Callback problem
shaunr.naidoo
hi!
can any onr help me with a callback problem. Pc dialing into router via ISDN doesnt work with callback but works without it.
6 Replies 6
globalnettech
Level 5
Level 5
can you post the configuration of your router as you have configured it so far ?
GNT
modem country mica south-africa
aaa new-model
aaa authentication ppp default group radius local
aaa authorization exec default local group radius
aaa authorization network default local group radius
aaa accounting network default start-stop group radius
aaa session-id common
ip subnet-zero
ip cef
no ftp-server write-enable
async-bootp dns-server 192.168.101.2 192.168.101.3
async-bootp nbns-server 192.168.101.2 192.168.101.3
isdn switch-type basic-net3
chat-script callback ABORT ERROR ABORT BUSY "" "ATDT\T" TIMEOUT 30 "CONNECT" \c
chat-script offhook "" "ATH1" OK
modemcap entry 3com_usr:MSC=&F1S0=1
interface FastEthernet0/0
ip address 192.168.254.250 255.255.255.0
no ip redirects
no ip unreachables
duplex auto
speed auto
interface FastEthernet0/1
ip address 192.168.100.28 255.255.255.0
no ip redirects
no ip unreachables
duplex auto
speed auto
interface BRI2/0
no ip address
encapsulation ppp
dialer rotary-group 0
dialer-group 1
isdn incoming-voice modem
isdn skipsend-idverify
no keepalive
ppp authentication pap chap ms-chap
interface BRI2/1
no ip address
encapsulation ppp
dialer-group 1
no keepalive
interface BRI2/2
no ip address
encapsulation ppp
dialer-group 1
no keepalive
interface BRI2/3
no ip address
encapsulation ppp
dialer-group 1
no keepalive
interface BRI2/4
no ip address
encapsulation ppp
dialer-group 1
no keepalive
interface BRI2/5
no ip address
encapsulation ppp
dialer-group 1
no keepalive
interface BRI2/6
no ip address
interface BRI2/7
no ip address
interface Group-Async1
ip unnumbered FastEthernet0/1
encapsulation ppp
no ip route-cache cef
no ip route-cache
no ip mroute-cache
dialer in-band
dialer idle-timeout 900
dialer-group 1
async dynamic routing
async mode interactive
peer default ip address pool RAS
ppp max-bad-auth 3
ppp callback accept
ppp authentication ms-chap-v2
group-range 33 50
hold-queue 10 in
hold-queue 20 out
interface Dialer0
ip unnumbered FastEthernet0/0
encapsulation ppp
no ip route-cache
no ip mroute-cache
dialer in-band
dialer-group 1
ppp multilink
ppp callback accept
hold-queue 10 in
hold-queue 20 out
ip local pool RAS 192.168.103.230 192.168.103.254
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.254.1
ip http server
dialer-list 1 protocol ip permit
radius-server host 192.168.101.61 auth-port 1645 acct-port 1646
radius-server key xxx
radius-server vsa send authentication
line con 0
password xxx
line 33 50
session-timeout 10
script modem-off-hook offhook
script callback callback
modem InOut
modem autoconfigure discovery
autoselect during-login
autoselect ppp
line 51 62
line aux 0
line vty 0 4
password xxx
end
the config looks ok, as far as I can tell. Can you post the output of:
debug modem
debug chat
debug callback
GNT
hi!
i have go the callback to work up to the point where it asks me to put in the number tocall back.
the router then disconnects the session but doesnt initiate a callback.
there is nothing on the debugs that you requested.
can you try the following callback script:
chat-script callback ABORT ERROR ABORT BUSY "" "ATZ" OK "ATDT \T" TIMEOUT 60 CONNECT \c
and see if that makes a difference ?
GNT
hi!
i have manged to get it working. seems the router didnt know which interface to dial out on. once iadded the line "modem dialout int bri 2/0" it worked fine.
thanks for the help.
