ASA running config will not load on ASDM
a.voiles
I am able to start the ASDM, but it hangs when loading the running config from the ASA. Same results from multiple PCs... on the ASA command line, the running config will not display: ERROR: Command Ignored, Configuration in progress...
acomiskey
Level 10
Level 10
only time this happened to me is when I attempted to use the vpn wizard, rebooted the asa and the cli came back fine.
Hi all,
I want to know is there any option to recover from this without rebooting.
