01-22-2015 07:33 AM
We have a cisco ASA: ASA 5510 Security Plus license. Adaptive Security Appliance Software Version 7.2(5) (I know it is old).
ASA is currently configured for remote access ipces vpn and site-to-site ipsec vpn. Both terminate on outside interface. There are hosts on the inside interface. There are only two interfaces on ASA, inside and outside.
Both remote users and local hosts can reach the other end of site-to-site vpn. Currently local users are PATed when going to site-to-site vpn destination. Whereas remote access users are allocated a pool of IP addresses, and these remote users are sent with those assigned IP addresses. Remote users have to first come to ASA and then ASA forwards their packets to site-to-site vpn destination.
My query is: Can I forward remote access users to site-to-site vpn destination with same PATed IP as local users are sent? Basically I'm asking for PATing on same interface.
I would like to add, ASA is already configured with following. same-security permit intra-interface Same-security permit inter-interface hairpinning. Please see attachment for n/w overview.
Thanks.
01-22-2015 08:14 AM
Hi Rohan,
what is your ultimate goal i checked your topology do you want your RA clients to access
the server behind the site to site VPN tunnel ?
please share the ip address of the users and the end server.
if you can add in ip addresses and share the config it will be helpful
Rohan
01-22-2015 08:49 AM
Hi Rohan.
RA user can reach the server behind site-to-site tunnel. The ASA forwards RA users' traffic without NAT or PAT. My goal is, I want ASA to PAT the RA users' traffic when they are forwarded over site-to-site tunnel. It is same interface (outside) on which both, RA users and site-to-site tunnel are terminated.
In short I am looking for PATing on same interface.
Thank you.
Rohan
01-22-2015 10:09 AM
yes this should be configurable which ASA IOS are you using?
is it 8.4x or higher ? or below 8.2
you will have to add the patted ip of the ASA in the cyrpto ACL and same has to be done
on the head end vpn terminating device in reverse fashion.
Example
A--is Remote access network
B-Remote end server network
C-Patted ASA IP
Crypto ACL on ASA
C----->>> B
Crypto ACL on the remote en device
B----->>>>C
Rohan
01-22-2015 10:59 PM
Hi Rohan,
I understand you are trying to help. But you may want to read original post, it answers all your question. You are advising about interesting traffic. I need a solution for a step Before that, PATing.
But, to make my query clearer, please see below:
A= IP add allocated to RA by ASA.
B= site-to-site server.
C= outside interface.
P= PAT IP.
L= Local users on inside interface.
Both, RA users and site-to-site vpn tunnel are terminated on outside interface.
CURRENT TRAFFIC FLOW.
If A wants to go to B
A first comes to C.
ASA forwards A as source IP and B as destination IP.
If L wants to go to B
ASA does PAT and changes source IP to P and B as destination IP.
What I want.
A firsts comes to C.
ASA to do PAT on A to change it to P. Then ASA to forward P as source IP and B as destination IP.
For L it should behave the same way.
Thanks.
Rohan
01-23-2015 01:20 AM
Hi Rohan,
This Explanation is pretty helpful.
what you are trying to achieve is configurable :)
which ASA IOS are you using? for 8.2 ,8.4 the natting is different
will try to create the NAT statements as per your code.
+++++++++++++Just to be on same page this is what you want++++++++++++
When A--->communicates with B it will be patted to P this communication will be bidirectional.
Rohan
01-23-2015 11:18 PM
Hi, Rohan.
Yes, that was my goal, and I accomplished it with policy PAT :-) .
Thanks for you interest in the discussion.
Rohan.
01-22-2015 11:58 PM
Hi Rohan,
Are you using the same IP address subnet for Remote vpn users as that of your local users?
Please share the VPN configuration, NAT/PAT and VPN ACL configuration on ASA to check the possibility.
01-23-2015 01:16 AM
Hello Poonam,
We are using a separate pool of IPs for RA.
For now forget about network topology. Lets start fresh. My basic query: PATing on same interface. Sort of like nat (outside,outside). Is it possible?
Rohan.
