Basic IPSec Problem - Arrrgghhh
john.pepper
Could anyone please help with this IPSec problem pls..?
Summary - 2 sites
HQ site = 1721 vpn/k9 bundle - (192.168.1.0)
Remote site = 837 vpn/k9 - (192.168.2.0)
have configured Internet access which works fine but cannot get the site-to-site IPSec VPN active. Debug crypto isakmp output below which seems to indicate a problem with the pre-share authentication or keys.?
I have triple checked both of these but still no joy. the two sites don't seem to find a common policy but they are configured the same.. Desparate to get working by end of tomorrow..!!!
CENTRAL SITE CONFIG (1721)
crypto isakmp policy 1
hash md5
authentication pre-share
crypto isakmp key xxxxx address xx.xxx.xxx.xxx
crypto ipsec transform-set ans esp-des
crypto map anmap 1 ipsec-isakmp
set peer xx.xxx.xxx.xxx
set transform-set ans
match address 110
interface ATM0
no ip address
no ip mroute-cache
no atm ilmi-keepalive
pvc 0/38
encapsulation aal5mux ppp dialer
dialer pool-member 1
dsl operating-mode auto
hold-queue 224 in
interface FastEthernet0
description AN Supplies LAN
ip address 192.168.1.168 255.255.255.0
ip nat inside
ip tcp adjust-mss 1452
no ip mroute-cache
speed auto
hold-queue 100 out
interface Dialer1
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp chap hostname xxxxxxx
ppp chap password 0 xxxxxxx
crypto map anmap
ip nat inside source route-map nonat interface Dialer1 overload
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
no ip http server
ip http authentication local
ip http secure-server
access-list 110 permit ip 192.168.1.0 0.0.0.255 192.168.2.0 0.0.0.255
access-list 130 deny ip 192.168.1.0 0.0.0.255 192.168.2.0 0.0.0.255
access-list 130 permit ip 192.168.1.0 0.0.0.255 any
dialer-list 1 protocol ip permit
route-map nonat permit 10
match ip address 130
REMOTE SITE CONFIG (837)
hash md5
crypto isakmp key 0 xxxxx address xx.xxx.xxx.xx
match address 110
interface Ethernet0
ip address 192.168.2.168 255.255.255.0
ip nat inside
no ip mroute-cache
hold-queue 100 out
interface ATM0
no ip address
no ip mroute-cache
pvc 0/38
hold-queue 224 in
interface Dialer1
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp chap hostname xxxxxxxxxxx
ppp chap password 7 xxxxxxxxxx
crypto map anmap
ip classless
ip http server
no ip http secure-server
access-list 110 permit ip 192.168.2.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 130 deny ip 192.168.2.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 130 permit ip 192.168.2.0 0.0.0.255 any
end
Debugs to follows:
22 Replies 22
both routers have 'static' Public IP addresses as the IPSec endpoints (peers) - these were puchased from our ISP and never change so that's not the problem.
The problem seems to be that the HQ router will not route packets through the tunnel unless it has a Static route pointing to the remote subnets (192.168.x.x) via the ISP 'next hop'. The next hop address is allocated by the ISP and binds itself to the Virtual-Access interace connected to the Dialer. You can only see this by issuing a 'show ip route' command.
The remote routers (837) seem to work ok with a default route via Dialer 1 - 0.0.0.0 0.0.0.0 dialer 1
I would like the same configuration for the HQ router (1721) but this doesn't seem to work.
Hope this helps..
Thanks,,,John
John,
I've just had a look at a config I used for a 1721, it uses a default route that points to the interface as the next hop. I'll try and find out what IOS the router is using, I dont have remote access so will have to make a phone call.
Andy
John,
I had the same problem with an 837<->2651 VPN I
recently configured. I was specifing the Dialer1
interface as the default next hop, but VPN traffic
never seemed to pass, as the next-hop address needed
to be added to the routing table from the routers
DHCP-client.
Try doing this (you may have to do it on both HQ and
site routers)...
! Remove the default route statement:
no ip route 0.0.0.0 0.0.0.0 Dialer1
! Tell the dhcp-client to make the next-hop distance 1
ip dhcp-client default-router distance 1
You may then need to reboot or issue "shutdown"
then "no shutdown" on the Dialer1 interface so that
the DHCP-client will renegotiate with the DSLAM.
If it doesn't work, please post a "show ip route"
from both routers.
Ryan
Ryan / Andy,
Both, thanks for your input..
* Ryan - I'll have to wait until a suitable time to try this as the customer is undergoing testing at the moment so I am unable to make any changes. However, I will try and test this in the next few days and let you know.
I assume this fixed your problem which seems similar to what I'm getting - did you get the ISP next hop address appear in the routing table after doing this.?
John
John,
When I removed the "ip route 0.0.0.0 0.0.0.0 Dialer1" statement, then the next-hop address then appeared in the routing table, but the distance was very high (250 I think), causing the route to not be preferred. This is why I had to insert the "ip dhcp-client default-route distance 1" statement
John,
The IOS used on the 1721 I set up with the route pointing out via dialer 1 is 12.2(11)T10
However its not running IPSec, its just a DSL connected link. I didnt have any routing issues caused by this statement whilst I was testing the link, its been in for about 5 months now.
Andy
Andy,
cheers for this information.
The only routing problem I have is with the IPSec stuff.. The DSL / PAT config works absolutely fine.. Users get translated from their respective Private address into the Public Static IP address provided by the ISP with no problems. The issue is purely the IPSec routing between the 192.168.x.x LAN's via the tunnel..
It seems a few other people have had issues with the 1700 router using IPSec and have swapped them out for an 800 and all works ok..
All the best....John
****** RESULT ****** CISCO PLEASE ADVISE *****
I finally got to the bottom of this problem when I came to do another IPSec VPN for another customer using a 1721 K9 VPN router (this is the one the on-board hardware encryption module).
The entire problem seems to be down to the Hardware Enryption Module..!!!!
If I disable this with the command:
no crypto engine accelerator
everything works fine with a simple Default route via the Dialer interface... If I turn it on again - inconsistent tunnel connectivity occurs (i.e the tunnel comes up, normally routes 'one' packet and then nothing else). Turn the Hardware Engine Accelerator OFF again and all works ok...
CISCO Guys - Is this an IOS problem..?
Both 1721 routers I've had this problem on were using IOS 12.3(2) XE
Should I open a TAC case or is this a known problem..?
Thanks for everyones input. I hope the above helps anyone else having this problem.
Cheers...John
