ASA AnyConnect RSA (SDI) authentication AND certificate based authentication
Anish Chauhan
On an ASA with AnyConnect remote access VPN we current have users authenticated using RSA. It is possible to combine this with certificate authentication? Or is it an either/ or type choice?
Thanks, Anish
rvarelac
Level 7
Level 7
Hi Anish,
Yes, this configuration is supported and called double factor authentication the document below might help you with the configuration.
http://www.cisco.com/c/en/us/support/docs/security/anyconnect-secure-mobility-client/116111-11611-config-double-authen-00.html
Hope it helps
-Randy-
