11-15-2018 01:39 AM - edited 02-21-2020 09:30 PM
Is there any particular command which can be used to accept ASA VPN to accept existing anyconnects installed on clients ? Because on the ASA VPN wizard it does not seem possible to move on from the anyconnect image upload step.
Solved! Go to Solution.
11-15-2018 02:04 AM
When configuring remote access you do need to specify a valid anyconnect image located on the ASA appliance. However a client can connect using an older AnyConnect client. Be aware that the client could automatically upgrade the client, unless the client has been specifically configured not to automatically upgrade.
11-15-2018 02:04 AM
11-15-2018 02:08 AM
Sure , thank you !
