I believe you’re talking about anyconnect sslvpn.
Anyconnect ssl vpn and ezvpn, I believe they aren’t running on the same port.
Are both of them running on the same ASA?
They can be up and running together at the same time.
Have you tried it and did you face any issues?
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
