Avocent CPS 1610 problem
ckeithjones
I have 2 2801's, 3 3750's and 2 2611's connected to a CPS 1610. I can connect remotely however a few commands won't execute properly. The show running-config" command is accepted but there is a page break after 15-20 lines. In other words I can never get to the middle or end of the running config since it just breaks back to a command prompt too early. Other commands that show multiple pages of output work such as show tech-support. Has anyone experienced this before? I've increased the terminal length but it doesn't really solve the core issue of why a break happens and sends me back to a command prompt too early.
Keith
stoffen1983
  • If not solved, this will solve your problem:
      • port all set out lf=strip
      • port all set in cr=cr (default)
      • port all set in lf=lf
        (default)
      • port all set out cr=cr
        (default)
Best regards
Christoffer
Message was edited by: Christoffer Smoras
stoffen1983
        (default)
        (default)
Best regards
Christoffer
