12-29-2015 11:31 AM
I'm in the process of getting a VPN for myself. My current router does not support VPN so I have to change it too.
I've been scrolling this VPN comparison website http://comparisonvpn.com for VPN candidates but I have no idea which one I should end up with.
Also which one of those work with a cisco router? I understand most of them work with something called DD-WRT router.
So the question is, could someone help me pick a VPN and a cisco router for home use? A small description of both would be helpful.
Thanks!
12-29-2015 11:38 AM
What sort of Internet connection do you have? ADSL? VDSL? Cable? Fibre? Ethernet?
12-29-2015 12:21 PM
ADSL2 50/20.
12-29-2015 12:31 PM
Cisco C887VA with advanced IP and SSL VPN (aka AnyConnect) would work well. You'll need to get a SmartNet with it initially. Don't expect a GUI.
01-20-2019 04:33 AM
Hello, I have the same question, work in Canada and through a review site, I thought that the best vpn for canada is ExpressVPN, but before hiring I want to be sure, to make a good choice, Has anyone hired it?
