AnyConnect SBL on wireless connection
derrick
I have AnyConnect 3.1.06079 and I set it up to use SBL. I'm using this on Windows 8 machines. I can see the AnyConnect VPN option but I can't see how to connect a wireless connection before attempting to connect to the VPN. I've used the built in Windows VPN client in the past using SBL and with that it had the wireless icon in the lower left corner. I could just go there and select the wireless connection I want and then try connecting the VPN. Is there something I missed in my configuration to get that wireless icon to show on the login screen?
0 Replies 0
