Anyconnect: Connection loss and 100% CPU load afterwards
Blaubaer
I installed Anyconnect for Linux in order to connect to a customer (who is obviously using this gateway).
Installation went fine, I can connect to the customer, BUT:
After 3 minutes latest the client says 'connection lost, trying to reconnect' and the /opt/cisco/anyconnect/bin/vpnagentd uses 100% CPU
operating system is openSUSE Leap 15.0, fully patched.
Any idea where to look after? Looks more like a bug than a feature to me...
Thanks!
BB
Blaubaer
Anyone else seeing this? Restarting the daemon is not as easy either - when asking for help (-h) it does not answer very verbose: linux-rown:/home/test # /opt/cisco/anyconnect/bin/vpnagentd -h Cisco Systems VPN Agent (version 4.6.00362 ) Copyright (C) 1998-2010 All Rights Reserved. usage: vpnagentd [-h] [-v] [-d] [-n
Try 4.6.0.11 I used it a pretty stable. Don't go for 4.6.0.23 its buggy
Thank you Mohammed. Is there any source where I could download the software without providing a service contract? The installed version was provided by the customer....
