AnyConnect fails to connect when using ECDH Group21 521-bit EC
ChuckHaynes
Level 3
Level 3
ECDH group to be used with SSL - Group21 - 521-bit EC (doesn't work with AnyConnect)
Anyone else experiencing this. ASA 5516-X, AnyConnect 4.8
Sheraz.Salim
I just check anyconnect version 8 with your setting its work for me. Only difference is mine box is 5506-X code is Version 9.9(2)47.
no threat-detection statistics tcp-intercept
ssl ecdh-group group21
ssl trust-point Peston_Trust outside
ssl trust-point Peston_Trust LAB
ssl trust-point Peston_Trust SERVER_BOX
ssl trust-point Peston_Trust DOT1X_less
ssl trust-point Peston_Trust wireless-house
ssl trust-point Peston_Trust BIG-SERVER
ssl trust-point Peston_Trust dot1x_wireless
webvpn
port 8443
enable outside
show webvpn anyconnect
1. disk0:/anyconnect-win-4.8.01090-webdeploy-k9.pkg 1 dyn-regex=/Windows NT/
CISCO STC win2k+
4,8,01090
Hostscan Version 4.8.01090
Mon 10/21/2019 9:53:27.36
please do not forget to rate.
ASA 5516-X  9.13(1)2
ASA# sh ssl
Accept connections using SSLv3 or greater and negotiate to TLSv1.2 or greater
Start connections using TLSv1.2 and negotiate to TLSv1.2 or greater
SSL DH Group: group24 (2048-bit modulus, 256-bit prime order subgroup, FIPS) (DEPRECATED)
SSL ECDH Group: group20 (384-bit EC)
SSL trust-points:
Self-signed (RSA 2048 bits RSA-SHA256) certificate available
Self-signed (EC 256 bits ecdsa-with-SHA256) certificate available
Interface outside: MEC-SSL-Trustpoint (EC 384 bits ecdsa-with-SHA256)
Certificate authentication is not enabled
When I set it to Group21, AnyConnect will no longer connect. It says "Could not connect to server. Please verify Internet connectivity and server address."
The problem was that our SSL certificate wasn't 521-bit. It looks like most CAs don't support it yet?
