Cisco ASA 8.3 VPN Problem
andy.dodd
Hi All,
I am having some problems with setting up a VPN using IPSEC to establish a Site to Site connection.
What I am trying to setup is the following, its IPs address from A site can reach the ranges on site B and visa versa.
Site A                                                       Site B
192.168.10.0                                             172.16.0.0
192.168.20.0      ---- IPSEC Tunnel----          172.17.0.0
192.168.30.0                                             172.18.0.0
I have tested with just one subnet to another subnet which works. However, when I try to group the objects together it fails.
As a example I can set up a VPN from 192.168.20.0 to 172.18.0.0 which I can pass traffic through but its unable to reach the other subnets.
Here is extracts from the config.
crypto isakmp enable outside
ACL
access-list outside_1_cryptomap permit ip object dmz-network-local object dmz-network-remote
Tunnel Group
tunnel-group <peer ip> type ipsec-l2l
tunnel-group <peer ip> ipsec-attributes
pre-shared-key <passkey>
isakmp keepalive threshold 10 retry 2
Phase 1
crypto isakmp policy 10 authentication pre-share
crypto isakmp policy 10 encrypt 3des
crypto isakmp policy 10 hash sah
crypto isakmp policy 10 group 2
crypto isakmp policy 10 lifetime 86400
Phase 2
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto map outside_map 1 match address outside_1_cryptomap
crypto map outside_map 1 set pfs group1
crypto map outside_map 1 set peer <peer ip>
crypto map outside_map 1 set transform-set ESP-3DES-SHA
crypto map outside_map interface outside
NAT
nat (inside,outside) 1 source static dmz-network-local dmz-network-local destination static dmz-network-remote dmz-network-remote
Any advice would be greatly appreciated.
Thanks.
Andrew,
Accroding to your config, every network is behind a different interface of the ASA so you will need to modify the NAT rule for each of those, for instance:
nat (DMZ_Zone,outside) 1 source static ad-network-local ad-network-local destination static obj-remote obj-remote
nat (DB_Zone,outside) 1 source static db-network-local db-network-local destination static obj-remote obj-remote
nat (AD_Zone,outside) 1 source static dmz-network-local dmz-network-local destination static obj-remote obj-remote
Please review it  and give it a try.
I hope to hear from you soon.
12 Replies 12
Jennifer Halim
Can you please advise if all 3 subnets (192.168.10.0/24, 20.0/24 and 30.0/24) are all behind the same "inside" interface?
As the object name is created as "dmz-network-local", does it mean it is actually behind DMZ interface instead of inside interface?
If you can share the config that would be good to understand which interface those subnets are connected to as well as to see the actual objects. Thanks.
All subnets are behind a /24 mask, each subnet is behind a different interface.
Here are my object groups.
object network dmz-network-local
subnet 192.168.10.0 255.255.255.0
object network dmz-network-remote
subnet 172.16.0.0 255.255.255.0
object network ad-network-local
subnet 192.168.2.0 255.255.255.0
object network ad-network-remote
subnet 172.17.0.0 255.255.255.0
object network db-network-local
subnet 192.168.30.0 255.255.255.0
object network db-network-remote
subnet 172.18.0.0 255.255.255.0
I'll post the running config in a while.
Did you group it as follows?:
object-group network obj-local
     network-object object dmz-network-local
     network-object object ad-network-local
     network-object object db-network-local
object-group network obj-remote
     network-object object dmz-network-remote
     network-object object ad-network-remote
     network-object object db-network-remote
nat (inside,outside) source static obj-local obj-local  destination static obj-remote obj-remote
Thats correct.
I used vpn-group-local
object-group network vpn-network-local
object-group network vpn-network-remote
Then added that group to the ACL
access-list outside_1_cryptomap permit ip object vpn-network-local object vpn-network-remote
However, I did create a seperate nat statment for each subnet.
e.g.
nat (inside,outside) source static dmz-network-remote dmz-network-remote destination static dmz-network-remote dmz-network-remote
Would I need to add in some sort of routing?
As all I have in the config a the mo is
ip route 0.0.0.0 0.0.0.0
I will upload a running config shortly after I have taking out some infomation.
I have removed much of the important information:
ASA Version 8.3(1)
hostname ASA 8.3
domain-name ASA1
enable password
passwd
names
interface Ethernet0/0
no nameif
security-level 0
no ip address
interface Ethernet0/0.1
description AD Zone
vlan 30
nameif AD_Zone
security-level 100
ip address 192.168.30.1 255.255.255.0 standby X.X.X.X
interface Ethernet0/0.2
description DB Interface
vlan 20
nameif DB_Zone
security-level 100
ip address 192.168.20.1 255.255.255.0 standby X.X.X.X
interface Ethernet0/1
description Management Interface
nameif Inside
security-level 100
ip address 192.168.0.1 255.255.255.0 standby X.X.X.X
interface Ethernet0/1.1
description DMZ Interface
vlan 10
nameif DMZ_Zone
security-level 50
ip address 192.168.10.1 255.255.255.0 standby X.X.X.X
interface Ethernet0/2
description Untrust Interface
nameif Outside
security-level 0
ip address X.X.X.X X.X.X.X standby X.X.X.X
interface Ethernet0/3
description LAN/STATE Failover Interface
interface Management0/0
nameif management
security-level 100
management-only
ftp mode passive
clock timezone GMT/BST 0
clock summer-time GMT/BDT recurring last Sun Mar 1:00 last Sun Oct 2:00
dns server-group DefaultDNS
domain-name asa.local
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object network Management_Inside_Out_NAT
subnet 192.168.0.0 255.255.255.0
object network AD_Inside_Out_NAT
object network DB_Inside_Out_NAT
subnet 192.168.20.0 255.255.255.0
object network DMZ_Inside_Out_NAT
object network network-remote1
object network network-remote2
object network network-remote3
object-group network vpn-group-local
object-group network vpn-group-remote
network-object object network-remote1
network-object object network-remote2
network-object object network-remote3
object-group protocol DM_INLINE_PROTOCOL_1
protocol-object ip
protocol-object icmp
access-list Outside_access_in extended permit object-group DM_INLINE_PROTOCOL_1 object-group vpn-group-local object-group vpn-group-remote
access-list outside_1_cryptomap extended permit ip object-group vpn-group-local object-group vpn-group-remote
pager lines 24
logging enable
logging asdm informational
mtu AD_Zone 1500
mtu DB_Zone 1500
mtu Inside 1500
mtu DMZ_Zone 1500
mtu Outside 1500
mtu management 1500
failover
failover lan unit primary
failover lan interface failover Ethernet0/3
failover key
failover link failover Ethernet0/3
failover interface ip failover X.X.X.X X.X.X.X standby X.X.X.X
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
nat (DMZ_Zone,Outside) source static dmz-network-local dmz-network-local destination static network-remote1 network-remote1
nat (DMZ_Zone,Outside) source static dmz-network-local dmz-network-local destination static network-remote2 network-remote2
nat (DMZ_Zone,Outside) source static dmz-network-local dmz-network-local destination static network-remote3 network-remote3
nat (AD_Zone,Outside) source static ad-network-local ad-network-local destination static network-remote1 network-remote1
nat (AD_Zone,Outside) source static ad-network-local ad-network-local destination static network-remote2 network-remote2
nat (AD_Zone,Outside) source static ad-network-local ad-network-local destination static network-remote3 network-remote3
nat (DB_Zone,Outside) source static db-network-local db-network-local destination static network-remote1 network-remote1
nat (DB_Zone,Outside) source static db-network-local db-network-local destination static network-remote2 network-remote2
nat (DB_Zone,Outside) source static db-network-local db-network-local destination static network-remote3 network-remote3
nat (Inside,Outside) dynamic interface
nat (AD_Zone,Outside) dynamic interface
nat (DB_Zone,Outside) dynamic interface
nat (DMZ_Zone,Outside) dynamic interface
access-group AD_Zone_access_in in interface AD_Zone
access-group DB_Zone_access_in in interface DB_Zone
access-group Inside_access_in in interface Inside
access-group DMZ_Zone_access in interface DMZ_Zone
access-group Outside_access_in_1 in interface Outside control-plane
access-group Outside_access_in in interface Outside
route Outside 0.0.0.0 0.0.0.0 X.X.X.x 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
aaa authentication ssh console LOCAL
http server enable 9000
http X.X.X.X X.X.X.X management
http X.X.X.X X.X.X.X Outside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
service resetoutside
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto map outside_map 1 set peer X.X.X.X
crypto map outside_map interface Outside
crypto isakmp enable Outside
encryption 3des
hash sha
group 2
lifetime 86400
telnet 192.168.10.0 255.255.255.0 Inside
telnet timeout 5
ssh X.X.X.X 255.255.255.255 Outside
ssh X.X.X.X 255.255.255.0 Outside
ssh timeout 5
console timeout 0
dhcpd address 192.168.1.2-192.168.1.254 management
dhcpd enable management
threat-detection basic-threat
threat-detection statistics host
threat-detection statistics port
threat-detection statistics protocol
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
group-policy DfltGrpPolicy attributes
username
tunnel-group X.X.X.X type ipsec-l2l
tunnel-group X.X.X.X ipsec-attributes
pre-shared-key
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
service-policy global_policy global
prompt hostname context
Andrew,
Javier,
Thank you for the reply.
I was under the impression that you use the twice nat statment here? As I used the that config from one subnet to another which worked.
I will amend the config and report back, I wont be able to report back till later today
Basically, I just created more specific entries for your individual networks, for troubleshooting purposes and to avoid further issues, that's better.
Now, please clean up some other NAT rules that might be considered duplicates and try with the lines above.
Keep me posted
andy.dodd
I have managed to get it working correctly, I managed to resolve amending the NAT statement.
Javier, although your suggestion didn't work. It did make me think it was the NAT which was causing the problem.
I have amended my NAT statement to the following:
nat (any,Outside) source static obj-local obj-local destination static obj-remote obj-remote
Its also alot cleaner now due to using the object grouping in the NAT statement rather then a entry for each part.
I am glad to hear that
It is very interesting since what you did is what I recommended, but in different words.
Instead of defining a NAT statement per network / interface you used the "any" keyword.
Thank you so much for posting your problem on CSC, we look forward to working with you once again in the future.
Please mark this post as answered since the original issue has been resolved.
Many thanks for the help to solve the small problem I had.
Andy
You are very welcome
Take care.
