11-12-2012 06:32 AM - edited 02-21-2020 06:28 PM
Hi!
I have a small network, wiht ASA 5505, 8.4:
Inside network: 192.168.2.0/24
Outside: Static IP
I would like to deploy a SSL AnyConnect setup.
The state:
-I give the correct IP from my predefined VPN pool (10.10.10.0/24).
But, could not reach any resource, could not ping too. My host has given 10.10.10.1 IP, and I had a GW: 10.10.10.2. Where is this GW from?
Could you help me?
Here is my config (I omitted my PUBLIC IP, and GW):
Result of the command: "show running-config"
: Saved
ASA Version 8.4(4)1
hostname valamiASA
domain-name valami.local
enable password OeyyCrIqfUEmzen8 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
switchport access vlan 12
interface Vlan1
description LAN
no forward interface Vlan12
nameif inside
security-level 100
ip address 192.168.2.1 255.255.255.0
interface Vlan2
description WAN
nameif outside
security-level 0
ip address MY_STATIC_IP 255.255.255.248
interface Vlan12
description Vendegeknek a valamiHotSpot WiFi-hez
nameif guest
security-level 100
ip address 192.168.4.1 255.255.255.0
management-only
ftp mode passive
clock timezone GMT 0
dns domain-lookup inside
dns domain-lookup outside
dns domain-lookup guest
dns server-group DefaultDNS
name-server 62.112.192.4
name-server 195.70.35.66
same-security-traffic permit intra-interface
object network obj_any
subnet 0.0.0.0 0.0.0.0
object network inside-net
subnet 192.168.2.0 255.255.255.0
object network guest-net
subnet 192.168.3.0 255.255.255.0
object network NETWORK_OBJ_192.168.2.128_25
subnet 192.168.2.128 255.255.255.128
object-group protocol DM_INLINE_PROTOCOL_3
protocol-object ip
protocol-object icmp
object-group protocol DM_INLINE_PROTOCOL_1
protocol-object ip
object-group protocol DM_INLINE_PROTOCOL_2
protocol-object ip
access-list global_access extended permit object-group DM_INLINE_PROTOCOL_3 any any
access-list AnyConnect_Client_Local_Print extended deny ip any any
access-list AnyConnect_Client_Local_Print extended permit tcp any any eq lpd
access-list AnyConnect_Client_Local_Print remark IPP: Internet Printing Protocol
access-list AnyConnect_Client_Local_Print extended permit tcp any any eq 631
access-list AnyConnect_Client_Local_Print remark Windows' printing port
access-list AnyConnect_Client_Local_Print extended permit tcp any any eq 9100
access-list AnyConnect_Client_Local_Print remark mDNS: multicast DNS protocol
access-list AnyConnect_Client_Local_Print extended permit udp any host 224.0.0.251 eq 5353
access-list AnyConnect_Client_Local_Print remark LLMNR: Link Local Multicast Name Resolution protocol
access-list AnyConnect_Client_Local_Print extended permit udp any host 224.0.0.252 eq 5355
access-list AnyConnect_Client_Local_Print remark TCP/NetBIOS protocol
access-list AnyConnect_Client_Local_Print extended permit tcp any any eq 137
access-list AnyConnect_Client_Local_Print extended permit udp any any eq netbios-ns
access-list inside_access_in extended permit object-group DM_INLINE_PROTOCOL_2 any any
access-list outside_access_in extended permit object-group DM_INLINE_PROTOCOL_1 any any
pager lines 24
logging enable
logging asdm informational
mtu inside 1500
mtu outside 1500
mtu guest 1500
ip local pool valami_vpn_pool 10.10.10.1-10.10.10.10 mask 255.255.255.0
icmp unreachable rate-limit 1 burst-size 1
icmp permit any inside
no asdm history enable
arp timeout 14400
nat (inside,outside) dynamic interface
nat (guest,outside) dynamic interface
access-group inside_access_in in interface inside
access-group outside_access_in in interface outside
access-group global_access global
route outside 0.0.0.0 0.0.0.0 MY_STATIC_GW 1
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
aaa local authentication attempts max-fail 16
http server enable
http 192.168.2.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
telnet timeout 5
ssh timeout 5
ssh key-exchange group dh-group1-sha1
console timeout 0
dhcpd auto_config outside
threat-detection basic-threat
threat-detection statistics host
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
enable inside
enable outside
anyconnect-essentials
anyconnect image disk0:/anyconnect-win-2.5.2014-k9.pkg 1
anyconnect enable
tunnel-group-list enable
group-policy GroupPolicy_valami_VPN internal
group-policy GroupPolicy_valami_VPN attributes
wins-server value 192.168.2.2
dns-server value 192.168.2.2
vpn-tunnel-protocol ssl-client
split-tunnel-policy tunnelall
default-domain value valami.local
webvpn
anyconnect ssl rekey time 30
anyconnect ssl rekey method ssl
anyconnect ask enable default anyconnect timeout 30
customization none
deny-message value Login was successful, but because certain criteria have not been met or due to some specific group policy, you do not have permission to use any of the VPN features. Contact your IT administrator for more information.
username test password P4ttSyrm33SV8TYp encrypted
tunnel-group valami_VPN type remote-access
tunnel-group valami_VPN general-attributes
address-pool valami_vpn_pool
default-group-policy GroupPolicy_valami_VPN
tunnel-group valami_VPN webvpn-attributes
group-alias valami_VPN enable
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum client auto
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect ip-options
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
Cryptochecksum:d54de340bb6794d90a9ee52c69044753
: end
11-12-2012 08:21 AM
You need to setup an exemption, your inside network to the VPN network. And the VPN pool, make it from 10.10.10.10 to whatever this way your gateway will be 10.10.10.1 just easier that way.
Here are my notes which might help:
http://news.mali77.com/index.php/2012/11/configuring-cisco-any-connect-on-cisco-asa-8-4/
11-14-2012 04:38 AM
First of all thanks your link.
I know your notes, but i don't understand 1 thing:
if i check nat exemption in the anyconnect wizad, why should i make nat exemption rule?
A tried creating a roule, but it is wrong.
My steps (on ASDM):
1: create network object (10.10.10.0/24), named VPN
2: create nat rule: source any, destination VPN, protocol any
Here is my config:
: Saved
ASA Version 8.4(4)1
hostname companyASA
domain-name company.local
names
interface Vlan1
description LAN
nameif inside
security-level 100
interface Vlan2
description WAN
nameif outside
security-level 0
ip address 77.111.103.106 255.255.255.248
interface Vlan12
description Vendegeknek a companyHotSpot WiFi-hez
nameif guest
security-level 100
ftp mode passive
clock timezone CEST 1
clock summer-time CEDT recurring last Sun Mar 2:00 last Sun Oct 3:00
object network WEBSHOP
host 192.168.2.2
object network INSIDE_HOST
host 10.100.130.5
object network VOIP_management
host 192.168.2.215
object network Dev_1
host 192.168.2.2
object network Dev_2
host 192.168.2.2
object network RDP
host 192.168.2.2
object network Mediasa
host 192.168.2.17
object network VOIP_ePhone
host 192.168.2.215
object network NETWORK_OBJ_192.168.4.0_28
subnet 192.168.4.0 255.255.255.240
object network NETWORK_OBJ_10.10.10.8_29
subnet 10.10.10.8 255.255.255.248
object network VPN
subnet 10.10.10.0 255.255.255.0
object network VPN-internet
protocol-object ip
protocol-object ip
protocol-object ip
pager lines 24
logging enable
mtu inside 1500
mtu outside 1500
mtu guest 1500
ip local pool company_vpn_pool 10.10.10.10-10.10.10.15 mask 255.255.255.0
arp timeout 14400
nat (any,any) source static any any destination static VPN VPN
nat (inside,outside) source static inside-net inside-net destination static VPN VPN
route outside 0.0.0.0 0.0.0.0 77.111.103.105 1
http server enable
telnet timeout 5
ssh timeout 5
console timeout 0
webvpn
enable inside
enable outside
anyconnect enable
group-policy GroupPolicy_company_VPN internal
group-policy GroupPolicy_company_VPN attributes
vpn-tunnel-protocol l2tp-ipsec
default-domain value company.local
webvpn
customization none
group-policy GroupPolicy_VPN internal
group-policy GroupPolicy_VPN attributes
wins-server none
dns-server value 62.112.192.4 195.70.35.66
tunnel-group company_VPN type remote-access
tunnel-group company_VPN general-attributes
address-pool company_vpn_pool
default-group-policy GroupPolicy_company_VPN
tunnel-group company_VPN webvpn-attributes
group-alias company_VPN enable
tunnel-group VPN type remote-access
tunnel-group VPN general-attributes
default-group-policy GroupPolicy_VPN
tunnel-group VPN webvpn-attributes
group-alias VPN enable
parameters
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect ip-options
inspect icmp
inspect icmp error
Cryptochecksum:33ee37a3722f228f9be9b84ef43f731e
: end
Could you give me a CLI-code?
(or ASDM steps).
11-14-2012 06:06 AM
Hi Ali!
I solved, I had a typo in the config, so everything is OK!
Thank You Very Much!
I have an other question:
If i would setup a global access route, source any, dest. any, is it safety?
My goal:
from inside reach the whole Internet, but from outside nothing, except the nat rules (eg. port forward)
What is your suggestion?
Akos
11-15-2012 10:04 AM
Sorry for the late reply been dealing with some of my own issues. Glad you were able to resolve the issue.
Technically firewall will deny traffic from outside to inside. If you want to access anything from outside to your internal network you'll have to setup NAT and configure appropriate rules too.
So basically inside(higher security level) to outside(lower security level) traffic is allowed but the other way around it is not unless you create rules for it.
I personally like to also use access list for the inside interface too for traffic going out.
