Anyconnect installation problem
cbrasolin
Level 5
Level 5
i have a problem with the anyconnect client installation "anyconnect-win-4.2.01035-web-deploy-k9.exe". The PC is a windows 10 32bit, the error i see in the log file is:
Error 1722. There is a problem with this Windows Installer package. A program run as part of the setup did not finish as expected. Contact your support personnel or package vendor.  Action VACon_ndis6_Install, location: C:\Program Files\Cisco\Cisco AnyConnect Secure Mobility Client\VACon.exe, command: -install "C:\Program Files\Cisco\Cisco AnyConnect Secure Mobility Client\vpnva-6.inf" VPNVA
i have attached the entire log file installation.
Any idea?
Christian
jonathanlunt
Level 3
Level 3
see the below support forum post:
https://supportforums.cisco.com/discussion/12571806/anyconnect-re-install-windows-10-hanging
It may have the fix you are after
found the problem, i had to remove the share setting on the network interface and i was able to complete the installation.
