11-23-2015 05:11 AM
Hi All,
I have configured a 4503 with SUP7L-E as a core switch for our infrastructure. But after every power outage the switch comes in ROMMON. After that I have to manually type "boot" to boot up the sysytem.
Please find the below " sh version" and "sh bootvar " and its results.
Is this due to a damaged flash ? Please help me in this .....
Thanks In Advance,
AMR
CORE1#show version
Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch Software (cat4500e-UNIVERSAL-M), Version 03.05.03.E RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Mon 05-May-14 10:33 by prod_rel_team
Cisco IOS-XE software, Copyright (c) 2005-2013 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: 15.0(1r)SG10
CORE1 uptime is 42 minutes
Running default software
Jawa Revision 7, Winter Revision 0x0.0x40
Last reload reason: power-on
License Information for 'WS-X45-SUP7L-E'
License Level: ipbase Type: Permanent
Next reboot license Level: ipbase
cisco WS-C4503-E (MPC8572) processor (revision 6) with 2097152K bytes of physical memory.
Processor board ID SPE191200CS
MPC8572 CPU at 1.5GHz, Supervisor 7L-E
Last reset from PowerUp
14 Virtual Ethernet interfaces
84 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
CORE1#sh bootvar
BOOT variable =
CONFIG_FILE variable does not exist
BOOTLDR variable does not exist
11-23-2015 05:27 AM
sh bootvar Output
BOOT variable = >>>>> It shows Empty
try to use boot system command, format would be
(config)#boot system <PATH of IOS Image>
wr
Then execute sh bootvar again and check for any entry there, If yes, Power Off and Power On again and check whether it's booting normally or not ?
