto usb token), virtual machine have no problem, I can see certificate and I can use it with AnyConnect to establish SSL VPN sucessfully.
But when I use clasic smart card like Crescendo or SafeSign with internal or external reader (on my laptop), I can see certificates, I can read and write to smart cards, I even have sucesfully validated certificate on ASA - vpn concentrator, but tunnel is not established sucessfully, ending with:
AnyConnect error: The client agent has encountered an error.
From ASA firewall: ERROR: Initialization failure (mem alloc failed, etc.)
From DART: An established connection was aborted by the software in your host machine.
I have two types of smart cards (crescendo, safesign) and Gemalto usb token, all is shared through RDP session from my laptop, only usb token can sucesfully establish VPN in RDP session. Generally I do not see any difference in using usb token (embeded smart card in reader) and usb reader with smart card. Anybody has similar experience?
Pavol Jaco
danieljochem
we have a similar problem here.
Have you already found a solution or any further information on that issue?
The only thing we found out is that a problem with the same error message is described in a Troubleshooting Guide on the MAC-OS AnyConnect client as an issue with IPv6.
Daniel Jochem
Pavol,
What version of AnyConnect and ASA are you using?
Shweta
Shweta,
As we have the same problem as Pavol here I also think it would be good to post the versions we are using here.
The issue occured first with using ASA version 8.4.4.1 and AnyConnect 3.1.01065. As we thought it may be a problem with the currently use ASA version we upgraded to ASA version 8.4.5 but that does not make any changes on the problem.
Daniel
Hi guys,
I am not sure wich version I was using back there, but now in my lab I have ASA 9.0(1) and AnyConnect 3.1.01065. As a driver for smartcard I am using SafeNet eToken Minidriver 5.1. I repeated the test today and now it works with no problem. I can sucesfully connect to ssl vpn (safenet cards did not work before upgrade), Gemalto tokens still work as before (Card OS API 5.1)
Pavol
