Cisco RV180 IPSec connection problem
madmas
Good day,
I have a CISCO RV180 router as a client and VPS with static IP (X.X.138.131) as a server (running up on the Debian+StrongSwan). CISCO is a router to which clients of the local network are connected (LAN - 192.168.1.0/24). Next, the WAN port of the router (192.168.0.199) is connected to the LAN (192.168.0.0/24) of the provider router (TP-Link). On WAN port of TP-Link real Dynamic IP. I need make IPSec connection between CISCO router and VPS server in the Internet to connect all LAN clients to Internet via VPS.
When I try to connect (to push "Connect" button on the status WEB page of the router), the status of connection don't change, but on the server side, when I run "ipsec statusall" I see one connection is up, but traffic don't go via this tunnel and I can't even do ping the VPS IP address from LAN (I have no any firewall or access rules), but all other IP in the Internet I can ping.
The same situation when I remove TPLink router and directly connect the Cisco router to the Internet.
Could you help me in my problem?
Maybe you'll advise using more suitable software on the VPS (not Debian+StrongSwan).
Thanks in advance!
0 Replies 0
