ASA to ASA ipsec problem after wan drop
erik bakke
Hi all!
We have 5525x at DC and a lot of ipsec to other asa`s. (5505,06x and 5516x)
If wan connection to 5525x drops for a few ms, ipsec tunnels stops passing traffic, often we can see one-way-traffic or no traffic at all, we need to logout ipsec tunnel and re-establish tunnels again.
This is a big issue for us.
Anyone have any solutions? Any configuration setting we need to have?
I have read about "sysopt connection preserve-vpn-flows" Preserve stateful VPN flows when the tunnel drops, is it a good idea to enable this?
Very happy for all the help I can get :)
5 Replies 5
Shakti Kumar
Hi Erik,
Have you implemented IKEV2 or IKEV1 tunnel ??
Is the issue seen with both of them ?
Both, most tunnels is IKEv2
Hi Erik,
I have often seen this issue very specifically with IKEV2 based tunnel during link failure on either of the sides because of
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCva84635/?reffering_site=dumpcr
Can you share the logs during the outage for one of the tunnels and share the logs to shaktiku@cisco.com?
Hi!
Yes I will :) which command do you want output from?
We running 9.8.1, is that release affected also?
Hi Erik,
Yes 9.8.1 has this problem, it isn't a code problem.
The outputs i need is
1.) run a conditional debug for a peer
debug crypto condition peer <ip address of the ikev2 peer>
2.) enable debugs
debug crypto ikev2 protocol 127
debug crypto ikev2 platform 127
debug crypto ipsec 127
Please ensure to check the health of the device before executing the debug commands
While sending out the logs please include "supportforum" in the subject area
thanks
Shakti
