ASA firmware upgraded facing issue with IPSEC
man05681
Very recently we have upgraded ASA firmware with letest one but are facing issue with IPSEC tunnels goes down except few are up.
Please help me out to trouble shoot the issue.
Man
Jitendra Kumar
@man05681
show run all crypto map
check the crypto map and compare with remote side i was faced issue with PFS group number was changed due to the security reason.
when upgrade the firmware pfs group 1,2 will be removed after upgrade due to the security reason.
below is the command you can reconfigure the it again.
no crypto map outside_map 1 set pfs group14
crypto map outside_map 1 set pfs group2
Jitendra
Jitendra
5 Replies 5
@man05681 you'll need to provide more information.
What was the original software version?
What version did you upgrade to?
Have you checked for bugs on the version you upgraded to?
If using a Policy Based VPN interesting traffic needs to be sent to keep the tunnel up, if you send traffic does the tunnel come up?
Have you checked the logs?
man05681
We was on the 6.0.x then upgrade 6.3.x.
If anyone has faced this issue please help.
thanks,
man05681
hi
Jitendra Kumar
@man05681
Jitendra
Jitendra
thanks for help.
