cisco asa ipsec s2s - routing between remote sides
Peter Handke
I have asa (8.2) in headquarter as hub, cisco 18xx in branches as spoke. I need make routing between remote LANs. On one side i have 192.168.211.0/24 on the other is 192.168.212.0/24. Ipsec phase 1 and phase 2 are ok but i can't ping from from 192.168.211.0/24 to 192.168.212.0/24 and vice versa. Packet trace says:
Phase: 8
Type: VPN
Subtype: encrypt
Result: DROP
Config:
Additional Information:
Forward Flow based lookup yields rule:
out id=0xd83fd240, priority=70, domain=encrypt, deny=false
        hits=53, user_data=0x0, cs_id=0xd7b688c8, reverse, flags=0x0,  protocol=0
        src ip=192.168.211.0, mask=255.255.255.0, port=0
        dst ip=192.168.212.0, mask=255.255.255.0, port=0, dscp=0x0
Drop-reason: (acl-drop) Flow is denied by configured rule
My config on asa:
crypto acl:
access-list test-p1-p2 line 1 extended permit ip 192.168.211.0  255.255.255.0 192.168.212.0 255.255.255.0
access-list test-p2-p1 line 2 extended permit ip 192.168.212.0  255.255.255.0 192.168.211.0 255.255.255.0
access-list nonat line 40 extended permit ip 192.168.211.0 255.255.255.0  192.168.212.0 255.255.255.0 (hitcnt=0)
access-list nonat line 41 extended permit ip 192.168.212.0 255.255.255.0  192.168.211.0 255.255.255.0 (hitcnt=0)
#outside interface
access-list outside line 1 extended permit ip 192.168.211.0  255.255.255.0 192.168.212.0 255.255.255.0
access-list outside line 2 extended permit ip 192.168.212.0  255.255.255.0 192.168.211.0 255.255.255.0
routing between remote lan:
route outside 192.168.211.0 255.255.255.0 194.146.123.1 1
route outside 192.168.212.0 255.255.255.0 194.146.123.1 1
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
What i'm doing wrong or what i have missing ?
Thanks for help
Peter
5 Replies 5
Peter,
Why do have the ACL in both directions?
May I know the LAN of the ASA?
It should something like:
crypto acl:
No need to add an outside interface
route outside 192.168.211.0 255.255.255.0 194.146.123.1 1 --> remove it, since it is on the inside.
Thanks.
Portu.
Thanks in advance.
LAN behind ASA is 192.168.50.0/24, but i need have comunication between
192.168.211.0/24 and 192.168.212.0/24
I have ACL in both direction because i need initialize connection from both sides:
192.168.211.0/24 <-> 192.168.212.0/24
i have both acl becasue i have two peers:
crypto map SDM_CMAP_1 211 match address test-p1-p2
crypto map SDM_CMAP_1 211 set peer 8.8.8.8
crypto map SDM_CMAP_1 212 match address test-p2-p1
crypto map SDM_CMAP_1 212 set peer 8.8.4.4
i removed :
but it didn't help
packet-tracer input outside icmp 192.168.211.1 0 3 192.168.212.1
Phase: 8
Type: VPN
Subtype: encrypt
Result: DROP
Config:
        hits=81, user_data=0x0, cs_id=0xd7b688c8, reverse, flags=0x0, protocol=0
++++++++++++++++++ ASA-P1. +++++++++++++++
crypto acl:
Tunnel group 8.8.8.8
++++++++++++++ ASA-P2. +++++++++++++++
Tunnel group 8.8.4.4
i have already configured in this way and i have still problem with encryption..
Then IKE and IPSEC on both sides are not matching. Set or add the option that match on both sides.
